Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-02-2012, 08:02   #1 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
Thumbs up (RM-320) n95 8gb after flash white screen big problem!!!!
dear bro...i have take the phone from custormer....
1st time problem is memory full ,phone work nice...
then i try to flash it with atf 35.0001 version...after flash phone is white screen when power on....
then i backup the rpl , do full erase , full flash , write back rpl,repair simlock , repair sd , write full pm , write eno file rm320_ENO_x_2007wk45v0.020_sos.fpsx after that phone is goto test mode , but insert battery try phone is white screen restart too....any solution???i have try 2 set with this problem...
Old 02-02-2012, 08:30   #2 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
log here~~~~
Basic Phone Information
MCU Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia
IMEI Plain : 359542013802929
IMEI Spare : A359542013802920
IMEI SV : 33595420138029214F
Phone Model: Nokia N95 8GB
Category : Classic Phone
Phone Type : RM-320
Extended Phone Information
Product Serial Number: SHG437010
Product Code : 0557631
Basic Production Code: 0548236
Long Production SN : 0
MCU SW Version : V 06wk41v64.20 01-10-09 RM-320 (c) Nokia
HW Version : 4120
RFIC Version : 17141715
DSP Version : aino.ICPR62_08w28p2
Content : RM320_31.0.002_U01 RM320_003_000_M025
APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
Content Pack Version : RM320_31.0.002_U01 r RM320_003_000_M025
AHNE Version : 11
APE SW Core Version : 35.0.001
APE Test Version : rm320_eno_2007wk45v0.020
RETU Version : 15
TAHVO Version : 22
APE HW Version : 1
APE ADSP SW Version : 256
Wireless LAN ID : 00:1E:3A:8F:19:F4
Bluetooth ID : 00:1E:3A:7F7:B4
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I
Simlock Information
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL2
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
DCC ID : NOT USED
Old 02-02-2012, 08:42   #3 (permalink)
Karlos007's Avatar
Member: 170013
Thanks Meter: 42
Hi, If you perform selftests is everything ok (pass)?
Karel
Old 02-02-2012, 08:48   #4 (permalink)
Karlos007's Avatar
Member: 170013
Thanks Meter: 42
...and did you tried * + 3 + call + power on (hard reset)?
Old 02-02-2012, 09:40   #5 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
self test~
08-ST_MBUS_RX_TX_LOOP_TEST = minor
3B-ST_MAIN_LCD_IF_TEST = minor
other is all passed....
Old 02-02-2012, 09:41   #6 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
this solution is no work for me bro~。。
Old 02-02-2012, 09:48   #7 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,483
@acelai00
Use this procedure, it should work if phone do not have any kind of hardware:
N95 8gb dead after flash - (SOLVED - Solution Inside)
Old 02-02-2012, 10:09   #8 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
Originally Posted by ..::Angel::.. View Post
@acelai00
this solution i have read and try before open thread bro...
step 88. Now flash the second ENO file to the phone, file name:
"normalize_susd_eno_aino_urel.fpsx"
Manually add the SINGLE file above in ATF Software and flash this
SINGLE file to your phone...
Flash Settings:
* uncheck Backup Simlocks
* uncheck Backup RPL
* uncheck Factory Reset
--> You will still get "Test Mode" on screen
no work...when i input this file at mcu press flash atf no any respon....just write ( please wait load big file!!!) i wait long time but still no respon....
Old 02-02-2012, 10:23   #9 (permalink)
Member: 643472
Sonork: 100.96901
Flash Settings:
Hi,
If You have followed the full procedure written by AdvanceBox, then I would
suggest to chk phone hardware...
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 02-02-2012, 10:31   #10 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 706
200% sure phone will be ok try this
try to rehot 8gb memory ic if not ok
remove memory ic you will see some damage prints
The Following User Says Thank You to chand_gee For This Useful Post:
Old 02-02-2012, 10:32   #11 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 90
bor.........Nokia E63 Black Screen Problem....help..me
Old 02-02-2012, 10:58   #12 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
Hi,
thank your suggest bro...i try to check the mmc ic
Old 02-02-2012, 11:01   #13 (permalink)
acelai00's Avatar
Member: 255011
Thanks Meter: 56
yes bro! i try check it and reply back~~~~
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 11-23-2017 07:11
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
Really big favour! MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-18-1999 03:21
Page generated in 0.42475 seconds with 8 queries
