10-02-2017, 12:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | Rm-1067 dead boot repair error TEAM i have microsoft RM-1067, customer brought it update ,while updating in microsoft update tool power went of , and it is dead , so when i repair dead boot n ATF BIG BOX ,iam getting error messages ,this isi the log below SCAN ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48384731650503B5D3D84F42C9 CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G1e Product Rev : 0.3 Product SN : B5D3D84F Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48384731650503B5D3D84F42C9.ext_csd Backup Directory: C:\Program Files\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ WRITE ERROR Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! |
