12-04-2014, 19:21 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Bd,Dhaka,GSM CLUB Age: 38
Member: 859030 Status: Offline Sonork: 100.1619336 Thanks Meter: 435 | Quote:
..:::GSM CLUB™:::.. | |
The Following User Says Thank You to ..:::GSM CLUB™:::.. For This Useful Post: |
12-05-2014, 03:18 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Repair this phone via SDC 4.4.4 here: ATF Offcial Support Area / file-support / Samsung SDC Files / GT-I9300I / GT-I9300I_4.4.4_16GB_I9300IXXUBNJ3.sdc This will give you download mode... So you can reflash your phone with correct 4.4.4 files. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-20-2015, 16:54 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: srilanka Age: 32
Member: 1674096 Status: Offline Thanks Meter: 49 | sd methoad 1) install the Win32DiskImager 2) download and extract the debrick.zip u will find a debrick.img 3) insert sd card (16 GB class 10) and format it 4) open Win32DiskImager 5) open img file and write to sd card 6) after complete remove sd card from pc and insert it into your neo 7) insert back the battery and press vol down + home + power button 8) u will get into download mode 9) now remove your sd card from mobile 10) open odin and add your firmware and flash it https://mega.nz/#!DVcSTA7R!0D0ah1pSa...6M2Ea0NmngPQX4 |
The Following 2 Users Say Thank You to alrsbs For This Useful Post: |
06-21-2016, 20:56 | #7 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | bboot secsess.but when remoove bootcard ,set goes dead flash done with sd card power on..but with out sd card no power..pkls tell me solution..iam flash ,4,4,4 multy firmware with pit... |
