09-04-2013, 05:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: mindanao L-D-S
Member: 1339214 Status: Offline Thanks Meter: 514 | s100 ERROR: Connection Refused (CMD2) ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V ERROR: Connection Refused (CMD2) Check your Test Point Soldering! |
09-04-2013, 08:46 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | disconnect usb procedure 1st -> Check your Test Point Soldering! 1. click scan emmc 2. connect micro usb. |
09-04-2013, 10:50 | #3 (permalink) |
Member: 1339214 Status: Offline Thanks Meter: 514 | solved ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : XINYH Product Rev : 1.2 Product SN : A1434FAC Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Start Writing 0x0009E73E Blocks at 0x00000000 Partition Selected: USER AREA |
The Following User Says Thank You to amar85 For This Useful Post: |
09-04-2013, 11:17 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @amar85 WOW, First time I saw a success log Remember, when it look like it "hang", just disconnect USB cable from phone and wait until ATF exe will react... then connect USB cable again to phone. It will continue to where it previously stopped. Start Writing 0x0009E73E Blocks at 0x00000000 <------- What file is this? |
09-04-2013, 12:10 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @amar85 I think you are writing JTAG AFP file !!!! This will not fix your phone !!!! This file is for ATF JTAG only. CM_FLARE_S100_JBv006045.afp <----- This is for ATF JTAG !!! You need to write this file for eMMC: 4shared folder - eMMC REPAIR FILES When you extract it, it will be a BIN file CM_FLARE_S100_JBv006045.bin <------- This is for eMMC TP (681 MB) You need to write it again using correct files. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-04-2013, 12:33 | #6 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | if it is like these ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED ERROR: Connection Refused 0x06 Check your Test Point Soldering! |
09-04-2013, 13:16 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @TestCard17 eMMC is replying corrupt info: If you want to see corrupted info, you can use this exe from here: http://174.120.45.27/lemor/AdvanceBox.exe There is still 10.11 exe,, but this exe will show you data read from eMMC... B.R. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
09-05-2013, 02:10 | #8 (permalink) |
Freak Poster Join Date: Jul 2007 Location: philippines
Member: 555850 Status: Offline Thanks Meter: 14 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED eMMC Device Information Manufacturer ID: 65 Device Type : Removable Card Application ID : 6F Product Name : M MORN Product Rev : 4.6 Product SN : 00010000 Manufactured : January 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Start Writing 0x0014CA20 Blocks at 0x00000000 Partition Selected: USER AREA when i leave it connected it stops and returns to ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box but when i reattach the usb cable during the Start Writing 0x0014CA20 Blocks at 0x00000000 Partition Selected: USER AREA the status bar shows writing custom block 0x00000000 then returns to ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box |
09-05-2013, 03:31 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | emmc is corrupted its not reading the emmc properly look up the manufacturer its diff. from in your reading |
The Following User Says Thank You to lemor For This Useful Post: |
09-05-2013, 05:54 | #10 (permalink) | |
Member: 1339214 Status: Offline Thanks Meter: 514 | Quote:
hi bro im back please need other link like mediafire thanks... | |
09-05-2013, 11:18 | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | |
09-07-2013, 04:26 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @amar85 If it looks like it hanged, just disconnect USB cable from phone and wait until ATF software will detect that you have disconnected the phone. Then connect it back, ATF software will continue writing where it stopped. |
