Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-23-2017, 18:32   #391 (permalink)
Member: 2220270
Thanks Meter: 8
Originally Posted by Advance-Box View Post
STEP 1:
Download NEWEST Flash File which have your Language Pack Inside from S-A-M-M-O-B-I-L-E.com or other sites...
STEP 2:
Solder eMMC Connections to Phone PCB:
(Thanks to Chand Gee for Finding the Pinouts)
STEP 3:
Use ATF Software 12.66 or Higher... Select eMMC Tool Tab from ATF Plus.
Follow the Steps illustrated in the Screenshots Below:
STEP 4:
De-Solder/Remove eMMC Connections on the PCB and Flash Phone via ODIN using the same flash file which you used on Step 3.
STEP 5:
Done.
*** REMEMBER ONE IMPORTANT THING ***
The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files.
i need process pic again & test point picture please again i don't see process picture on 1st post.
i need j700h/ds
Old 07-13-2017, 11:53   #392 (permalink)
noi
noi's Avatar
Member: 49103
Thanks Meter: 45
where are those emmc connection pics onstep 2 and step 3..please post
Old 08-31-2017, 05:48   #393 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
need flash file chand jee................ sumung j700f
Old 08-31-2017, 09:05   #394 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
What Flash file you need?...is enough last Stock Fw .tar.md5 from Sammobile and use only the 2 "Bootlader" files.
Read carefully first page instead of post useless question.
The Following User Says Thank You to allumts For This Useful Post:
Old 09-04-2017, 07:14   #395 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
dear boot flash file need
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
Done.
plz other side j700f boot file need adwance thanx
Old 09-04-2017, 13:00   #396 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
plz need boot loder file other downolode
Originally Posted by ..::Angel::.. View Post
Hi, if you don't want to download complete firmware...
Here BL / Bootloader file for SM-J700F, recent version:
https://mega.nz/#!URJVARKA!ODPoWPhrv...syqWmHs2--d21I
SM-J700F successfully repaired:
21:47:33 : ======================================================
21:47:33 :        eMMC Test Point Connection Module
21:47:33 :
21:47:33 : 1. DO NOT USE THE PHONE"S BATTERY
21:47:33 : 2. Connect the Soldered TP Connections to ATF Box
21:47:33 : 3. Disconnect the USB Cable and Wait until the
21:47:33 :    the ATF Software will tell you to Connect the USB.
21:47:33 :
21:47:33 :
21:47:33 : Interface Reset OK!
21:47:33 : eMMC Access Type: SECTOR MODE
21:47:33 : eMMC Supported Voltage Range:
21:47:33 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
21:47:33 :
21:47:33 : CID : 11010034303030373300C4EB3D26A2C3
21:47:33 : CSD : D07E00320F5903FFFFFFFFE78A4000D1
21:47:33 :
21:47:33 : eMMC Boot Information
21:47:33 : Revision 1.7 (for MMC v5.0, v5.01)
21:47:33 : BOOT PARTITION     : BOOT PARTITION 1
21:47:33 : PARTITION ACCESS   : R/W USER PARTITION
21:47:33 : PERM_BOOT_CFG_PROT : DISABLED
21:47:33 : PWR_BOOT_CFG_PROT  : DISABLED
21:47:33 : BOOT MODE          : x4 SINGLE DATA RATE + LOW SPEED
21:47:33 : RESET BUS WIDTH    : ENABLED
21:47:33 : eMMC FirmW UPDATE  : DISABLED
21:47:33 : EMMC CACHE SIZE    : 0 KB
21:47:33 : SUPER PAGE SIZE    : 4096 KB
21:47:33 : HC ERASE GROUP SIZE: 4096 KB
21:47:33 : USER AREA SIZE     : 15758000128 BYTES
21:47:33 : BOOT PARTITION SIZE: 4096 KB
21:47:33 : RPMB PARTITION SIZE: 4096 KB
21:47:33 :
21:47:33 :
21:47:33 : eMMC Device Information
21:47:33 : Manufacturer ID: TOSHIBA
21:47:33 : Device Type    : Embedded BGA
21:47:33 : Application ID : 00
21:47:33 : Product Name   : 400073
21:47:33 : Product Rev    : 0.0
21:47:33 : Product SN     : C4EB3D26
21:47:33 : Manufactured   : January 1999
21:47:33 :
21:47:33 : Card Specific Data
21:47:33 : CSD_STRUCTURE     : Extended
21:47:33 : SPEC_VERS         : Version 4.1/4.2/4.3
21:47:33 : TAAC              : 8000 ns
21:47:33 : TRAN_SPEED        : 4000000 KHz
21:47:33 : READ_BL_LEN       : 512 Bytes
21:47:33 : C_SIZE            : HIGH CAPACITY
21:47:33 : WP_GRP_ENABLE     : YES
21:47:33 : WRITE_BL_LEN      : 512 Bytes
21:47:33 : CONTENT_PROT_APP  : NO
21:47:33 : PERM_WRITE_PROTECT: NO
21:47:33 : TMP_WRITE_PROTECT : NO
21:47:33 :
21:47:33 : Extended CSD Saved:
21:47:33 : 11010034303030373300C4EB3D26A2C3.ext_csd
21:47:33 : Backup Directory:
21:47:33 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 : Start Writing Flash Images...
