02-11-2016, 17:19 | #17 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | Huawei G510-0010 Done emmc only read thanx ATF team ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100534A5330304D004DD17B1DCF1F CSD : D02701320F5903FFF6DBFFE78A406033 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3909091328 BYTES BOOT PARTITION SIZE: 1024 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : SJS00M Product Rev : 0.0 Product SN : 4DD17B1D Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100534A5330304D004DD17B1DCF1F.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100534A5330304D004DD17B1DCF1F CSD : D02701320F5903FFF6DBFFE78A404057 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3909091328 BYTES BOOT PARTITION SIZE: 1024 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : SJS00M Product Rev : 0.0 Product SN : 4DD17B1D Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100534A5330304D004DD17B1DCF1F.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Last edited by Pablo Velasqu; 02-11-2016 at 17:25. |
04-08-2016, 11:28 | #18 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Hi, Is there any way to find emmc pinout in MTK phones. Facing one MTK 6582 set with Samsung emmc which has became read only! Code: [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMVX7 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 1501004B3758564D42013F27DEF2713B [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! |
