Samsung SM-J700F/H/K/M/P/8 BOOT Repair via eMMC Flashing STEP 1: Download NEWEST Flash File which have your Language Pack Inside from S-A-M-M-O-B-I-L-E.com or other sites... STEP 2: Solder eMMC Connections to Phone PCB: (Thanks to Chand Gee for Finding the Pinouts) https://s5.postimg.org/3sw2seadz/SM-...MMC_PINOUT.jpg STEP 3: Use ATF Software 12.66 or Higher... Select eMMC Tool Tab from ATF Plus. Follow the Steps illustrated in the Screenshots Below: https://s5.postimg.org/wjswigg7r/EMMC_WRITE_TAR_A.jpg https://s5.postimg.org/jgx9z6pzr/EMMC_WRITE_TAR_B.jpg https://s5.postimg.org/6e68tnp5j/EMMC_WRITE_TAR_C.jpg https://s5.postimg.org/nsqh1xmaf/EMMC_WRITE_TAR_D.jpg STEP 4: De-Solder/Remove eMMC Connections on the PCB and Flash Phone via ODIN using the same flash file which you used on Step 3. STEP 5: Done. *** REMEMBER ONE IMPORTANT THING *** The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files. |
Very Good update .My request to ATF Team plz come in SAMSUNG market Because Nokia market is very slow So if its possible then come in SAMSUNG with complete solutions like Unlocking flashing and Jtag or emmc with new SAMSUNG box.Because this update proves that no one Like ATF team. |
good update..please add win 8 direct unlock ..were ready to pay for the activation since service is down now for most servers |
@Advance box Sir, If I already have Only the BL file, can Only that file be selected? Thanks in Advance, BR jackle123 |
As long as two files inside your BL. sboot.bin cm.bin Then you can use it. Also, as long BL version is higher than what is needed to fix phone |
atf works 50% with bootrepair and easy jtag always work 100% some handset wich are not connect with atf done with easy jtag easily i have both activated but i dont know why atf fails in 50% handsets |
Only professional team can born Professional work--- Thanks |
thanks sir but why you diidnt choose boot img and after phone on only flash with one packge firmware pda or flashing with full firmware+pit and this method works on older phone also like n7100-i9300-n8000 flashing with sboot bin, cm bin or only for new phone with 5.1.1 version,thanks again and keep it up.... |
http://forum.gsmhosting.com/vbb/f609...users-2052397/ NOT import and Not paragon or naming Other Box/tool here, if not are satisfaction of Atf Box, please NOT use and NOT post nothing about Others Teams. |
atf team help this samsung s7562 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106230E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A5330304103224272DA702D Flash Description: Samsung JJS00A, 3.64 GiB, SN 224272DA, Jul 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91459 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! http://i.imgur.com/PUhvo22.png |
================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330080D99B8CA2BD CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 80D99B8C Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330080D99B8CA2BD.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:04 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:04 Write Success! Total Images Written: 2 Process Done! thanks and work 100% :) |
very nice update atfTEAM more bless to come!!!!! |
Hi, if you don't want to download complete firmware... Here BL / Bootloader file for SM-J700F, recent version: https://mega.nz/#!URJVARKA!ODPoWPhrv...syqWmHs2--d21I SM-J700F successfully repaired: Code: 21:47:33 : ====================================================== |
cmd+2.8 removed from board any one can help or i can to connect to it without R? thanx |
