07-10-2016, 13:30 | #331 (permalink) |
Crazy Poster Join Date: Apr 2013
Member: 1918840 Status: Offline Thanks Meter: 11 | 16:11:15 : 1. DO NOT USE THE PHONE"S BATTERY 16:11:15 : 2. Connect the Soldered TP Connections to ATF Box 16:11:15 : 3. Disconnect the USB Cable and Wait until the 16:11:15 : the ATF Software will tell you to Connect the USB. 16:11:15 : 16:11:15 : 16:11:15 : Interface Reset OK! 16:11:15 : eMMC Access Type: SECTOR MODE 16:11:15 : eMMC Supported Voltage Range: 16:11:15 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 16:11:15 : 16:11:15 : CID : 1101003430303037330088E340F0A219 16:11:15 : CSD : D07E00320F5903FFFFFFFFE78A4000D1 16:11:15 : 16:11:15 : eMMC Boot Information 16:11:15 : Revision 1.7 (for MMC v5.0, v5.01) 16:11:15 : BOOT PARTITION : BOOT PARTITION 1 16:11:15 : PARTITION ACCESS : R/W USER PARTITION 16:11:15 : PERM_BOOT_CFG_PROT : DISABLED 16:11:15 : PWR_BOOT_CFG_PROT : DISABLED 16:11:15 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 16:11:15 : RESET BUS WIDTH : ENABLED 16:11:15 : eMMC FirmW UPDATE : DISABLED 16:11:15 : EMMC CACHE SIZE : 0 KB 16:11:15 : SUPER PAGE SIZE : 4096 KB 16:11:15 : HC ERASE GROUP SIZE: 4096 KB 16:11:15 : USER AREA SIZE : 15758000128 BYTES 16:11:15 : BOOT PARTITION SIZE: 4096 KB 16:11:15 : RPMB PARTITION SIZE: 4096 KB 16:11:15 : 16:11:15 : 16:11:15 : eMMC Device Information 16:11:15 : Manufacturer ID: TOSHIBA 16:11:15 : Device Type : Embedded BGA 16:11:15 : Application ID : 00 16:11:15 : Product Name : 400073 16:11:15 : Product Rev : 0.0 16:11:15 : Product SN : 88E340F0 16:11:15 : Manufactured : January 1999 16:11:15 : 16:11:15 : Card Specific Data 16:11:15 : CSD_STRUCTURE : Extended 16:11:15 : SPEC_VERS : Version 4.1/4.2/4.3 16:11:15 : TAAC : 8000 ns 16:11:15 : TRAN_SPEED : 4000000 KHz 16:11:15 : READ_BL_LEN : 512 Bytes 16:11:15 : C_SIZE : HIGH CAPACITY 16:11:15 : WP_GRP_ENABLE : YES 16:11:15 : WRITE_BL_LEN : 512 Bytes 16:11:15 : CONTENT_PROT_APP : NO 16:11:15 : PERM_WRITE_PROTECT: NO 16:11:15 : TMP_WRITE_PROTECT : NO 16:11:15 : 16:11:15 : Extended CSD Saved: 16:11:15 : 1101003430303037330088E340F0A219.ext_csd 16:11:15 : Backup Directory: 16:11:15 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 16:11:15 : 16:11:15 : 16:11:15 : 16:11:15 : 16:11:15 : Start Writing Flash Images... 16:11:15 : 16:11:15 : 16:11:15 : 16:11:15 : Flash Image: sboot.bin 16:11:16 : Start Writing 0x00002000 Blocks at 0x00000000 16:11:16 : Partition Selected: BOOT 1 16:11:23 : 16:11:23 : Total Elapsed Time 00:00:07 16:11:23 : Write Success! 16:11:23 : 16:11:23 : 16:11:23 : Flash Image: param.bin 16:11:24 : Start Writing 0x00004000 Blocks at 0x0001A800 16:11:24 : Partition Selected: USER AREA 16:11:43 : 16:11:43 : Total Elapsed Time 00:00:19 16:11:43 : Write Success! 16:11:43 : 16:11:43 : 16:11:43 : Flash Image: cm.bin 16:11:44 : Start Writing 0x00002000 Blocks at 0x00000000 16:11:44 : Partition Selected: BOOT 2 16:12:05 : 16:12:05 : Total Elapsed Time 00:00:21 16:12:05 : Write Success! 16:12:05 : 16:12:05 : 16:12:05 : Total Images Written: 3 16:12:05 : Process Done! |
07-12-2016, 11:06 | #332 (permalink) |
Insane Poster Join Date: Jan 2010 Location: russian federation
Member: 1218019 Status: Offline Thanks Meter: 6 | boot successfully restored. body go to download mode. but i cant flashing body. in odin an error pit not found. i try 4-files firmware. i try pit. but repartion filed. for boot i used J700HXXU2APE3_J700HOXY2APE3_CAU. which pit file to use? |
07-13-2016, 10:50 | #336 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
VCC isn't Resistor but CAPACITOR, just ceck value from other same phone. FOR ALL: Not use Last Build 6.0.1, Samsung has disabled some Function and is useless use this FW. Br allumts | |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
07-14-2016, 13:42 | #341 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 581 | Quote:
07-14-2016, 21:07 | #342 (permalink) | |
Member: 1218019 Status: Offline Thanks Meter: 6 | Quote: | |
07-20-2016, 17:40 | #345 (permalink) |
Junior Member Join Date: Jan 2009
Member: 942321 Status: Offline Thanks Meter: 1 | samsung J700H ,i was repair boot succesfully but phone not power on. i can not flash to repaire phone. i have try 5 firmwares and android 6.0.1 ,same probleme . who have solution for me thanks phone is coming to UAE (LYS) language |
