04-23-2017, 18:32 | #391 (permalink) | |
Freak Poster Join Date: Jul 2014
Member: 2220270 Status: Offline Thanks Meter: 8 | Quote:
i need process pic again & test point picture please again i don't see process picture on 1st post. i need j700h/ds Last edited by karnagrg; 04-23-2017 at 18:34. Reason: add some word. | |
09-04-2017, 07:14 | #395 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: allahabad shankargarh u.p.
Member: 865141 Status: Offline Thanks Meter: 140 | dear boot flash file need Quote:
plz other side j700f boot file need adwance thanx | |
09-04-2017, 13:00 | #396 (permalink) | |
Member: 865141 Status: Offline Thanks Meter: 140 | plz need boot loder file other downolode Quote:
other downlode link dear plz .................... | |
09-12-2017, 14:04 | #398 (permalink) |
Member: 865141 Status: Offline Thanks Meter: 140 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733006B7B1C0CA2E5 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 6B7B1C0C Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733006B7B1C0CA2E5.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: PIT Start Writing 0x00000008 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:14 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 3 Process Done! but mobile not don plz help me ................... all frend |
09-12-2017, 14:11 | #399 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Why you has flashed to much partition when you need only 2 File: Quote:
09-12-2017, 14:28 | #400 (permalink) |
Member: 865141 Status: Offline Thanks Meter: 140 | BL_J700FXXU1AOL2_CL916897_QB7693529_REV00_user_low _ship.tar then write dear ic name cpu name......... SK hynix Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 2 Process Done! |
09-20-2017, 05:45 | #401 (permalink) |
Member: 865141 Status: Offline Thanks Meter: 140 | today my problem solved ......................... big thanks...........all atf team |
The Following 2 Users Say Thank You to linux_sh For This Useful Post: |
