02-15-2016, 07:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Samsung SM-J700F/H/K/M/P/8 BOOT Repair via eMMC Flashing Download NEWEST Flash File which have your Language Pack Inside from S-A-M-M-O-B-I-L-E.com or other sites... STEP 2: Solder eMMC Connections to Phone PCB: (Thanks to Chand Gee for Finding the Pinouts) STEP 3: Use ATF Software 12.66 or Higher... Select eMMC Tool Tab from ATF Plus. Follow the Steps illustrated in the Screenshots Below: STEP 4: De-Solder/Remove eMMC Connections on the PCB and Flash Phone via ODIN using the same flash file which you used on Step 3. STEP 5: Done. *** REMEMBER ONE IMPORTANT THING *** The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files. Last edited by ..::Angel::..; 08-23-2017 at 15:29. Reason: fixed broken links by mtk6572s4clone |
The Following 72 Users Say Thank You to Advance-Box For This Useful Post: |
02-15-2016, 08:33 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Very Good update .My request to ATF Team plz come in SAMSUNG market Because Nokia market is very slow So if its possible then come in SAMSUNG with complete solutions like Unlocking flashing and Jtag or emmc with new SAMSUNG box.Because this update proves that no one Like ATF team. |
The Following 11 Users Say Thank You to asad_nomy7 For This Useful Post: |
02-15-2016, 08:56 | #3 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | good update..please add win 8 direct unlock ..were ready to pay for the activation since service is down now for most servers |
The Following 4 Users Say Thank You to bigjef1 For This Useful Post: |
02-15-2016, 09:31 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Delhi
Member: 138575 Status: Offline Thanks Meter: 58 | @Advance box Sir, If I already have Only the BL file, can Only that file be selected? Thanks in Advance, BR jackle123 |
The Following User Says Thank You to jackle123 For This Useful Post: |
02-15-2016, 09:46 | #7 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | atf works 50% with bootrepair and easy jtag always work 100% some handset wich are not connect with atf done with easy jtag easily i have both activated but i dont know why atf fails in 50% handsets |
The Following User Says Thank You to sunil1670 For This Useful Post: |
02-15-2016, 10:07 | #9 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | thanks sir but why you diidnt choose boot img and after phone on only flash with one packge firmware pda or flashing with full firmware+pit and this method works on older phone also like n7100-i9300-n8000 flashing with sboot bin, cm bin or only for new phone with 5.1.1 version,thanks again and keep it up.... |
02-15-2016, 10:38 | #10 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
http://forum.gsmhosting.com/vbb/f609...users-2052397/ NOT import and Not paragon or naming Other Box/tool here, if not are satisfaction of Atf Box, please NOT use and NOT post nothing about Others Teams. | |
The Following 6 Users Say Thank You to allumts For This Useful Post: |
02-15-2016, 11:01 | #11 (permalink) |
No Life Poster Join Date: Jul 2013 Location: tamilnadu.kumbakonam
Member: 1971123 Status: Offline Sonork: 100.1661727 Thanks Meter: 555 | atf team help this samsung s7562 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106230E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A5330304103224272DA702D Flash Description: Samsung JJS00A, 3.64 GiB, SN 224272DA, Jul 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91459 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! |
The Following 5 Users Say Thank You to bis.kadhar For This Useful Post: |
02-15-2016, 11:29 | #12 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2064519 Status: Offline Thanks Meter: 83 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330080D99B8CA2BD CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 80D99B8C Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330080D99B8CA2BD.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:04 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:04 Write Success! Total Images Written: 2 Process Done! thanks and work 100% |
The Following 8 Users Say Thank You to Diamond Gsm For This Useful Post: |
02-15-2016, 11:38 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, if you don't want to download complete firmware... Here BL / Bootloader file for SM-J700F, recent version: https://mega.nz/#!URJVARKA!ODPoWPhrv...syqWmHs2--d21I SM-J700F successfully repaired: Code: 21:47:33 : ====================================================== 21:47:33 : eMMC Test Point Connection Module 21:47:33 : ====================================================== 21:47:33 : ====================================================== 21:47:33 : 21:47:33 : 1. DO NOT USE THE PHONE"S BATTERY 21:47:33 : 2. Connect the Soldered TP Connections to ATF Box 21:47:33 : 3. Disconnect the USB Cable and Wait until the 21:47:33 : the ATF Software will tell you to Connect the USB. 21:47:33 : 21:47:33 : 21:47:33 : Interface Reset OK! 21:47:33 : eMMC Access Type: SECTOR MODE 21:47:33 : eMMC Supported Voltage Range: 21:47:33 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 21:47:33 : 21:47:33 : CID : 11010034303030373300C4EB3D26A2C3 21:47:33 : CSD : D07E00320F5903FFFFFFFFE78A4000D1 21:47:33 : 21:47:33 : eMMC Boot Information 21:47:33 : Revision 1.7 (for MMC v5.0, v5.01) 21:47:33 : BOOT PARTITION : BOOT PARTITION 1 21:47:33 : PARTITION ACCESS : R/W USER PARTITION 21:47:33 : PERM_BOOT_CFG_PROT : DISABLED 21:47:33 : PWR_BOOT_CFG_PROT : DISABLED 21:47:33 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 21:47:33 : RESET BUS WIDTH : ENABLED 21:47:33 : eMMC FirmW UPDATE : DISABLED 21:47:33 : EMMC CACHE SIZE : 0 KB 21:47:33 : SUPER PAGE SIZE : 4096 KB 21:47:33 : HC ERASE GROUP SIZE: 4096 KB 21:47:33 : USER AREA SIZE : 15758000128 BYTES 21:47:33 : BOOT PARTITION SIZE: 4096 KB 21:47:33 : RPMB PARTITION SIZE: 4096 KB 21:47:33 : 21:47:33 : 21:47:33 : eMMC Device Information 21:47:33 : Manufacturer ID: TOSHIBA 21:47:33 : Device Type : Embedded BGA 21:47:33 : Application ID : 00 21:47:33 : Product Name : 400073 21:47:33 : Product Rev : 0.0 21:47:33 : Product SN : C4EB3D26 21:47:33 : Manufactured : January 1999 21:47:33 : 21:47:33 : Card Specific Data 21:47:33 : CSD_STRUCTURE : Extended 21:47:33 : SPEC_VERS : Version 4.1/4.2/4.3 21:47:33 : TAAC : 8000 ns 21:47:33 : TRAN_SPEED : 4000000 KHz 21:47:33 : READ_BL_LEN : 512 Bytes 21:47:33 : C_SIZE : HIGH CAPACITY 21:47:33 : WP_GRP_ENABLE : YES 21:47:33 : WRITE_BL_LEN : 512 Bytes 21:47:33 : CONTENT_PROT_APP : NO 21:47:33 : PERM_WRITE_PROTECT: NO 21:47:33 : TMP_WRITE_PROTECT : NO 21:47:33 : 21:47:33 : Extended CSD Saved: 21:47:33 : 11010034303030373300C4EB3D26A2C3.ext_csd 21:47:33 : Backup Directory: 21:47:33 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 21:47:33 : 21:47:33 : 21:47:33 : 21:47:33 : 21:47:33 : Start Writing Flash Images... 21:47:33 : 21:47:33 : 21:47:33 : 21:47:33 : Flash Image: sboot.bin 21:47:34 : Start Writing 0x00002000 Blocks at 0x00000000 21:47:34 : Partition Selected: BOOT 1 21:47:44 : 21:47:44 : Total Elapsed Time 00:00:10 21:47:44 : Write Success! 21:47:44 : 21:47:44 : 21:47:44 : Flash Image: cm.bin 21:47:44 : Start Writing 0x00002000 Blocks at 0x00000000 21:47:44 : Partition Selected: BOOT 2 21:47:54 : 21:47:54 : Total Elapsed Time 00:00:10 21:47:54 : Write Success! 21:47:54 : 21:47:54 : 21:47:54 : Total Images Written: 2 21:47:54 : Process Done! Last edited by ..::Angel::..; 02-16-2016 at 18:17. |
The Following 11 Users Say Thank You to ..::Angel::.. For This Useful Post: |
02-15-2016, 11:52 | #15 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | cmd+2.8 removed from board any one can help or i can to connect to it without R? thanx |
The Following 2 Users Say Thank You to anasshe For This Useful Post: |
