10-13-2014, 22:52 | #167 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Poland
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | Hi, i have problem with my i9300: SAMSUNG LOGO BLINK OR RESTART Download mode working BUT! Cannot flash, error Fullflash, boot and Repair efs cannot write with ODIN. At the beginning phone lost imei (NULL NULL) i write EFS with Z3x and ODIN and nothing, problem the same. After another loooong try phone is dead, logo blink and restart. I have a question. Where do I solder the wires in my mod adapter 5in1 gpg for VCC and VCCQ? |
11-10-2014, 10:50 | #170 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
What answer you want if have Full scheme, fill procedure itc... and not post nothingh of screen of which error show... BR | |
11-10-2014, 11:17 | #171 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @rudy178, This error isn't Bricked phone for repair via eMMc direct: Quote:
If you try in Workinkg device (not totaly Bricked), is possible you damage this and no Repair, Boot is working when there's this issue, carefully when play with eMMc, most user now are exchanging eMMc repair with Samsung Boxex or Odin Issues. BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
11-18-2014, 11:16 | #173 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Isha.786, No Hijack on other user thread, more this isn't Z3X section, use search button BR |
11-20-2014, 10:42 | #174 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Indonesia Raya
Member: 636569 Status: Offline Thanks Meter: 192 | samsung note 2 n7100 succes repair and format emmc but no live...help What is wrong steps? I just follow step http://forum.gsmhosting.com/vbb/f609...epair-1785442/ |
The Following User Says Thank You to lages_79 For This Useful Post: |
11-20-2014, 10:49 | #175 (permalink) | |
BR | |
11-20-2014, 13:33 | #177 (permalink) |
Member: 636569 Status: Offline Thanks Meter: 192 | here is log ================================================== ==== 17:36:49 : ================================================== ==== 17:36:49 : eMMC Test Point Connection Module 17:36:49 : ================================================== ==== 17:36:49 : ================================================== ==== 17:36:49 : 17:36:49 : 1. DO NOT USE THE PHONE"S BATTERY 17:36:49 : 2. Connect the Soldered TP Connections to ATF Box 17:36:49 : 3. Disconnect the USB Cable and Wait until the 17:36:49 : the ATF Software will tell you to Connect the USB. 17:36:49 : 17:36:49 : 17:36:49 : Interface Reset OK! 17:36:49 : eMMC Access Type: SECTOR MODE 17:36:49 : eMMC Supported Voltage Range: 17:36:49 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 17:36:49 : 17:36:49 : CID : 15010056545530304DF789AA6A80 17:36:49 : CSD : D02701320F5903FFF6DBFFFF8E40406D 17:36:49 : 17:36:49 : eMMC Boot Information 17:36:49 : Revision 1.6 (for MMC v4.5) 17:36:49 : BOOT PARTITION : BOOT PARTITION 1 17:36:49 : PARTITION ACCESS : R/W USER PARTITION 17:36:49 : PERM_BOOT_CFG_PROT : DISABLED 17:36:49 : PWR_BOOT_CFG_PROT : DISABLED 17:36:49 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 17:36:49 : RESET BUS WIDTH : ENABLED 17:36:49 : eMMC FirmW UPDATE : DISABLED 17:36:49 : EMMC CACHE SIZE : 0 KB 17:36:49 : SUPER PAGE SIZE : 3584 KB 17:36:49 : HC ERASE GROUP SIZE: 512 KB 17:36:49 : USER AREA SIZE : 15758000128 BYTES 17:36:49 : BOOT PARTITION SIZE: 2048 KB 17:36:49 : RPMB PARTITION SIZE: 128 KB 17:36:49 : 17:36:49 : 17:36:49 : eMMC Device Information 17:36:49 : Manufacturer ID: SAMSUNG 17:36:49 : Device Type : Embedded BGA 17:36:49 : Application ID : 00 17:36:49 : Product Name : VTU00M 17:36:49 : Product Rev : 15.7 17:36:49 : Product SN : 89AA6A80 17:36:49 : Manufactured : April 1997 17:36:49 : 17:36:49 : Card Specific Data 17:36:49 : CSD_STRUCTURE : Extended 17:36:49 : SPEC_VERS : Version 4.1/4.2/4.3 17:36:49 : TAAC : 13 ns 17:36:49 : TRANS_SPEED : 4000000 KHz 17:36:49 : READ_BL_LEN : 512 Bytes 17:36:49 : C_SIZE : HIGH CAPACITY 17:36:49 : WP_GRP_ENABLE : YES 17:36:49 : WRITE_BL_LEN : 512 Bytes 17:36:49 : CONTENT_PROT_APP : NO 17:36:49 : PERM_WRITE_PROTECT: NO 17:36:49 : TMP_WRITE_PROTECT : NO 17:36:49 : 17:36:49 : Extended CSD Saved: 17:36:49 : 15010056545530304DF789AA6A80_E566FDCF.ext_csd 17:36:49 : Backup Directory: 17:36:49 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 17:36:49 : 17:36:51 : 17:36:51 : Task Selected: Normal Factory Erase 17:36:51 : ================================================== ==== 17:36:51 : For eMMC Revision 1.2 (for MMC v4.2) and LOWER 17:36:51 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 17:36:51 : For eMMC Revision 1.3 (for MMC v4.3) and HIGHER 17:36:51 : --> This will ONLY ERASE USER AREA 17:36:51 : ================================================== ==== 17:36:51 : This eMMC is: Revision 1.6 (for MMC v4.5) 17:36:51 : 17:36:51 : Factory Erasing Supported FLASH AREA... 17:36:51 : Normal Factory Erase Done! 17:36:51 : 17:36:51 : ================================================== ==== 17:36:51 : WARNING - WARNING - WARNING - WARNING - WARNING 17:36:52 : ================================================== ==== 17:36:52 : 1. WRITE BOOT1 Image if Needed 17:36:52 : 2. WRITE BOOT2 Image if Needed 17:36:52 : 3. WRITE USER AREA Image if Needed 17:36:52 : ================================================== ==== 17:36:53 : ================================================== ==== 17:36:53 : ================================================== ==== 17:36:53 : eMMC Test Point Connection Module 17:36:53 : ================================================== ==== 17:36:53 : ================================================== ==== 17:36:53 : 17:36:53 : 1. DO NOT USE THE PHONE"S BATTERY 17:36:53 : 2. Connect the Soldered TP Connections to ATF Box 17:36:53 : 3. Disconnect the USB Cable and Wait until the 17:36:53 : the ATF Software will tell you to Connect the USB. 17:36:53 : 17:36:53 : 17:36:53 : Interface Reset OK! 17:36:53 : eMMC Access Type: SECTOR MODE 17:36:53 : eMMC Supported Voltage Range: 17:36:53 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 17:36:53 : 17:36:53 : CID : 15010056545530304DF789AA6A80 17:36:53 : CSD : D02701320F5903FFF6DBFFFF8E40406D 17:36:53 : 17:36:53 : eMMC Boot Information 17:36:53 : Revision 1.6 (for MMC v4.5) 17:36:53 : BOOT PARTITION : BOOT PARTITION 1 17:36:54 : PARTITION ACCESS : R/W USER PARTITION 17:36:54 : PERM_BOOT_CFG_PROT : DISABLED 17:36:54 : PWR_BOOT_CFG_PROT : DISABLED 17:36:54 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 17:36:54 : RESET BUS WIDTH : ENABLED 17:36:54 : eMMC FirmW UPDATE : DISABLED 17:36:54 : EMMC CACHE SIZE : 0 KB 17:36:54 : SUPER PAGE SIZE : 3584 KB 17:36:54 : HC ERASE GROUP SIZE: 512 KB 17:36:54 : USER AREA SIZE : 15758000128 BYTES 17:36:54 : BOOT PARTITION SIZE: 2048 KB 17:36:54 : RPMB PARTITION SIZE: 128 KB 17:36:54 : 17:36:54 : 17:36:54 : eMMC Device Information 17:36:54 : Manufacturer ID: SAMSUNG 17:36:54 : Device Type : Embedded BGA 17:36:54 : Application ID : 00 17:36:54 : Product Name : VTU00M 17:36:54 : Product Rev : 15.7 17:36:54 : Product SN : 89AA6A80 17:36:54 : Manufactured : April 1997 17:36:54 : 17:36:54 : Card Specific Data 17:36:54 : CSD_STRUCTURE : Extended 17:36:54 : SPEC_VERS : Version 4.1/4.2/4.3 17:36:54 : TAAC : 13 ns 17:36:54 : TRANS_SPEED : 4000000 KHz 17:36:54 : READ_BL_LEN : 512 Bytes 17:36:54 : C_SIZE : HIGH CAPACITY 17:36:54 : WP_GRP_ENABLE : YES 17:36:54 : WRITE_BL_LEN : 512 Bytes 17:36:54 : CONTENT_PROT_APP : NO 17:36:54 : PERM_WRITE_PROTECT: NO 17:36:54 : TMP_WRITE_PROTECT : NO 17:36:54 : 17:36:54 : Extended CSD Saved: 17:36:54 : 15010056545530304DF789AA6A80_D4DA9374.ext_csd 17:36:54 : Backup Directory: 17:36:54 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 17:36:54 : 17:36:59 : ================================================== ==== 17:36:59 : ================================================== ==== 17:36:59 : eMMC Test Point Connection Module 17:36:59 : ================================================== ==== 17:36:59 : ================================================== ==== 17:36:59 : 17:36:59 : 1. DO NOT USE THE PHONE"S BATTERY 17:36:59 : 2. Connect the Soldered TP Connections to ATF Box 17:36:59 : 3. Disconnect the USB Cable and Wait until the 17:36:59 : the ATF Software will tell you to Connect the USB. 17:36:59 : 17:36:59 : 17:36:59 : Interface Reset OK! 17:36:59 : eMMC Access Type: SECTOR MODE 17:36:59 : eMMC Supported Voltage Range: 17:36:59 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 17:36:59 : 17:36:59 : CID : 15010056545530304DF789AA6A80 17:36:59 : CSD : D02701320F5903FFF6DBFFFF8E40406D 17:36:59 : 17:36:59 : eMMC Boot Information 17:37:00 : Revision 1.6 (for MMC v4.5) 17:37:00 : BOOT PARTITION : BOOT PARTITION 1 17:37:00 : PARTITION ACCESS : R/W USER PARTITION 17:37:00 : PERM_BOOT_CFG_PROT : DISABLED 17:37:00 : PWR_BOOT_CFG_PROT : DISABLED 17:37:00 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 17:37:00 : RESET BUS WIDTH : ENABLED 17:37:00 : eMMC FirmW UPDATE : DISABLED 17:37:00 : EMMC CACHE SIZE : 0 KB 17:37:00 : SUPER PAGE SIZE : 3584 KB 17:37:00 : HC ERASE GROUP SIZE: 512 KB 17:37:00 : USER AREA SIZE : 15758000128 BYTES 17:37:00 : BOOT PARTITION SIZE: 2048 KB 17:37:00 : RPMB PARTITION SIZE: 128 KB 17:37:00 : 17:37:00 : 17:37:00 : eMMC Device Information 17:37:00 : Manufacturer ID: SAMSUNG 17:37:00 : Device Type : Embedded BGA 17:37:00 : Application ID : 00 17:37:00 : Product Name : VTU00M 17:37:00 : Product Rev : 15.7 17:37:00 : Product SN : 89AA6A80 17:37:00 : Manufactured : April 1997 17:37:00 : 17:37:00 : Card Specific Data 17:37:00 : CSD_STRUCTURE : Extended 17:37:00 : SPEC_VERS : Version 