08-22-2016, 12:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: philippines
Member: 2226456 Status: Offline Sonork: jerrenn Thanks Meter: 83 | samsung gt-p3100 tab 2 7.0 DEADBOOT DONE via direct emmc by ATFBOX dis assemble the tablet im using 4 IN 1 JTAG EMMC ADAPTER solder emmc pin out then open atf software follow my screenshot below then load tested file from any box support,or from samsung mobile firmware after emmc flashing the tab become alive and blue screen all you have to to is to full flash via odin ,z3x,octopus set then phone into download mode state by pressing VOLUME +POWER BUTTON Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D414732474107B7009AB19F45 CSD : D02701320F5903FFF6DBFFFF8A404007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MAG2GA Product Rev : 0.7 Product SN : B7009AB1 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D414732474107B7009AB19F45.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT Start Writing 0x00000005 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Warning: EXT3/4 Image Detected Skipping system.img... Flash Image: boot.img Start Writing 0x00004000 Blocks at 0x00012000 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Warning: EXT3/4 Image Detected Skipping cache.img... Warning: EXT3/4 Image Detected Skipping hidden.img... Flash Image: recovery.img Start Writing 0x00004000 Blocks at 0x00016000 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Flash Image: mlo Start Writing 0x00000200 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: param.lfs Start Writing 0x00004000 Blocks at 0x0000E000 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Flash Image: sbl.bin Start Writing 0x00001000 Blocks at 0x0000C000 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: modem.bin Start Writing 0x0000A000 Blocks at 0x00178000 Partition Selected: USER AREA Total Elapsed Time 00:00:33 Write Success! Total Images Written: 6 Process Done! |
The Following 4 Users Say Thank You to jennydahan For This Useful Post: |
06-17-2018, 08:50 | #4 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | NO NEED dump just write full repair firmware with pit file ... https://androidfilehost.com/?fid=24438995911974806 |
