02-02-2015, 00:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | S7562L dead boot Default language ID 0x0416, LR 12 JTAG Interface Connected, S/N 0x8XXXXX6E Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/05/2014 18:59:00 ================================================== ======== Phone Type : Samsung GT-S7562L CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A53303041031E170FA3AF5E Flash Description: Samsung JJS00A, 3.64 GiB, SN 1E170FA3, Oct 2012 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91370 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 3m 4s. Code Download Speed 112 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
02-02-2015, 00:15 | #2 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | I try, try, try but phone is dead, battery 100% display perfect Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/05/2014 18:59:00 ================================================== ======== Phone Type : Samsung GT-S7562L CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106230E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A53303041031E170FA3AF5E Flash Description: Samsung JJS00A, 3.64 GiB, SN 1E170FA3, Oct 2012 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (90605 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 3m 16s. Code Download Speed 106 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
