01-08-2016, 09:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1749874 Status: Offline Sonork: 100.1663210QQ:20249255921 Thanks Meter: 437 | Samsung I9060/ds Kiess mode ALl EMMC Process Done Phone now ded cant.t show dl mode manually nd also use MBC cable plz help me 1. DO NOT USE THE PHONE"S BATTERY 13:17:31 : 2. Connect the Soldered TP Connections to ATF Box 13:17:31 : 3. Disconnect the USB Cable and Wait until the 13:17:31 : the ATF Software will tell you to Connect the USB. 13:17:31 : 13:17:31 : 13:17:31 : Interface Reset OK! 13:17:31 : eMMC Access Type: SECTOR MODE 13:17:31 : eMMC Supported Voltage Range: 13:17:31 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:17:31 : 13:17:31 : CID : 1501004B3758564D4203831AD00EC0B3 13:17:31 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:17:31 : 13:17:31 : eMMC Boot Information 13:17:31 : Revision 1.6 (for MMC v4.5, v4.51) 13:17:31 : BOOT PARTITION : NOT BOOT ENABLED 13:17:31 : PARTITION ACCESS : R/W USER PARTITION 13:17:31 : PERM_BOOT_CFG_PROT : DISABLED 13:17:31 : PWR_BOOT_CFG_PROT : DISABLED 13:17:31 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 13:17:31 : RESET BUS WIDTH : ENABLED 13:17:31 : eMMC FirmW UPDATE : DISABLED 13:17:31 : EMMC CACHE SIZE : 0 KB 13:17:31 : SUPER PAGE SIZE : 3072 KB 13:17:31 : HC ERASE GROUP SIZE: 512 KB 13:17:31 : USER AREA SIZE : 7818182656 BYTES 13:17:31 : BOOT PARTITION SIZE: 4096 KB 13:17:31 : RPMB PARTITION SIZE: 512 KB 13:17:31 : 13:17:31 : 13:17:31 : eMMC Device Information 13:17:31 : Manufacturer ID: SAMSUNG 13:17:31 : Device Type : Embedded BGA 13:17:31 : Application ID : 00 13:17:31 : Product Name : K7XVMB 13:17:31 : Product Rev : 0.3 13:17:31 : Product SN : 831AD00E 13:17:31 : Manufactured : December 1997 13:17:31 : 13:17:31 : Card Specific Data 13:17:31 : CSD_STRUCTURE : Extended 13:17:31 : SPEC_VERS : Version 4.1/4.2/4.3 13:17:31 : TAAC : 13 ns 13:17:31 : TRAN_SPEED : 4000000 KHz 13:17:31 : READ_BL_LEN : 512 Bytes 13:17:31 : C_SIZE : HIGH CAPACITY 13:17:31 : WP_GRP_ENABLE : YES 13:17:31 : WRITE_BL_LEN : 512 Bytes 13:17:31 : CONTENT_PROT_APP : NO 13:17:31 : PERM_WRITE_PROTECT: NO 13:17:31 : TMP_WRITE_PROTECT : NO 13:17:31 : 13:17:31 : Extended CSD Saved: 13:17:31 : 1501004B3758564D4203831AD00EC0B3.ext_csd 13:17:31 : Backup Directory: 13:17:31 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:17:31 : 13:17:57 : ================================================== ==== 13:17:57 : ================================================== ==== 13:17:57 : eMMC Test Point Connection Module 13:17:57 : ================================================== ==== 13:17:57 : ================================================== ==== 13:17:57 : 13:17:57 : 1. DO NOT USE THE PHONE"S BATTERY 13:17:57 : 2. Connect the Soldered TP Connections to ATF Box 13:17:57 : 3. Disconnect the USB Cable and Wait until the 13:17:57 : the ATF Software will tell you to Connect the USB. 13:17:57 : 13:17:57 : 13:17:57 : Interface Reset OK! 13:17:57 : eMMC Access Type: SECTOR MODE 13:17:57 : eMMC Supported Voltage Range: 13:17:57 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:17:57 : 13:17:57 : CID : 1501004B3758564D4203831AD00EC0B3 13:17:57 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:17:57 : 13:17:57 : eMMC Boot Information 13:17:57 : Revision 1.6 (for MMC v4.5, v4.51) 13:17:57 : BOOT PARTITION : NOT BOOT ENABLED 13:17:57 : PARTITION ACCESS : R/W USER PARTITION 13:17:57 : PERM_BOOT_CFG_PROT : DISABLED 13:17:57 : PWR_BOOT_CFG_PROT : DISABLED 13:17:57 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 13:17:57 : RESET BUS WIDTH : ENABLED 13:17:57 : eMMC FirmW UPDATE : DISABLED 13:17:57 : EMMC CACHE SIZE : 0 KB 13:17:57 : SUPER PAGE SIZE : 3072 KB 13:17:57 : HC ERASE GROUP SIZE: 512 KB 13:17:57 : USER AREA SIZE : 7818182656 BYTES 13:17:57 : BOOT PARTITION SIZE: 4096 KB 13:17:57 : RPMB PARTITION SIZE: 512 KB 13:17:57 : 13:17:57 : 13:17:57 : eMMC Device Information 13:17:57 : Manufacturer ID: SAMSUNG 13:17:57 : Device Type : Embedded BGA 13:17:57 : Application ID : 00 13:17:57 : Product Name : K7XVMB 13:17:57 : Product Rev : 0.3 13:17:57 : Product SN : 831AD00E 13:17:57 : Manufactured : December 1997 13:17:57 : 13:17:57 : Card Specific Data 13:17:57 : CSD_STRUCTURE : Extended 13:17:57 : SPEC_VERS : Version 4.1/4.2/4.3 13:17:57 : TAAC : 13 ns 13:17:57 : TRAN_SPEED : 4000000 KHz 13:17:57 : READ_BL_LEN : 512 Bytes 13:17:57 : C_SIZE : HIGH CAPACITY 13:17:57 : WP_GRP_ENABLE : YES 13:17:57 : WRITE_BL_LEN : 512 Bytes 13:17:57 : CONTENT_PROT_APP : NO 13:17:57 : PERM_WRITE_PROTECT: NO 13:17:57 : TMP_WRITE_PROTECT : NO 13:17:57 : 13:17:57 : Extended CSD Saved: 13:17:57 : 1501004B3758564D4203831AD00EC0B3.ext_csd 13:17:57 : Backup Directory: 13:17:57 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:17:57 : 13:22:27 : ================================================== ==== 13:22:27 : ================================================== ==== 13:22:27 : eMMC Test Point Connection Module 13:22:27 : ================================================== ==== 13:22:27 : ================================================== ==== 13:22:27 : 13:22:27 : 1. DO NOT USE THE PHONE"S BATTERY 13:22:27 : 2. Connect the Soldered TP Connections to ATF Box 13:22:27 : 3. Disconnect the USB Cable and Wait until the 13:22:27 : the ATF Software will tell you to Connect the USB. 13:22:27 : 13:22:27 : 13:22:27 : Interface Reset OK! 13:22:27 : eMMC Access Type: SECTOR MODE 13:22:27 : eMMC Supported Voltage Range: 13:22:27 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:22:27 : 13:22:27 : CID : 1501004B3758564D4203831AD00EC0B3 13:22:27 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:22:27 : 13:22:27 : eMMC Boot Information 13:22:27 : Revision 1.6 (for MMC v4.5, v4.51) 13:22:27 : BOOT PARTITION : NOT BOOT ENABLED 13:22:27 : PARTITION ACCESS : R/W USER PARTITION 13:22:27 : PERM_BOOT_CFG_PROT : DISABLED 13:22:27 : PWR_BOOT_CFG_PROT : DISABLED 13:22:27 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 13:22:27 : RESET BUS WIDTH : ENABLED 13:22:27 : eMMC FirmW UPDATE : DISABLED 13:22:27 : EMMC CACHE SIZE : 0 KB 13:22:27 : SUPER PAGE SIZE : 3072 KB 13:22:27 : HC ERASE GROUP SIZE: 512 KB 13:22:27 : USER AREA SIZE : 7818182656 BYTES 13:22:27 : BOOT PARTITION SIZE: 4096 KB 13:22:27 : RPMB PARTITION SIZE: 512 KB 13:22:27 : 13:22:27 : 13:22:27 : eMMC Device Information 13:22:27 : Manufacturer ID: SAMSUNG 13:22:27 : Device Type : Embedded BGA 13:22:27 : Application ID : 00 13:22:27 : Product Name : K7XVMB 13:22:27 : Product Rev : 0.3 13:22:27 : Product SN : 831AD00E 13:22:27 : Manufactured : December 1997 13:22:27 : 13:22:27 : Card Specific Data 13:22:27 : CSD_STRUCTURE : Extended 13:22:27 : SPEC_VERS : Version 4.1/4.2/4.3 13:22:27 : TAAC : 13 ns 13:22:27 : TRAN_SPEED : 4000000 KHz 13:22:27 : READ_BL_LEN : 512 Bytes 13:22:27 : C_SIZE : HIGH CAPACITY 13:22:27 : WP_GRP_ENABLE : YES 13:22:27 : WRITE_BL_LEN : 512 Bytes 13:22:27 : CONTENT_PROT_APP : NO 13:22:27 : PERM_WRITE_PROTECT: NO 13:22:27 : TMP_WRITE_PROTECT : NO 13:22:27 : 13:22:27 : Extended CSD Saved: 13:22:27 : 1501004B3758564D4203831AD00EC0B3.ext_csd 13:22:27 : Backup Directory: 13:22:27 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:22:27 : 13:25:11 : ================================================== ==== 13:25:11 : ================================================== ==== 13:25:11 : eMMC Test Point Connection Module 13:25:11 : ================================================== ==== 13:25:11 : ================================================== ==== 13:25:11 : 13:25:11 : 1. DO NOT USE THE PHONE"S BATTERY 13:25:11 : 2. Connect the Soldered TP Connections to ATF Box 13:25:11 : 3. Disconnect the USB Cable and Wait until the 13:25:11 : the ATF Software will tell you to Connect the USB. 13:25:11 : 13:25:11 : 13:25:11 : Interface Reset OK! 13:25:11 : eMMC Access Type: SECTOR MODE 13:25:11 : eMMC Supported Voltage Range: 13:25:11 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:25:11 : 13:25:11 : CID : 1501004B3758564D4203831AD00EC0B3 13:25:11 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:25:11 : 13:25:11 : eMMC Boot Information 13:25:11 : Revision 1.6 (for MMC v4.5, v4.51) 13:25:11 : BOOT PARTITION : NOT BOOT ENABLED 13:25:11 : PARTITION ACCESS : R/W USER PARTITION 13:25:11 : PERM_BOOT_CFG_PROT : DISABLED 13:25:11 : PWR_BOOT_CFG_PROT : DISABLED 13:25:11 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 13:25:11 : RESET BUS WIDTH : ENABLED 13:25:11 : eMMC FirmW UPDATE : DISABLED 13:25:11 : EMMC CACHE SIZE : 0 KB 13:25:11 : SUPER PAGE SIZE : 3072 KB 13:25:11 : HC ERASE GROUP SIZE: 512 KB 13:25:11 : USER AREA SIZE : 7818182656 BYTES 13:25:11 : BOOT PARTITION SIZE: 4096 KB 13:25:11 : RPMB PARTITION SIZE: 512 KB 13:25:11 : 13:25:11 : 13:25:11 : eMMC Device Information 13:25:11 : Manufacturer ID: SAMSUNG 13:25:11 : Device Type : Embedded BGA 13:25:11 : Application ID : 00 13:25:11 : Product Name : K7XVMB 13:25:11 : Product Rev : 0.3 13:25:11 : Product SN : 831AD00E 13:25:11 : Manufactured : December 1997 13:25:11 : 13:25:11 : Card Specific Data 13:25:11 : CSD_STRUCTURE : Extended 13:25:11 : SPEC_VERS : Version 4.1/4.2/4.3 13:25:11 : TAAC : 13 ns 13:25:11 : TRAN_SPEED : 4000000 KHz 13:25:11 : READ_BL_LEN : 512 Bytes 13:25:11 : C_SIZE : HIGH CAPACITY 13:25:11 : WP_GRP_ENABLE : YES 13:25:11 : WRITE_BL_LEN : 512 Bytes 13:25:11 : CONTENT_PROT_APP : NO 13:25:11 : PERM_WRITE_PROTECT: NO 13:25:11 : TMP_WRITE_PROTECT : NO 13:25:11 : 13:25:11 : Extended CSD Saved: 13:25:11 : 1501004B3758564D4203831AD00EC0B3.ext_csd 13:25:11 : Backup Directory: 13:25:11 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:25:11 : 13:25:13 : 13:25:13 : Task Selected: Samsung eMMC Firmware Update 13:25:13 : ================================================== ==== 13:25:13 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 13:25:13 : --> This will RESET EXT_CSD Programming Such as BOOT 13:25:13 : Options, Bus Characteristics and Partition Sizes.. 13:25:13 : ================================================== ==== 13:25:13 : 13:25:13 : Please Manually Select the Correct 13:25:13 : Part Number of your eMMC Device. 