02-28-2015, 16:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | <<< Samsung eMMC Write Protection Removal >>> 2. So if eMMC is Samsung, just wire eMMC Connection and do this: If you do not know eMMC Pinout, then you can Find the eMMC Pinout via following Steps here: http://forum.gsmhosting.com/vbb/f609...orial-1908984/ So here we see eMMC is SAMSUNG Brand and PERM_WRITE_PROTECT is YES... This means eMMC is WRITE PROTECTED... So here just select Advance Function "Samsung Remove Write Protection" then click "YES". After Operation will finish, click "SCAN EMMC" again to see the updated Write Protection Information... see here it is already Removed... *** This procedure WILL NOT TOUCH DATA on your eMMC. Whatever was inside your eMMC before the procedure is 100% same as after the procedure, except only that Write Protection was Removed! *** |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
02-28-2015, 16:30 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Because some phones get Write Protected due to BUG in Phone Operating System and Samsung eMMC Firmware. Example, many complained about getting WP = ON after updating their Lumia 520 to WP 8.1. This bricks the phone... We cannot boot repair it because it is WRITE PROTECTED. So need to remove Write Protection to fix the Phone bug. |
The Following 6 Users Say Thank You to Advance-Box For This Useful Post: |
02-28-2015, 16:37 | #4 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | this method will work with all new phones that have Samsung emmc chips??and what about htc devices..u know there are too many modules like desire 500,300 and 700 have same issue. b.r. |
02-28-2015, 17:28 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @bk.gsm 1. First open phone. Check if samsung eMMC Inside. 2. Then check 1 phone, connect with eMMC Tool to see if WP is ON... If both 1 and 2 is YES, then you will be able to fix it. If you can show me that other eMMC Brand also have WP problem, then I can check on these brands as well. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
03-18-2015, 15:46 | #8 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | need pinouts for rm-875 909 i have this adapter,, ========= just instaled nokia emergency driver ------- --------------- Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 ERROR: eMMC WRITE Failed at 0x01000000 Skipping This Partition... Start Writing eMMC Blocks at : 0x01200000 ERROR: eMMC WRITE Failed at 0x01200000 7E0D07000000577269746520756E7375636365737366756CF0 5B7E ERROR: Flashing Failed! |
03-24-2015, 08:30 | #10 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | IS there any possibiliy to check WP-0N or not.so we dont update that phones.and if u can describe here Lumia models which could be brick after update wp 8.1 so we avoid to update thats models. |
03-24-2015, 08:38 | #11 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | this Adapter Wont work properly incomplete Adapter and copy by other teams Quote:
03-26-2015, 11:49 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300FFDFC0B690F7 CSD : D02701320F5903FFF6DBFFEF96406063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : FFDFC0B6 Manufactured : September 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300FFDFC0B690F7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung Remove Write Protection ================================================== ==== --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC --> Make Sure you BACKUP eMMC DUMP Just In Case... ================================================== ==== Permanent Write Protection Removed! Perform USB Firmware Update if Needed... now set condition is dead ? what i do next ? next procedure ? must be flash after samsung romove write protection |
01-02-2016, 17:38 | #15 (permalink) | |
Insane Poster Join Date: Jun 2014
Member: 2208230 Status: Offline Thanks Meter: 6 | can i use this faction Quote:
