03-02-2016, 15:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | S7560m boot repair problem atfjtag Phone Type : Samsung GT-S7560M CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (Android 4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91445 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Bad Answer from Loader 0xFFFFFFFF, 0x5F04 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91436 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Task Process Saved to: GT-S7560M_FULL_BOOT.task Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (91435 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Task Process Saved to: GT-S7560M_FULL_BOOT.task Please send this log and "..\Logs\.log" file to support! Loading AFP (Please Wait)...OK AFP revision 4, compiled 5/25/2014 6:45:00 PM ================================================== ======== Phone Type : Samsung GT-S7560M CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (Android 4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106230E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (91436 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Task Process Saved to: GT-S7560M_FULL_BOOT.task Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (91431 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Task Process Saved to: GT-S7560M_FULL_BOOT.task Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (91451 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91429 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91423 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91411 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91429 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A533030410318297EA04015 Flash Description: Samsung JJS00A, 3.64 GiB, SN 18297EA0, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91433 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! |