4.1/4.2/4.3 17:37:00 : TAAC : 13 ns 17:37:00 : TRANS_SPEED : 4000000 KHz 17:37:00 : READ_BL_LEN : 512 Bytes 17:37:00 : C_SIZE : HIGH CAPACITY 17:37:00 : WP_GRP_ENABLE : YES 17:37:00 : WRITE_BL_LEN : 512 Bytes 17:37:00 : CONTENT_PROT_APP : NO 17:37:00 : PERM_WRITE_PROTECT: NO 17:37:00 : TMP_WRITE_PROTECT : NO 17:37:00 : 17:37:00 : Extended CSD Saved: 17:37:00 : 15010056545530304DF789AA6A80_3AE17E6D.ext_csd 17:37:00 : Backup Directory: 17:37:00 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 17:37:00 : 17:37:01 : 17:37:01 : Task Selected: Samsung Factory Format 17:37:01 : ================================================== ==== 17:37:01 : For eMMC Revision 1.5 (for MMC v4.41) and LOWER 17:37:01 : --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries 17:37:01 : For eMMC Revision 1.6 (for MMC v4.5) and HIGHER 17:37:01 : --> This will ONLY ERASE USER AREA 17:37:01 : ================================================== ==== 17:37:01 : This eMMC is: Revision 1.6 (for MMC v4.5) 17:37:01 : 17:37:01 : Samsung Factory Format Start... 17:37:02 : Format Done! 17:37:02 : 17:37:02 : ================================================== ==== 17:37:02 : WARNING - WARNING - WARNING - WARNING - WARNING 17:37:02 : ================================================== ==== 17:37:02 : 1. WRITE Back EXT_CSD Backup if Needed 17:37:02 : 2. WRITE BOOT1 Image if Needed 17:37:02 : 3. WRITE BOOT2 Image if Needed 17:37:02 : 4. WRITE USER AREA Image if Needed 17:37:02 : ================================================== ==== 17:37:11 : ================================================== ==== 17:37:11 : ================================================== ==== 17:37:11 : eMMC Test Point Connection Module 17:37:11 : ================================================== ==== 17:37:11 : ================================================== ==== 17:37:11 : 17:37:11 : 1. DO NOT USE THE PHONE"S BATTERY 17:37:11 : 2. Connect the Soldered TP Connections to ATF Box 17:37:11 : 3. Disconnect the USB Cable and Wait until the 17:37:11 : the ATF Software will tell you to Connect the USB. 17:37:11 : 17:37:11 : 17:37:11 : Interface Reset OK! 17:37:11 : eMMC Access Type: SECTOR MODE 17:37:11 : eMMC Supported Voltage Range: 17:37:11 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 17:37:11 : 17:37:11 : CID : 15010056545530304DF789AA6A80 17:37:11 : CSD : D02701320F5903FFF6DBFFFF8E40406D 17:37:11 : 17:37:11 : eMMC Boot Information 17:37:11 : Revision 1.6 (for MMC v4.5) 17:37:11 : BOOT PARTITION : BOOT PARTITION 1 17:37:11 : PARTITION ACCESS : R/W USER PARTITION 17:37:11 : PERM_BOOT_CFG_PROT : DISABLED 17:37:11 : PWR_BOOT_CFG_PROT : DISABLED 17:37:11 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 17:37:11 : RESET BUS WIDTH : ENABLED 17:37:11 : eMMC FirmW UPDATE : DISABLED 17:37:11 : EMMC CACHE SIZE : 0 KB 17:37:11 : SUPER PAGE SIZE : 3584 KB 17:37:11 : HC ERASE GROUP SIZE: 512 KB 17:37:11 : USER AREA SIZE : 15758000128 BYTES 17:37:11 : BOOT PARTITION SIZE: 2048 KB 17:37:11 : RPMB PARTITION SIZE: 128 KB 17:37:11 : 17:37:11 : 17:37:11 : eMMC Device Information 17:37:11 : Manufacturer ID: SAMSUNG 17:37:11 : Device Type : Embedded BGA 17:37:11 : Application ID : 00 17:37:11 : Product Name : VTU00M 