Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-30-2016, 16:55   #1 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
rm-914 dead after remove protection
phone shows unable to find bootloader state
i remove protection and phone become dead
i repire dead boot in windows phone menu with tp service here is the logs
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 1501004D384732594300FA00BC1C90AF
CSD : D02701320F5903FFF6DBFFEF96404063
eMMC Boot Information
Revision 1.5 (for MMC v4.41)
BOOT PARTITION : USER AREA
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 7818182656 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : M8G2YC
Product Rev : 0.0
Product SN : FA00BC1C
Manufactured : September 1997
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
1501004D384732594300FA00BC1C90AF.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Writing MBR + GPT...
Write Success!
Writing SBL1...
Write Success!
Writing SBL2...
Write Success!
Writing SBL3...
Write Success!
Writing UEFI...
Write Success!
Writing RPM...
Write Success!
Writing TZ...
Write Success!
Writing WINSECAPP...
Write Success!
BOOT Images Written Successfully!
Be sure to desolder all the wires properly
before you try to flash the phone (if needed).
Total Elapsed Time 00:14:07
but phone still dead
here is the info
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
emmc name is
K4P4G324EB-PGC2
cant format and upgreade the emmc becouse their is not any firmware for this cpu
need firmware or other way to boot the phone
Page generated in 0.13132 seconds with 8 queries
