Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-15-2016, 12:16   #16 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@Diamond Gsm,
You want you ATF Temporary or Full blocked?
Why go in other section Sharing Atf Solusion?
Read here: http://forum.gsmhosting.com/vbb/f609.../#post11626439
just put in this list
Old 02-15-2016, 12:23   #17 (permalink)
Diamond Gsm's Avatar
Member: 2064519
Thanks Meter: 83
Originally Posted by anasshe View Post
cmd+2.8 removed from board any one can help or i can to connect to it without R?
thanx
once try to do wiring pinout and test again to scan emmc
Old 02-15-2016, 12:34   #18 (permalink)
Member: 2064519
Thanks Meter: 83
Originally Posted by allumts View Post
@Diamond Gsm,
bro i didn't know atf team want do this work
Old 02-15-2016, 13:02   #19 (permalink)
allumts's Avatar
Member: 1564612
so now you know.
you do not need to make you beautiful with the work of others and going to post our solutions directly into the house of the other teams.
Is enough all their copy / paste that make alone
The Following User Says Thank You to allumts For This Useful Post:
Old 02-15-2016, 16:11   #20 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
@ Advance-Box, it is very necessary to flash newest firmware??
My question is - why flash with newest firmware ??
Old 02-15-2016, 16:16   #21 (permalink)
Member: 1522144
Thanks Meter: 15
i need connect both of 2,8?
Old 02-15-2016, 16:34   #22 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Because if phone is "killed" via flash downgrade, then there is no way for you to know what firmware was inside the phone before it died.
Easiest way to fix is to write newest firmware. If you don't want to write newest firmware, then it depends on you. If phone still dead after you try to repair, then you know why...
New Samsungs not allow downgrade.
The Following 8 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-15-2016, 16:44   #23 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
@maxpro12
simply to avoid dead phone always use latest fw.
Old 02-15-2016, 20:16   #24 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
I WAS KNOW YOU ARE THE ONLY MAN IN THE WORLD
@ADVANCE-BOX
@X-SHADOW
WHO CAN CATCH LITTLE ANT FROM J700
THANKS FOR GIVING GOLDEN TIME TO J700---FOR MAKING GOLD FOR US
The Following 4 Users Say Thank You to chand_gee For This Useful Post:
Old 02-15-2016, 22:53   #25 (permalink)
Member: 205475
Thanks Meter: 179
tested and work 1000000000% best box from great team but i have another one the cmd removed from board any help thanx again
Old 02-15-2016, 23:28   #26 (permalink)
Jimbojump's Avatar
Member: 1748375
Sonork: 100.1617845
Thanks Meter: 17
I have one question. boot repair and flash firmware for j700F-DS and J700F-DD Is different or same???? Thanks
Old 02-16-2016, 00:06   #27 (permalink)
Jimbojump's Avatar
Member: 1748375
Sonork: 100.1617845
Thanks Meter: 17
In samfirmware is Sm-J700F only. Not showing DS Or DD. same firmware ????
I think J700F-DD for Indian only and J700F-DS for other Country.
Old 02-16-2016, 16:52   #28 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
yes you are correct F/DD for India, other country is DS
but they are same firmware J700F
Old 02-16-2016, 22:42   #29 (permalink)
Member: 2089529
Thanks Meter: 2
I tested. but still not working i dowonlod last flash for j700h and flashed with emmc tool like image but not work any one have any idea for my plzzzz
أرسلت من HTC Desire 816 dual sim بإستخدام تاباتلك
Old 02-16-2016, 23:27   #30 (permalink)
Jimbojump's Avatar
Member: 1748375
Sonork: 100.1617845
Thanks Meter: 17
But when you flash j700f dd with Except J700f dd firmware(J700f ds file Except indian firmware ) phone will die. I tested.
The Following User Says Thank You to Jimbojump For This Useful Post:
Page generated in 0.20866 seconds with 9 queries