17:37:11 : Product Rev : 15.7 17:37:11 : Product SN : 89AA6A80 17:37:11 : Manufactured : April 1997 17:37:11 : 17:37:11 : Card Specific Data 17:37:11 : CSD_STRUCTURE : Extended 17:37:11 : SPEC_VERS : Version 4.1/4.2/4.3 17:37:11 : TAAC : 13 ns 17:37:11 : TRANS_SPEED : 4000000 KHz 17:37:11 : READ_BL_LEN : 512 Bytes 17:37:11 : C_SIZE : HIGH CAPACITY 17:37:11 : WP_GRP_ENABLE : YES 17:37:11 : WRITE_BL_LEN : 512 Bytes 17:37:11 : CONTENT_PROT_APP : NO 17:37:11 : PERM_WRITE_PROTECT: NO 17:37:11 : TMP_WRITE_PROTECT : NO 17:37:11 : 17:37:11 : Extended CSD Saved: 17:37:11 : 15010056545530304DF789AA6A80_A17ED324.ext_csd 17:37:11 : Backup Directory: 17:37:11 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 17:37:11 : 17:37:33 : 17:37:33 : Task Selected: Write EXT_CSD Backup 17:37:33 : Task Done! 17:37:33 : 17:37:44 : ================================================== ==== 17:37:44 : ================================================== ==== 17:37:44 : eMMC Test Point Connection Module 17:37:44 : ================================================== ==== 17:37:44 : ================================================== ==== 17:37:44 : 17:37:44 : 1. DO NOT USE THE PHONE"S BATTERY 17:37:44 : 2. Connect the Soldered TP Connections to ATF Box 17:37:44 : 3. Disconnect the USB Cable and Wait until the 17:37:44 : the ATF Software will tell you to Connect the USB. 17:37:44 : 17:37:44 : 17:37:44 : Interface Reset OK! 17:37:44 : eMMC Access Type: SECTOR MODE 17:37:44 : eMMC Supported Voltage Range: 17:37:44 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 17:37:44 : 17:37:44 : CID : 15010056545530304DF789AA6A80 17:37:44 : CSD : D02701320F5903FFF6DBFFFF8E40406D 17:37:44 : 17:37:44 : eMMC Boot Information 17:37:44 : Revision 1.6 (for MMC v4.5) 17:37:44 : BOOT PARTITION : BOOT PARTITION 1 17:37:44 : PARTITION ACCESS : R/W USER PARTITION 17:37:44 : PERM_BOOT_CFG_PROT : DISABLED 17:37:44 : PWR_BOOT_CFG_PROT : DISABLED 17:37:44 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 17:37:44 : RESET BUS WIDTH : ENABLED 17:37:44 : eMMC FirmW UPDATE : DISABLED 17:37:44 : EMMC CACHE SIZE : 0 KB 17:37:44 : SUPER PAGE SIZE : 3584 KB 17:37:44 : HC ERASE GROUP SIZE: 512 KB 17:37:44 : USER AREA SIZE : 15758000128 BYTES 17:37:44 : BOOT PARTITION SIZE: 2048 KB 17:37:44 : RPMB PARTITION SIZE: 128 KB 17:37:44 : 17:37:45 : 17:37:45 : eMMC Device Information 17:37:45 : Manufacturer ID: SAMSUNG 17:37:45 : Device Type : Embedded BGA 17:37:45 : Application ID : 00 17:37:45 : Product Name : VTU00M 17:37:45 : Product Rev : 15.7 17:37:45 : Product SN : 89AA6A80 17:37:45 : Manufactured : April 1997 17:37:45 : 17:37:45 : Card Specific Data 17:37:45 : CSD_STRUCTURE : Extended 17:37:45 : SPEC_VERS : Version 4.1/4.2/4.3 17:37:45 : TAAC : 13 ns 17:37:45 : TRANS_SPEED : 4000000 KHz 17:37:45 : READ_BL_LEN : 512 Bytes 17:37:45 : C_SIZE : HIGH CAPACITY 17:37:45 : WP_GRP_ENABLE : YES 17:37:45 : WRITE_BL_LEN : 512 Bytes 17:37:45 : CONTENT_PROT_APP : NO 17:37:45 : PERM_WRITE_PROTECT: NO 17:37:45 : TMP_WRITE_PROTECT : NO 17:37:45 : 17:37:45 : Extended CSD Saved: 17:37:45 : 15010056545530304DF789AA6A80_AA61BEA9.ext_csd 17:37:45 : Backup Directory: 17:37:45 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 17:37:45 : 17:39:00 : Start Writing 0x00200000 Blocks at 0x00000000 17:39:00 : Partition Selected: USER AREA 18:10:26 : 18:10:26 : Total Elapsed Time 00:31:29 18:10:26 : Write Success! 