08-13-2014, 17:56 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For boths, now not remember if this model is Qualcomm, (no need TP) or EXINOS platform, (Need TP), but you can create from yourself Sdc File for Unbrick, read my Guide here: http://forum.gsmhosting.com/vbb/f609...iting-1847536/ Br allumts |
08-13-2014, 18:27 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, The S3 Neo+ (GT-I9301I) has a Qualcomm Snapdragon 400 MSM8226 SoC. Should be supported by SDC if SDC is made properly. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
08-15-2014, 15:29 | #7 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, some new version SDC files + I9301I_8GB file added today: http://forum.gsmhosting.com/vbb/10497710-post4.html BR |
02-18-2015, 10:08 | #9 (permalink) |
Major Poster Join Date: Aug 2005 Age: 45
Member: 174181 Status: Offline Thanks Meter: 21 | Hi, I have i9301i dead boot. PC detect him Zeus flash device. Whith ATF sdc put in download mode, flash whith service firmware (4 files), but after flash phone stay in zeus device. Whith sdcard I can put phone in download mode an enter in the stock recovery. Can you hellp me, thanks! |
02-18-2015, 10:30 | #10 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
02-18-2015, 16:59 | #12 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Try flashing only BL + PIT of same version of SD Card after enter in D.Mode and take out Sd Card if have this: Quote:
BR | |
02-19-2015, 08:56 | #13 (permalink) | |
Member: 174181 Status: Offline Thanks Meter: 21 | Quote:
Log from ATF eMMC Tool: Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003031364745320461A5E6E3 CSD : D05E00320F5903FFFFFFFFEF924000D3 eMMC Boot Information Revision 1.x (For MMC v4.x) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 016GE2 Product Rev : 0.4 Product SN : 61A5E6E3 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 800 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO why BOOT PARTITION : NOT BOOT ENABLED ? | |
02-19-2015, 10:05 | #14 (permalink) |
Member: 174181 Status: Offline Thanks Meter: 21 | ALL done! whith atf eMMC TOOL : Normal factory erase, Samsung factory format,write ext_cds file. Then write 4 files firmware, phone power on but without imei and efs. Root, restore efs from one backup, write cert whith other imei ATF you help me, but I use pinout from z3x-jtag for eMMC. Thanks |