13:25:13 : 13:25:13 : ================================================== ==== 13:25:13 : If you select a WRONG PART NUMBER, then 13:25:13 : YOU WILL PROBABLY KILL THE EMMC !!! 13:25:13 : ================================================== ==== 13:25:20 : 13:25:20 : ================================================== ==== 13:25:20 : Loading ATF eMMC Firmware File... (Please Wait) 13:25:20 : ================================================== ==== 13:25:20 : 13:25:20 : 13:25:28 : File Author: ATF Team @ edocomsel 13:25:28 : Date Created: 02/06/2015 (dd/mm/yyyy) 13:25:28 : Description: Samsung eMMC Firmware 13:25:28 : eMMC Part Number: KMK7X000VM-B314 13:25:28 : eMMC Product Name: K7XVMB 13:25:28 : eMMC Product Rev: 0.1 13:25:28 : 13:25:28 : Preparing eMMC for Firmware Update... 13:25:37 : Sending eMMC Firmware Blocks... 13:25:40 : All Blocks Sent! 13:25:40 : NAND Write Delay: 1 Second (Please Wait) 13:25:41 : Applying eMMC Firmware Update... 13:25:41 : Waiting for Device Re-Initialization... 13:25:41 : Firmware Write Protect Delay: 1 Second (Please Wait) 13:25:42 : Checking eMMC Firmware Update Status... 13:25:46 : Applying Final Patches... 13:25:46 : eMMC Firmware Update Successful! 13:25:46 : 13:25:46 : 13:25:46 : ================================================== ==== 13:25:46 : Your eMMC is now a Brand New BLANK Device!!! 13:25:46 : ================================================== ==== 13:25:46 : Resize BOOT and RPM Partitions if needed... 13:25:46 : ReWrite BOOT1, BOOT2 and USER Partitions if needed... 13:25:46 : ReWrite EXT_CSD File if needed... 13:25:46 : Make sure eMMC BOOT Options are Correct for your Phone 13:25:46 : ================================================== ==== 13:25:46 : 13:25:46 : Total Elapsed Time 00:00:17 13:25:52 : ================================================== ==== 13:25:52 : ================================================== ==== 13:25:52 : eMMC Test Point Connection Module 13:25:52 : ================================================== ==== 13:25:52 : ================================================== ==== 13:25:52 : 13:25:52 : 1. DO NOT USE THE PHONE"S BATTERY 13:25:52 : 2. Connect the Soldered TP Connections to ATF Box 13:25:52 : 3. Disconnect the USB Cable and Wait until the 13:25:52 : the ATF Software will tell you to Connect the USB. 13:25:52 : 13:25:52 : 13:25:52 : Interface Reset OK! 13:25:52 : eMMC Access Type: SECTOR MODE 13:25:52 : eMMC Supported Voltage Range: 13:25:52 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:25:52 : 13:25:52 : CID : 1501004B3758564D30012400D00E8165 13:25:52 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:25:52 : 13:25:52 : eMMC Boot Information 13:25:52 : Revision 1.7 (for MMC v5.0, v5.01) 13:25:52 : BOOT PARTITION : NOT BOOT ENABLED 13:25:52 : PARTITION ACCESS : R/W USER PARTITION 13:25:52 : PERM_BOOT_CFG_PROT : DISABLED 13:25:52 : PWR_BOOT_CFG_PROT : DISABLED 13:25:52 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 13:25:52 : RESET BUS WIDTH : ENABLED 13:25:52 : eMMC FirmW UPDATE : DISABLED 13:25:52 : EMMC CACHE SIZE : 0 KB 13:25:52 : SUPER PAGE SIZE : 3072 KB 13:25:52 : HC ERASE GROUP SIZE: 512 KB 13:25:52 : USER AREA SIZE : 7818182656 BYTES 13:25:52 : BOOT PARTITION SIZE: 4096 KB 13:25:52 : RPMB PARTITION SIZE: 512 KB 13:25:52 : 13:25:52 : 13:25:52 : eMMC Device Information 13:25:52 : Manufacturer ID: SAMSUNG 13:25:52 : Device