06-28-2015, 11:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: indonesia
Member: 154427 Status: Offline Thanks Meter: 61 | Samsung P5100 dead with backup then i conect to atf direct emmc for read 512 rom.. after read done i try firmware update and succes then samsung factory format.. then i write my ext_csd backup then user area backup... now phone dont turn on... please help... here log boot scann emmc boot 6:51:45 : eMMC Test Point Connection Module 16:51:45 : ================================================== ==== 16:51:45 : ================================================== ==== 16:51:45 : 16:51:45 : 1. DO NOT USE THE PHONE"S BATTERY 16:51:45 : 2. Connect the Soldered TP Connections to ATF Box 16:51:45 : 3. Disconnect the USB Cable and Wait until the 16:51:45 : the ATF Software will tell you to Connect the USB. 16:51:45 : 16:51:45 : 16:51:45 : Interface Reset OK! 16:51:45 : eMMC Access Type: SECTOR MODE 16:51:45 : eMMC Supported Voltage Range: 16:51:45 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 16:51:45 : 16:51:45 : CID : 1501004D414732474104A8CB0EE770ED 16:51:45 : CSD : 902701320F5903FFF6DBFFEF8A404023 16:51:45 : 16:51:45 : eMMC Boot Information 16:51:45 : Revision 1.5 (for MMC v4.41) 16:51:45 : BOOT PARTITION : NOT BOOT ENABLED 16:51:45 : PARTITION ACCESS : R/W USER PARTITION 16:51:45 : PERM_BOOT_CFG_PROT : DISABLED 16:51:45 : PWR_BOOT_CFG_PROT : DISABLED 16:51:45 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 16:51:45 : RESET BUS WIDTH : ENABLED 16:51:45 : eMMC FirmW UPDATE : DISABLED 16:51:45 : EMMC CACHE SIZE : 0 KB 16:51:45 : SUPER PAGE SIZE : 4096 KB 16:51:45 : HC ERASE GROUP SIZE: 512 KB 16:51:45 : USER AREA SIZE : 17179869184 BYTES 16:51:45 : BOOT PARTITION SIZE: 512 KB 16:51:45 : RPMB PARTITION SIZE: 128 KB 16:51:45 : 16:51:45 : 16:51:45 : eMMC Device Information 16:51:45 : Manufacturer ID: SAMSUNG 16:51:45 : Device Type : Embedded BGA 16:51:45 : Application ID : 00 16:51:45 : Product Name : MAG2GA 16:51:45 : Product Rev : 0.4 16:51:45 : Product SN : A8CB0EE7 16:51:45 : Manufactured : July 1997 16:51:45 : 16:51:45 : Card Specific Data 16:51:45 : CSD_STRUCTURE : Version 1.2 16:51:45 : SPEC_VERS : Version 4.1/4.2/4.3 16:51:45 : TAAC : 13 ns 16:51:45 : TRAN_SPEED : 4000000 KHz 16:51:45 : READ_BL_LEN : 512 Bytes 16:51:45 : C_SIZE : HIGH CAPACITY 16:51:45 : WP_GRP_ENABLE : YES 16:51:45 : WRITE_BL_LEN : 512 Bytes 16:51:45 : CONTENT_PROT_APP : NO 16:51:45 : PERM_WRITE_PROTECT: NO 16:51:45 : TMP_WRITE_PROTECT : NO 16:51:45 : 16:51:45 : Extended CSD Saved: 16:51:45 : 1501004D414732474104A8CB0EE770ED.ext_csd 16:51:45 : Backup Directory: 16:51:45 : F:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 16:51:45 : |
06-30-2015, 06:52 | #5 (permalink) |
Member: 154427 Status: Offline Thanks Meter: 61 | @Advance-Box as i know p5100 don have boot partition.like p3100.. file from abo anas zayan its from another tool.. i write still dead..and boot config still BOOT PARTITION : NOT BOOT ENABLED |
