03-04-2015, 05:01 | #196 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Quote:
Please provide this for N8000 too,i badly need.i ve one dead during update from 4.0.4 to 4.4.2. . i dont know what happened,boot ,partition,or something else ? . Its already been discussed here. http://forum.gsmhosting.com/vbb/f609...n8000-1921507/ | |
03-07-2015, 16:34 | #197 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Have give you one page of help now if you not have understand too, try creating by yourself this SDC file, read the updates. BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
04-16-2015, 14:03 | #199 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @alexjuve42, what's you device?, this thread was for Exinos N7100 but I9300 is the same, (change file and pinout). So if you have I9300 or N7100 and want use this procedure just read any previoius page and can find aldo Diagram for Only BIG ATF from RJ45 cable.... or also with BIG ATF can use 4 in 1 adapter... BR allumts |
04-28-2015, 12:07 | #200 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
I do not have 4 in 1 cable I did a search on the forum, direct pinout connection can be established please help me B:R | |
04-30-2015, 19:39 | #201 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If have Big Atf you can use diagram that have posted many times in previous page... with small Atf must need of modific and bye bye warranty...but if you search in forum 4 in 1 adapter cable...not think you are good to modific w/o damage nitro/light atf.... If have nitro/light Atf must need of purchase this adapter 4 in 1...how search and find in the forum one adapter Loock in sticky thread and find Atf V2 4 in 1 adapter from SmartGsm Br allumts |
05-01-2015, 06:54 | #202 (permalink) | |
I think I need to buy.I get 4 in 1 cable Do I need to modify? Does atf light box B:R | |
06-06-2015, 21:58 | #205 (permalink) | |
If ha Adapter V2 no need any resistor just watch here for set right the switcher: http://forum.gsmhosting.com/vbb/f609...hting-1834819/ But excuseme Why you want use this OLD procedure with 80% of success?...use this other, (for N7100 is more easy becouse no need to desolder any component), wher connect one easy pol or what you can invent inside the EMMC w/o removing this...and Success is 100% also if EMMC is Totally Dead... Here Step by step procedure, change only Pinout that can take from first post of this thread, EMMC type are the same: repair-totally-dead-i9300-n7100-without-removing-emmc-pictures BR allumts | |
06-24-2015, 08:18 | #208 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1263464 Status: Offline Thanks Meter: 0 | Hi to all, i write from italy and i have an dead N7100. The story: One day no boot no battery charge and nothing other, only red light blink on the top pressing the power button. After search in the net i have try to change the emcc chip with fw buy on china but now the phone is still with red light blink only. I need help someone can tell me if is possible repair and how. TU all in advance. Bye. Doriano. |
06-24-2015, 10:33 | #209 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If have Atf Box say here wich type and read Exact emmc number in this...then use procedure With or Withouth remove EMMC chip with NAND#RE TP for Update Firmware and Factory erase... http://forum.gsmhosting.com/vbb/f609...m-n-o-1936304/ or http://forum.gsmhosting.com/vbb/f609...tures-1945278/ Also i think you have a Fake EMMC chip or you not are been good to replace and Update Fw only if emmc was New. If not have Atf Box not post more here, but goes in "General Samsung Section" BR allumts |
