05-05-2015, 23:10 | #32 (permalink) |
Freak Poster Join Date: Oct 2004 Location: zanzibar Age: 53
Member: 84774 Status: Offline Thanks Meter: 11 | I9060i EMMC Does anyone know pinout for this type of emmc : D0 ,CMD ,CLK, 18V,3,3V, EMMC was removed from samsung I9060i Last edited by kodan; 05-05-2015 at 23:20. |
05-06-2015, 14:24 | #34 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | g900i emmc this is sm-g900i emmc and boot partition damage if possable plz send rom1 rom 2 and ext_csd Quote:
05-06-2015, 17:06 | #36 (permalink) |
Junior Member Join Date: Feb 2013 Location: hyderabad
Member: 1882373 Status: Offline Sonork: ikkks Thanks Meter: 2 | i9300 KMVTU000LM-B503 pin outs needed i need emmc pin outs for KMVTU000LM-B503 s3 i9300 and i dont have any emmc adaptor i want to connect it as direct connection i have ATF BIG BOX also its exynos doest it need to connect all connections ? clk cmd gnd data vcc vccq or only vcc vccq gnd (tp) emmc type is Here is eMMC NAND Factory Pinout Type A: i use this connections but still not ditected by emmc tookl 3.6 |
05-06-2015, 17:19 | #37 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
clk cmd gnd data vcc vccq --------- use 2.8v on both vcc and vccq | |
05-06-2015, 17:56 | #38 (permalink) |
Member: 1882373 Status: Offline Sonork: ikkks Thanks Meter: 2 | i m getting this error ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0x00FF8080 WARNING: POSSIBLE eMMC is TOTALLY DEAD!!! Interface Reset OK! eMMC Access Type is BYTE MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) Check your Test Point Soldering! Try to Adjust VCCIO Voltage and trying iwth vccio seting |
05-08-2015, 19:57 | #41 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Pls support firmware for this type: KLMBG4GE4A-A001 This type on Pantech SKY IM-A870L; IM-A870K and A870S It on hand, I can connect it via EMMC testpoint Quote:
05-10-2015, 15:55 | #42 (permalink) | |
Member: 1012390 Status: Offline Thanks Meter: 95 | Pls support firmware for this type: KLVYL000LM-B503 and KLVYL000LM-B603 This type on Pantech SKY IM-A760S; IM-A770K; SKY IM-A800S; SKY A810S; SKY A810K; LG F160S; LG F160L; LG F160K; Samsung S2 I9100; Samsung S2 LTE E110S; Samsung S2 HD E120L; E120K; E120S I can connect all of this PBC via emmc testpoint Quote:
