07-24-2014, 21:21 | #303 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | I have files from another box in bin format but do not know if it will work on the ATF, we expect the staff to speak for we know happens to work. If the answer is yes, I attached the files ok. |
The Following User Says Thank You to toninhosantos For This Useful Post: |
07-24-2014, 21:36 | #304 (permalink) | |
Junior Member Join Date: May 2012
Member: 1758984 Status: Offline Thanks Meter: 0 | Quote:
okay lets i try thats files.if not work its not bigdeal..will better try it.so we know thats work for atf or not.if that file makes my device death,its no problem for me.thank for you help. | |
08-04-2014, 19:32 | #307 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | hi, Ready only 4.3 Vers. but it's very Easy create you Sdc file more high version like 4.4.2, just go in CRATE IMMAGE tabulate in Atf Sw and insert only BL, (Bootloader) and CP, (Modem) + PIT file.... press create with Sd card in reader and have you 4.4.2 N900w8 sdc file... Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
08-05-2014, 05:41 | #309 (permalink) | |
Junior Member Join Date: Jun 2014
Member: 2210492 Status: Offline Thanks Meter: 0 | Quote:
08-05-2014, 07:24 | #310 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
sm-n900w8_4.3.sdc Br allumts | |
08-05-2014, 07:30 | #311 (permalink) | |
All .Bin file are working with Atf Box how are working with any Jtag Box, so is possible use also these file Boot1, Boot2 itc... in .bin format Br allumts | |
08-05-2014, 08:24 | #312 (permalink) |
Member: 2210492 Status: Offline Thanks Meter: 0 | Card CID: 1D4144534420202010B394236700C743 Card CSD: 400E00325B590000EF0D7F800A400019 Card SCR: 0235800000000000 Card OCR: 00C0FF8000 SD Card Size : 32085377024 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SHV-E330K UNBRICK Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Press Volume Down + Home + Power Button 4. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:01:27 Write Success! Create SDC ok ...but not display boot download, help please....testpoin ?? |
08-05-2014, 10:02 | #313 (permalink) | |
Now, not you think that just make one Sd Card + TP and you phone just go in D.Mode, no it not work in this mode. 1) Loock good this Thread for Unbrick I9300/N7100, is same CPU EXINOS platform, with eMMc direct Jtag, Here: http://forum.gsmhosting.com/vbb/10135977-post1.html 2) I havent restored one I9300 also with eMMc Direct JTAG becouse eMMc was damaged, 3) If you want to try only with Sd card + TP, make request for CMD point (TP point), in right thread posting CLEAR Pic. of you Device in HD, where show you open PCB boths side and try with this procedure, 4) Remember that Sdc File must be same GB of you Memory device and SDC file that want create must be same version of FW that device had wrote first of Unbrick, Br allumts | |
08-07-2014, 11:37 | #315 (permalink) | |
Br allumts | |
