03-04-2014, 05:21 | #32 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Very Nice explanation. 4 questions though: 1. After soldering the Resistors to the Adaptor to do this job, can we leave it this way for other ATF Nokia Jobs? 2. In What condition do we need to write Boot2 ? 3. Am I correct to say this will only work for eMMC 4.5 chips or Lower 4. After doing this repair process, do we need to Full Flash with 4-part files and Pit or Just single big PDA File ? |
03-04-2014, 06:46 | #35 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Hi, I have here n7100 no product name, i try to scan emmc but error. solder wire connection to board is okey. i used SmartGsm adapter here's the log: ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 |
03-04-2014, 09:41 | #39 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
U need extra power supply or use smart gsm 4 in 1 jig with modified no need to extra power supply. BR, Srinivas Reddy. | |
03-04-2014, 12:55 | #42 (permalink) |
Freak Poster Join Date: May 2012
Member: 1757924 Status: Offline Sonork: 100.1675762 Thanks Meter: 40 | Hi dear Can I change partitions sizes and a******* If I replace emmc with 8gb or 4gb can I partition with lower user area and/or cache blocks Also I guess some times efs problem come from emmc bad blocks can I change efs partition to another location |
The Following User Says Thank You to hakan 3 For This Useful Post: |
03-04-2014, 13:11 | #44 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Quote:
Pls check here or contact me:- http://forum.gsmhosting.com/vbb/f650...hones-1763482/ Regards s n hasan Mobile No\whatsup:-9815177706 | |