Type : Embedded BGA 13:25:52 : Application ID : 00 13:25:52 : Product Name : K7XVM0 13:25:52 : Product Rev : 0.1 13:25:52 : Product SN : 2400D00E 13:25:52 : Manufactured : January 1998 13:25:52 : 13:25:52 : Card Specific Data 13:25:52 : CSD_STRUCTURE : Extended 13:25:52 : SPEC_VERS : Version 4.1/4.2/4.3 13:25:52 : TAAC : 13 ns 13:25:52 : TRAN_SPEED : 4000000 KHz 13:25:52 : READ_BL_LEN : 512 Bytes 13:25:52 : C_SIZE : HIGH CAPACITY 13:25:52 : WP_GRP_ENABLE : YES 13:25:52 : WRITE_BL_LEN : 512 Bytes 13:25:52 : CONTENT_PROT_APP : NO 13:25:52 : PERM_WRITE_PROTECT: NO 13:25:52 : TMP_WRITE_PROTECT : NO 13:25:52 : 13:25:52 : Extended CSD Saved: 13:25:52 : 1501004B3758564D30012400D00E8165.ext_csd 13:25:52 : Backup Directory: 13:25:52 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:25:52 : 13:25:53 : 13:25:53 : Task Selected: Normal Factory Erase 13:25:53 : ================================================== ==== 13:25:53 : For eMMC Revision 1.2 (for MMC v4.2) and LOWER 13:25:53 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 13:25:53 : For eMMC Revision 1.3 (for MMC v4.3) and HIGHER 13:25:53 : --> This will ONLY ERASE USER AREA 13:25:53 : ================================================== ==== 13:25:53 : This eMMC is: Revision 1.x (For MMC v4.x) 13:25:53 : 13:25:53 : Factory Erasing Supported FLASH AREA... 13:25:56 : Normal Factory Erase Done! 13:25:56 : 13:25:56 : ================================================== ==== 13:25:56 : WARNING - WARNING - WARNING - WARNING - WARNING 13:25:56 : ================================================== ==== 13:25:56 : 1. WRITE BOOT1 Image if Needed 13:25:56 : 2. WRITE BOOT2 Image if Needed 13:25:56 : 3. WRITE USER AREA Image if Needed 13:25:56 : ================================================== ==== 13:26:03 : ================================================== ==== 13:26:03 : ================================================== ==== 13:26:03 : eMMC Test Point Connection Module 13:26:03 : ================================================== ==== 13:26:03 : ================================================== ==== 13:26:03 : 13:26:03 : 1. DO NOT USE THE PHONE"S BATTERY 13:26:03 : 2. Connect the Soldered TP Connections to ATF Box 13:26:03 : 3. Disconnect the USB Cable and Wait until the 13:26:03 : the ATF Software will tell you to Connect the USB. 13:26:03 : 13:26:03 : 13:26:03 : Interface Reset OK! 13:26:03 : eMMC Access Type: SECTOR MODE 13:26:03 : eMMC Supported Voltage Range: 13:26:03 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:26:03 : 13:26:03 : CID : 1501004B3758564D30012400D00E8165 13:26:03 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:26:03 : 13:26:03 : eMMC Boot Information 13:26:03 : Revision 1.7 (for MMC v5.0, v5.01) 13:26:03 : BOOT PARTITION : NOT BOOT ENABLED 13:26:03 : PARTITION ACCESS : R/W USER PARTITION 13:26:03 : PERM_BOOT_CFG_PROT : DISABLED 13:26:03 : PWR_BOOT_CFG_PROT : DISABLED 13:26:03 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 13:26:03 : RESET BUS WIDTH : ENABLED 13:26:03 : eMMC FirmW UPDATE : DISABLED 13:26:03 : EMMC CACHE SIZE : 0 KB 13:26:03 : SUPER PAGE SIZE : 3072 KB 13:26:03 : HC ERASE GROUP SIZE: 512 KB 13:26:03 : USER AREA SIZE : 7818182656 BYTES 13:26:03 : BOOT PARTITION SIZE: 4096 KB 13:26:03 : RPMB PARTITION SIZE: 512 KB 13:26:03 : 13:26:03 : 13:26:03 : eMMC Device Information 13:26:03 : Manufacturer ID: SAMSUNG 