06-06-2016, 16:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Samsung I9300 EMMC NAME Toshiba 016G92 repair possible set now working condition only IMEI 004499.XXXX try to repair , write crt ..ext but still same |
06-07-2016, 05:51 | #2 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Do you try to take a picture with camere and make a factory reset ( or erase via recovery ) and after this to check - is there still picture exist or not? If this test to record / erase some data to internal memory ( in fact a part from your eMMC inside phone ) show that R/W is OK, then mostly seem You need to try to rewrite EFS ( reset EFS ) and write a good certificate. In some case Checking of modem IC ( Infineon XG626 ) is highly recomended ... In fact IMEI data is stored on eMMC, but is depended of modem IC. I wish you success ... WBR, DebeliaMark, BG | |
