(RM-320) n95 8gb after flash white screen big problem!!!! dear bro...i have take the phone from custormer....:rolleyes: 1st time problem is memory full ,phone work nice...:cool: then i try to flash it with atf 35.0001 version...after flash phone is white screen when power on.... then i backup the rpl , do full erase , full flash , write back rpl,repair simlock , repair sd , write full pm , write eno file rm320_ENO_x_2007wk45v0.020_sos.fpsx after that phone is goto test mode , but insert battery try phone is white screen restart too....any solution???:confused:i have try 2 set with this problem... |
log here~~~~ Basic Phone Information ================================================ MCU Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia IMEI Plain : 359542013802929 IMEI Spare : A359542013802920 IMEI SV : 33595420138029214F Phone Model: Nokia N95 8GB Category : Classic Phone Phone Type : RM-320 ================================================ Extended Phone Information ================================================ Product Serial Number: SHG437010 Product Code : 0557631 Basic Production Code: 0548236 Long Production SN : 0 MCU SW Version : V 06wk41v64.20 01-10-09 RM-320 (c) Nokia HW Version : 4120 RFIC Version : 17141715 DSP Version : aino.ICPR62_08w28p2 Content : RM320_31.0.002_U01 ¥ RM320_003_000_M025 APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Content Pack Version : RM320_31.0.002_U01 r RM320_003_000_M025 AHNE Version : 11 APE SW Core Version : 35.0.001 APE Test Version : rm320_eno_2007wk45v0.020 RETU Version : 15 TAHVO Version : 22 APE HW Version : 1 APE ADSP SW Version : 256 Wireless LAN ID : 00:1E:3A:8F:19:F4 Bluetooth ID : 00:1E:3A:7F:D7:B4 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST DCC ID : NOT USED |
Hi, If you perform selftests is everything ok (pass)? Karel |
...and did you tried * + 3 + call + power on (hard reset)? |
self test~ 08-ST_MBUS_RX_TX_LOOP_TEST = minor 3B-ST_MAIN_LCD_IF_TEST = minor other is all passed.... |
this solution is no work for me bro~。。;) |
@acelai00 Use this procedure, it should work if phone do not have any kind of hardware: http://forum.gsmhosting.com/vbb/7746277-post16.html |
step 88. Now flash the second ENO file to the phone, file name: "normalize_susd_eno_aino_urel.fpsx" Manually add the SINGLE file above in ATF Software and flash this SINGLE file to your phone... Flash Settings: * uncheck Backup Simlocks * uncheck Backup RPL * uncheck Factory Reset --> You will still get "Test Mode" on screen no work...when i input this file at mcu press flash atf no any respon....just write ( please wait load big file!!!) i wait long time but still no respon.... |
If You have followed the full procedure written by AdvanceBox, then I would suggest to chk phone hardware... BR |
200% sure phone will be ok try this try to rehot 8gb memory ic if not ok remove memory ic you will see some damage prints |
bor.........Nokia E63 Black Screen Problem....help..me |