13:26:03 : Device Type : Embedded BGA 13:26:03 : Application ID : 00 13:26:03 : Product Name : K7XVM0 13:26:03 : Product Rev : 0.1 13:26:03 : Product SN : 2400D00E 13:26:03 : Manufactured : January 1998 13:26:03 : 13:26:03 : Card Specific Data 13:26:03 : CSD_STRUCTURE : Extended 13:26:03 : SPEC_VERS : Version 4.1/4.2/4.3 13:26:03 : TAAC : 13 ns 13:26:03 : TRAN_SPEED : 4000000 KHz 13:26:03 : READ_BL_LEN : 512 Bytes 13:26:03 : C_SIZE : HIGH CAPACITY 13:26:03 : WP_GRP_ENABLE : YES 13:26:03 : WRITE_BL_LEN : 512 Bytes 13:26:03 : CONTENT_PROT_APP : NO 13:26:03 : PERM_WRITE_PROTECT: NO 13:26:03 : TMP_WRITE_PROTECT : NO 13:26:03 : 13:26:03 : Extended CSD Saved: 13:26:03 : 1501004B3758564D30012400D00E8165.ext_csd 13:26:03 : Backup Directory: 13:26:03 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:26:03 : 13:26:04 : 13:26:04 : Task Selected: Samsung Factory Format 13:26:04 : ================================================== ==== 13:26:04 : For eMMC Revision 1.5 (for MMC v4.41) and LOWER 13:26:04 : --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries 13:26:04 : For eMMC Revision 1.6 (for MMC v4.5) and HIGHER 13:26:04 : --> This will ONLY ERASE USER AREA 13:26:04 : ================================================== ==== 13:26:04 : This eMMC is: Revision 1.x (For MMC v4.x) 13:26:04 : 13:26:04 : Samsung Factory Format Start... 13:26:04 : Format Done! 13:26:04 : 13:26:04 : ================================================== ==== 13:26:04 : WARNING - WARNING - WARNING - WARNING - WARNING 13:26:04 : ================================================== ==== 13:26:04 : 1. WRITE Back EXT_CSD Backup if Needed 13:26:04 : 2. WRITE BOOT1 Image if Needed 13:26:04 : 3. WRITE BOOT2 Image if Needed 13:26:04 : 4. WRITE USER AREA Image if Needed 13:26:04 : ================================================== ==== 13:26:08 : ================================================== ==== 13:26:08 : ================================================== ==== 13:26:08 : eMMC Test Point Connection Module 13:26:08 : ================================================== ==== 13:26:08 : ================================================== ==== 13:26:08 : 13:26:08 : 1. DO NOT USE THE PHONE"S BATTERY 13:26:08 : 2. Connect the Soldered TP Connections to ATF Box 13:26:08 : 3. Disconnect the USB Cable and Wait until the 13:26:08 : the ATF Software will tell you to Connect the USB. 13:26:08 : 13:26:08 : 13:26:08 : Interface Reset OK! 13:26:08 : eMMC Access Type: SECTOR MODE 13:26:08 : eMMC Supported Voltage Range: 13:26:08 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:26:08 : 13:26:08 : CID : 1501004B3758564D30012400D00E8165 13:26:08 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:26:08 : 13:26:08 : eMMC Boot Information 13:26:08 : Revision 1.7 (for MMC v5.0, v5.01) 13:26:08 : BOOT PARTITION : NOT BOOT ENABLED 13:26:08 : PARTITION ACCESS : R/W USER PARTITION 13:26:08 : PERM_BOOT_CFG_PROT : DISABLED 13:26:08 : PWR_BOOT_CFG_PROT : DISABLED 13:26:08 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 13:26:08 : RESET BUS WIDTH : ENABLED 13:26:08 : eMMC FirmW UPDATE : DISABLED 13:26:08 : EMMC CACHE SIZE : 0 KB 13:26:08 : SUPER PAGE SIZE : 3072 KB 13:26:08 : HC ERASE GROUP SIZE: 512 KB 13:26:08 : USER AREA SIZE : 7818182656 BYTES 13:26:08 : BOOT PARTITION SIZE: 4096 KB 13:26:08 : RPMB PARTITION SIZE: 512 KB 13:26:08 : 13:26:08 : 13:26:08 : eMMC Device Information 13:26:08 : Manufacturer ID: SAMSUNG 13:26:08 : Device Type : Embedded BGA 13:26:08 : Application ID : 00 13:26:08 : Product Name : K7XVM0 13:26:08 : Product Rev : 0.1 13:26:08 : Product SN : 2400D00E 13:26:08 : Manufactured : January 1998 13:26:08 : 13:26:08 : Card Specific Data 13:26:08 : CSD_STRUCTURE : Extended 13:26:08 : SPEC_VERS : Version 4.1/4.2/4.3 13:26:08 : TAAC : 13 ns 13:26:08 : TRAN_SPEED : 4000000 KHz 13:26:08 : READ_BL_LEN : 512 Bytes 13:26:08 : C_SIZE : HIGH CAPACITY 13:26:08 : WP_GRP_ENABLE : YES 13:26:08 : WRITE_BL_LEN : 512 Bytes 13:26:08 : CONTENT_PROT_APP : NO 13:26:08 : PERM_WRITE_PROTECT: NO 13:26:08 : TMP_WRITE_PROTECT : NO 13:26:08 : 13:26:08 : Extended CSD Saved: 13:26:08 : 1501004B3758564D30012400D00E8165.ext_csd 13:26:08 : Backup Directory: 13:26:08 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:26:08 : 13:26:13 : ================================================== ==== 13:26:13 : ================================================== ==== 13:26:13 : eMMC Test Point Connection Module 13:26:13 : ================================================== ==== 13:26:13 : ================================================== ==== 13:26:13 : 13:26:13 : 1. DO NOT USE THE PHONE"S BATTERY 13:26:13 : 2. Connect the Soldered TP Connections to ATF Box 13:26:13 : 3. Disconnect the USB Cable and Wait until the 13:26:13 : the ATF Software will tell you to Connect the USB. 13:26:13 : 13:26:13 : 13:26:13 : Interface Reset OK! 13:26:13 : eMMC Access Type: SECTOR MODE 13:26:13 : eMMC Supported Voltage Range: 13:26:13 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 13:26:13 : 13:26:13 : CID : 1501004B3758564D30012400D00E8165 13:26:13 : CSD : D02701320F5903FFF6DBFFEF8E40400D 13:26:13 : 13:26:13 : eMMC Boot Information 13:26:13 : Revision 1.7 (for MMC v5.0, v5.01) 13:26:13 : BOOT PARTITION : NOT BOOT ENABLED 13:26:13 : PARTITION ACCESS : R/W USER PARTITION 13:26:13 : PERM_BOOT_CFG_PROT : DISABLED 13:26:13 : PWR_BOOT_CFG_PROT : DISABLED 13:26:13 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 13:26:13 : RESET BUS WIDTH : ENABLED 13:26:13 : eMMC FirmW UPDATE : DISABLED 13:26:13 : EMMC CACHE SIZE : 0 KB 13:26:13 : SUPER PAGE SIZE : 3072 KB 13:26:13 : HC ERASE GROUP SIZE: 512 KB 13:26:13 : USER AREA SIZE : 7818182656 BYTES 13:26:13 : BOOT PARTITION SIZE: 4096 KB 13:26:13 : RPMB PARTITION SIZE: 512 KB 13:26:13 : 13:26:13 : 13:26:13 : eMMC Device Information 13:26:13 : Manufacturer ID: SAMSUNG 13:26:13 : Device Type : Embedded BGA 13:26:13 : Application ID : 00 13:26:13 : Product Name : K7XVM0 13:26:13 : Product Rev : 0.1 13:26:13 : Product SN : 2400D00E 13:26:13 : Manufactured : January 1998 13:26:13 : 13:26:13 : Card Specific Data 13:26:13 : CSD_STRUCTURE : Extended 13:26:13 : SPEC_VERS : Version 4.1/4.2/4.3 13:26:13 : TAAC : 13 ns 13:26:13 : TRAN_SPEED : 4000000 KHz 13:26:13 : READ_BL_LEN : 512 Bytes 13:26:13 : C_SIZE : HIGH CAPACITY 13:26:13 : WP_GRP_ENABLE : YES 13:26:13 : WRITE_BL_LEN : 512 Bytes 13:26:13 : CONTENT_PROT_APP : NO 13:26:13 : PERM_WRITE_PROTECT: NO 13:26:13 : TMP_WRITE_PROTECT : NO 13:26:13 : 13:26:13 : Extended CSD Saved: 13:26:13 : 1501004B3758564D30012400D00E8165.ext_csd 13:26:13 : Backup Directory: 13:26:13 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 13:26:13 : 13:26:26 : 13:26:26 : Task Selected: Write EXT_CSD Backup 13:26:26 : Task Done! |