18:10:50 : Start Writing 0x00001000 Blocks at 0x00000000 18:10:50 : Partition Selected: BOOT 1 18:10:54 : 18:10:54 : Total Elapsed Time 00:00:04 18:10:54 : Write Success! 18:10:57 : ================================================== ==== 18:10:57 : ================================================== ==== 18:10:57 : eMMC Test Point Connection Module 18:10:57 : ================================================== ==== 18:10:57 : ================================================== ==== 18:10:57 : 18:10:57 : 1. DO NOT USE THE PHONE"S BATTERY 18:10:57 : 2. Connect the Soldered TP Connections to ATF Box 18:10:57 : 3. Disconnect the USB Cable and Wait until the 18:10:57 : the ATF Software will tell you to Connect the USB. 18:10:57 : 18:10:57 : 18:10:57 : Interface Reset OK! 18:10:57 : eMMC Access Type: SECTOR MODE 18:10:57 : eMMC Supported Voltage Range: 18:10:57 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 18:10:57 : 18:10:57 : CID : 15010056545530304DF789AA6A80 18:10:57 : CSD : D02701320F5903FFF6DBFFFF8E40406D 18:10:57 : 18:10:57 : eMMC Boot Information 18:10:57 : Revision 1.6 (for MMC v4.5) 18:10:57 : BOOT PARTITION : BOOT PARTITION 1 18:10:57 : PARTITION ACCESS : R/W USER PARTITION 18:10:57 : PERM_BOOT_CFG_PROT : DISABLED 18:10:57 : PWR_BOOT_CFG_PROT : DISABLED 18:10:57 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 18:10:57 : RESET BUS WIDTH : ENABLED 18:10:57 : eMMC FirmW UPDATE : DISABLED 18:10:57 : EMMC CACHE SIZE : 0 KB 18:10:57 : SUPER PAGE SIZE : 3584 KB 18:10:57 : HC ERASE GROUP SIZE: 512 KB 18:10:57 : USER AREA SIZE : 15758000128 BYTES 18:10:57 : BOOT PARTITION SIZE: 2048 KB 18:10:57 : RPMB PARTITION SIZE: 128 KB 18:10:57 : 18:10:57 : 18:10:57 : eMMC Device Information 18:10:57 : Manufacturer ID: SAMSUNG 18:10:57 : Device Type : Embedded BGA 18:10:57 : Application ID : 00 18:10:57 : Product Name : VTU00M 18:10:57 : Product Rev : 15.7 18:10:57 : Product SN : 89AA6A80 18:10:57 : Manufactured : April 1997 18:10:57 : 18:10:57 : Card Specific Data 18:10:57 : CSD_STRUCTURE : Extended 18:10:57 : SPEC_VERS : Version 4.1/4.2/4.3 18:10:57 : TAAC : 13 ns 18:10:57 : TRANS_SPEED : 4000000 KHz 18:10:57 : READ_BL_LEN : 512 Bytes 18:10:57 : C_SIZE : HIGH CAPACITY 18:10:57 : WP_GRP_ENABLE : YES 18:10:57 : WRITE_BL_LEN : 512 Bytes 18:10:57 : CONTENT_PROT_APP : NO 18:10:57 : PERM_WRITE_PROTECT: NO 18:10:57 : TMP_WRITE_PROTECT : NO 18:10:57 : 18:10:57 : Extended CSD Saved: 18:10:57 : 15010056545530304DF789AA6A80_098B5C9B.ext_csd 18:10:57 : Backup Directory: 18:10:57 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 18:10:57 : |
12-22-2014, 15:39 | #178 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: kalimatan selatan - indonesia
Member: 259306 Status: Offline Thanks Meter: 96 | Quote:
sir , i need file binary for samsung N7100 ..... i try look from here eMMC REPAIR FILES by Linus H. - 4shared but I did not find the file | |
12-25-2014, 11:12 | #180 (permalink) | |
Sir , plz help....i need files emmc repair ( BOOT1 , BOOT2 and USERDATA ) | |
