thanx |
BR |
Here another one not done, dead by FRP lock resetting What to do? used latest bl file and other older files too. Quote:
There a few ways to avoid this problem: - Stupid way -> Read important partitions like EFS ect... from original one and change eMMC IC to Samsung - write it to Samsung eMMC, write BOOT-s also - tested and work. - A little bit smarter way - flash BOOT1 with sboot.bin and BOOT2 with cm.bin ( just follow the explanation at begining of thread ) and after this reconnect eMMC and READOUT both partitions. Compare dumps to bin images. If all is same, but phone cannot go to download mode - then you need to check for other damages! - If dumps and images have a difference - try again, if not work - connect the eMMC to other tool and repeat procedure - in any case the BOOT1 and BOOT2 must be a same or newnest that initial ones, before phone to die. WBR, DebeliaMark, BG |
Finally done repair but flashing failed! pit error Can anyone have J700F/DD pit? |
http://forum.gsmhosting.com/vbb/11701982-post133.html |
what u do Quote:
After write new bootloader same case not boot mode Code: BL_J700HXXU2APC2_CL1002542_QB8913155_REV00_user_low_ship.tar |
BL_J700HXXU1APA3_CL877784_QB8010669_REV00_user_low _ship.tar with and without re partition Put into download mode by jig, Try to flash with and without pit by odin and z3x Failed to flash! |
sir J700H emmx Repair Done butt no On downloud mode how soultion & Give me Boot Repir File |
Please do not complete Help Please do not complete Help I'm in trouble Please help me http://dc526.4shared.com/img/fjdi-Q2...08742357635571 http://dc526.4shared.com/img/2hVd7Hf...48032309075768 |
No Need "param.bin" file. Only cm.bin and Sboot.bin must need of use. Why not Read FIRST post of this thread instead of ask Help??? is showing all Step by Step. Quote:
Br allumts |
The same problem without choosing param.bin |
Change PC USB port or Pc, USB voltage maybe low. |
Thanks for the idea was changed 3.3 gtac tp |
