08-15-2016, 19:06 | #361 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have resetted All....how want write only the 2 file from "Bootloader" Fw ?????... |
08-20-2016, 18:48 | #362 (permalink) |
Junior Member Join Date: Oct 2011 Location: medellin, colombia
Member: 1673356 Status: Offline Thanks Meter: 2 | Excuse the question, what version of atf should I buy? (nitro, box or GoldBox) activation or what should I have? to repair boot J7 with atf thanks |
08-24-2016, 22:41 | #363 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Can purchase Atf Gold, (coming with All activaction inside) + SmartGsm 4 in 1 V3 adapter and haven't any issue for activaction or connection by EMMC Direct.. |
09-07-2016, 15:09 | #366 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2621792 Status: Offline Thanks Meter: 2 | I have problem with J700H my atf box say when I scan eMMC eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 Is that my phone emmc is not good or what? please |
09-07-2016, 17:37 | #367 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR | |
09-19-2016, 09:35 | #371 (permalink) |
Insane Poster Join Date: Oct 2015 Location: LAGOS/ NIGERIA
Member: 2478245 Status: Offline Sonork: 100.1669922:JOTECH Thanks Meter: 10 | Sm-j700h emmc boot repair write error PLEASE CAN SOMEONE HELP ME OUT AS TO WHAT COULD BE WRONG WITH MY TRYING TO REPAIR THE BOOT OF SM-J700H WHICH FAILED TO BOOT AFTER FLASHING A BOOLOADER FILE(BL_J700HXXU1AOG3_CL679261_QB5534807_REV00_use r_low_ship.tar) THE PHONE CONNECTED OK WITH ATF EMMC REPAIR TOOL BUT WOULD NOT WRITE THE REQUIRED FILES BEYOUNG 12% AND THE KEEP RETYING. PLEASE WHAT COULD BE WRONG? |
09-19-2016, 20:45 | #373 (permalink) | |
When have writed these 2 file with Success in EMMC then reflash with Same FW used for Repair from Dead Boot. *** REMEMBER ONE IMPORTANT THING *** The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files. BR allumts | |
09-20-2016, 09:02 | #374 (permalink) | |
Member: 2478245 Status: Offline Sonork: 100.1669922:JOTECH Thanks Meter: 10 | Quote:
