08-05-2014, 12:16 | #152 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
here the official adapter ATF-V2 All in 1 Ultimate Adaptor For ATF BIG BOX/Nitro/Lighting | |
08-15-2014, 11:14 | #153 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Circuitcorner
Member: 551599 Status: Offline Thanks Meter: 139 | hi is it possible note 2 emmc 16gb to 32gb? i dont have 16gb emmc available but i have emmc form s3 korea 32gb im planning to transfer it those it work without problem? |
The Following User Says Thank You to kidgz For This Useful Post: |
08-25-2014, 08:30 | #155 (permalink) |
Freak Poster Join Date: Jun 2009 Location: turkey/mersın
Member: 1064138 Status: Offline Thanks Meter: 13 | n7100 produck name empty 2cy07fb.jpg - directupload.net yuzde 1 mılyon okey . |
09-05-2014, 08:21 | #156 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | Hi when i do all i cant flash with odin always error repartition failed so i need to know if i must flash boot 2 also because in your pictures is only user area and boot 1. b.r |
09-05-2014, 19:36 | #158 (permalink) |
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | |
09-06-2014, 10:16 | #160 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
09-09-2014, 20:35 | #162 (permalink) | |
Open you thread if you are Atf User and explain you problem. Br | |
09-22-2014, 13:49 | #163 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | hi i am using atf v2 all in 1 adapter and try to connect with s3 board but its not connecting at all,i have even tried with a working board and seems to like problem with adapter. I have connected (vcc 2.8 and VCCQ 1.8 as well but still no response from the chip. All connections are 100% ok... Is there any special way to connect with this special adapter. help will be appreciated. Thanks |
09-22-2014, 14:47 | #164 (permalink) | |
You can Connect VCCQ & VCC 3.3V Switch must be " ON " mode In software select Spped 15mhz and Vccio 3.3V Than try Scan Device . make sure Do not connect any usb or power to Phone PCB | |
09-22-2014, 15:08 | #165 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | no luck..still same problem, now i am getting this 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