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 : Flash Image: sboot.bin
21:47:34 : Start Writing 0x00002000 Blocks at 0x00000000
21:47:34 : Partition Selected: BOOT 1
21:47:44 :
21:47:44 : Total Elapsed Time 00:00:10
21:47:44 : Write Success!
21:47:44 :
21:47:44 :
21:47:44 : Flash Image: cm.bin
21:47:44 : Start Writing 0x00002000 Blocks at 0x00000000
21:47:44 : Partition Selected: BOOT 2
21:47:54 :
21:47:54 : Total Elapsed Time 00:00:10
21:47:54 : Write Success!
21:47:54 :
21:47:54 :
21:47:54 : Total Images Written: 2
21:47:54 : Process Done!
other downlode link dear plz ....................
Old 09-04-2017, 13:08   #397 (permalink)
allumts's Avatar
Member: 1564612
But is complicate loock GOOD Photo 2 and 3 and Download Last Stock Fw from Sammobile or anywhere?
Wake Up please not ask for to have all ready in you handes...move....Lazy people!!!
Old 09-12-2017, 14:04   #398 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
Interface Reset OK!
CID : 110100343030303733006B7B1C0CA2E5
Application ID : 00
Product Rev : 0.0
Product SN : 6B7B1C0C
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
110100343030303733006B7B1C0CA2E5.ext_csd
Backup Directory:
MBR is Corrupted...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
Total Elapsed Time 00:00:01
Write Success!
Flash Image: PIT
Start Writing 0x00000008 Blocks at 0x00000022
Total Elapsed Time 00:00:03
Write Success!
Flash Image: SGPT
Start Writing 0x00000021 Blocks at 0x01D59FDF
Total Elapsed Time 00:00:00
Write Success!
Total Elapsed Time 00:00:07
Write Success!
Flash Image: param.bin
Start Writing 0x00004000 Blocks at 0x0001A800
Total Elapsed Time 00:00:14
Write Success!
Flash Image: cm.bin
Write Success!
Total Images Written: 3
Process Done!
but mobile not don plz help me ................... all frend
Old 09-12-2017, 14:11   #399 (permalink)
allumts's Avatar
Member: 1564612
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Write Success!
Flash Image: PIT
Write Success!
Flash Image: SGPT
Write Success!
Write Success!
Write Success!
Flash Image: cm.bin
Write Success!
Process Done!
Read carefully First post.
Why you has flashed to much partition when you need only 2 File:
sboot.bin
cm.bin
From Last Bootloader of Firmware .tar.md5
Old 09-12-2017, 14:28   #400 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
BL_J700FXXU1AOL2_CL916897_QB7693529_REV00_user_low _ship.tar
then write dear
ic name cpu name......... SK hynix
Write Success!
Flash Image: cm.bin
Write Success!
Process Done!
Old 09-20-2017, 05:45   #401 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
today my problem solved ......................... big thanks...........all atf team
The Following 2 Users Say Thank You to linux_sh For This Useful Post:
Old 10-04-2017, 08:17   #402 (permalink)
Member: 2436645
Thanks Meter: 28
need samsung sm-a7100 emmc pinout
Old 08-28-2018, 20:36   #403 (permalink)
Member: 261334
Thanks Meter: 13
friends i need help i need to repair boot J700M i have this cable i need to know which ones i should connect to the board.
File Type: jpeg WhatsApp Image 2018-08-28 at 16.35.39.jpeg (103.4 KB, 25 views)
Old 08-30-2018, 03:03   #404 (permalink)
Member: 261334
Thanks Meter: 13
please I need the urgent pinaut for that cable
Page generated in 0.27884 seconds with 9 queries
