03-28-2016, 15:24 | #169 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | Sm-j700f dead boot repair erorr when i try to repair sm-j700f dead boot repair showing pit error. ================================================== === ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010034303030373300A35A25EFA22F CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : A35A25EF Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010034303030373300A35A25EFA22F.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... ERROR: PIT Partition NOT FOUND! Please Provide a PIT File via Selecting "Re-Partition" when i try with pit again show another error Extended CSD Saved: 11010034303030373300A35A25EFA22F.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! |
03-28-2016, 23:29 | #171 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | Quote:
I HAVE 1 DEAD BOOT AFTER DOWNGRADE TO 4.4.4... TRIED WITH DUMP FILES BUT STILL DEAD | |
03-31-2016, 22:59 | #172 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2542589 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Please help if you posted a video of the solution to the problem of the bot J700H and withdrawal method of the emmc This is my account on Facebook 07706887711😢 أرسلت من GT-I9301I بإستخدام تاباتلك |
04-01-2016, 12:01 | #173 (permalink) |
No Life Poster Join Date: Jan 2013
Member: 1873398 Status: Offline Thanks Meter: 149 | Sm-j700h/ds write boot success but no download mode Sm-j700h/ds write boot success but no download mode IM TRYING 2 DIFRENT FILES BUT PHONE STILL DAD J700HXXU2APC4_J700HOXY2APC4_J700HXXU2APC4_HOME.tar J700HXXU1APA3_J700HOJV1AOK6_J700HXXU1APA2_HOME.tar I HAVE DUMP ANY ONE TELL ME HOW TO WRITE DUMP OR OTHER SLUTION ? ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733007A8BD108B2ED CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 7A8BD108 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733007A8BD108B2ED.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 2 Process Done! |
04-02-2016, 16:17 | #175 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | After write last one phone still sleeping Code: BL_J700HXXU2APC4_CL1007644_QB8985004_REV00_user_low_ship.tar Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. Make Sure CLK Test Point is already Soldered 2. Make Sure CMD Test Point is already Soldered Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733008BD2B786A221 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 8BD2B786 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733008BD2B786A221.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00.00.06 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00.00.04 Write Success! Total Images Written: 2 Process Done! |
04-02-2016, 16:36 | #176 (permalink) | |
Member: 1873398 Status: Offline Thanks Meter: 149 | Phone success full repair no budy guide me any way thnx team Phone success full repair sm-j700h no budy guide me any way thnx team Quote:
04-03-2016, 11:40 | #179 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | TESTED VERY MUCH!!! THANKS ATF TEAM !!! OHWRYT... J-TAG/TANIM MODE ( pwedi pa pala kamay at mata ko sa taniman hihi ) DONE BOOTLOADER ALIVE |
The Following User Says Thank You to bronce For This Useful Post: |
