03-07-2016, 21:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 591084 Status: Offline Thanks Meter: 41 | rm-980 repair boot done no power then vibrate only now after repair nothing asking qualcomm driver only product 059T9F2 file used NOKIA_X_RM-980_FULL_BOOT_11.1.1.afp here is log Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0xF805864C Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/28/2014 12:00:00 PM ================================================== ======== Phone Type : Nokia X [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 11.1.1 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...15010030303030303056201305155880 Flash Description: Samsung 000000, 8.19 GiB, SN 20130515, May 2005 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (92036 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 2s. Code Download Speed 865 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
