Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-15-2016, 06:40   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,059
Samsung SM-J700F/H/K/M/P/8 BOOT Repair via eMMC Flashing
STEP 1:
Download NEWEST Flash File which have your Language Pack Inside from S-A-M-M-O-B-I-L-E.com or other sites...
STEP 2:
Solder eMMC Connections to Phone PCB:
(Thanks to Chand Gee for Finding the Pinouts)
STEP 3:
Use ATF Software 12.66 or Higher... Select eMMC Tool Tab from ATF Plus.
Follow the Steps illustrated in the Screenshots Below:
STEP 4:
De-Solder/Remove eMMC Connections on the PCB and Flash Phone via ODIN using the same flash file which you used on Step 3.
STEP 5:
Done.
*** REMEMBER ONE IMPORTANT THING ***
The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always
use the NEWEST Flash Files and avoid using OLD Flash Files.
Last edited by ..::Angel::..; 08-23-2017 at 15:29. Reason: fixed broken links by mtk6572s4clone
The Following 72 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-15-2016, 07:33   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 987
Very Good update .My request to ATF Team plz come in SAMSUNG market Because Nokia market is very slow So if its possible then come in SAMSUNG with complete solutions like Unlocking flashing and Jtag or emmc with new SAMSUNG box.Because this update proves that no one Like ATF team.
The Following 11 Users Say Thank You to asad_nomy7 For This Useful Post:
Old 02-15-2016, 07:56   #3 (permalink)
Member: 731353
Thanks Meter: 129
good update..please add win 8 direct unlock ..were ready to pay for the activation since service is down now for most servers
The Following 4 Users Say Thank You to bigjef1 For This Useful Post:
Old 02-15-2016, 08:31   #4 (permalink)
Member: 138575
Thanks Meter: 50
@Advance box
Sir,
If I already have Only the BL file, can Only that file be selected?
Thanks in Advance,
jackle123
The Following User Says Thank You to jackle123 For This Useful Post:
Old 02-15-2016, 08:31   #5 (permalink)
Member: 138575
Thanks Meter: 50
@Advance box
Sir,
Thanks in Advance,
jackle123
The Following 2 Users Say Thank You to jackle123 For This Useful Post:
Old 02-15-2016, 08:44   #6 (permalink)
Member: 651945
Originally Posted by jackle123 View Post
@Advance box
Sir,
Thanks in Advance,
jackle123
As long as two files inside your BL.
sboot.bin
cm.bin
Then you can use it.
Also, as long BL version is higher than what is needed to fix phone
The Following 5 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-15-2016, 08:46   #7 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 134
atf works 50% with bootrepair and easy jtag always work 100% some handset wich are not connect with atf done with easy jtag easily
i have both activated but i dont know why atf fails in 50% handsets
The Following User Says Thank You to sunil1670 For This Useful Post:
Old 02-15-2016, 09:04   #8 (permalink)
Member: 2203193
Thanks Meter: 19
Only professional team can born
Professional work---
Thanks
Old 02-15-2016, 09:07   #9 (permalink)
Member: 1725884
Thanks Meter: 265
thanks sir but why you diidnt choose boot img and after phone on only flash with one packge firmware pda or flashing with full firmware+pit and this method works on older phone also like n7100-i9300-n8000 flashing with sboot bin, cm bin or only for new phone with 5.1.1 version,thanks again and keep it up....
Old 02-15-2016, 09:38   #10 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,001
@sunil1670, you want to be the first in this Thread:
<<<<<<<<<< Attention ATF users >>>>>>>>>>
NOT import and Not paragon or naming Other Box/tool here, if not are satisfaction of Atf Box, please NOT use and NOT post nothing about Others Teams.
The Following 6 Users Say Thank You to allumts For This Useful Post:
Old 02-15-2016, 10:01   #11 (permalink)
Member: 1971123
Sonork: 100.1661727
Thanks Meter: 524
atf team help this samsung s7562
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x106230E1 IR4
Restore Boot...
Waiting for Device Connection 20 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting eMMC #1 ID...1501004A4A5330304103224272DA702D
Flash Description: Samsung JJS00A, 3.64 GiB, SN 224272DA, Jul 1997
Partition Config: No boot enabled, Boot ACK OFF (0x00)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (91459 Op/Sec)
Restoring MBR Data...OK
Restoring Partition #1...OK
Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76
Please send this log and "..\Logs\.log" file to support!
The Following 5 Users Say Thank You to bis.kadhar For This Useful Post:
Old 02-15-2016, 10:29   #12 (permalink)
Diamond Gsm's Avatar
Member: 2064519
Thanks Meter: 83
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 1101003430303037330080D99B8CA2BD
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : 80D99B8C
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
1101003430303037330080D99B8CA2BD.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: sboot.bin
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Total Elapsed Time 00:00:04
Write Success!
Flash Image: cm.bin
Partition Selected: BOOT 2
Write Success!
Total Images Written: 2
Process Done!
thanks and work 100%
The Following 8 Users Say Thank You to Diamond Gsm For This Useful Post:
Old 02-15-2016, 10:34   #13 (permalink)
jonar23's Avatar
Member: 640052
Thanks Meter: 66
very nice update atfTEAM
more bless to come!!!!!
The Following User Says Thank You to jonar23 For This Useful Post:
Old 02-15-2016, 10:38   #14 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,528
Hi, if you don't want to download complete firmware...
Here BL / Bootloader file for SM-J700F, recent version:
https://mega.nz/#!URJVARKA!ODPoWPhrv...syqWmHs2--d21I
SM-J700F successfully repaired:
21:47:33 : ======================================================
21:47:33 :        eMMC Test Point Connection Module
21:47:33 :
21:47:33 : 1. DO NOT USE THE PHONE"S BATTERY
21:47:33 : 2. Connect the Soldered TP Connections to ATF Box
21:47:33 : 3. Disconnect the USB Cable and Wait until the
21:47:33 :    the ATF Software will tell you to Connect the USB.
21:47:33 :
21:47:33 :
21:47:33 : Interface Reset OK!
21:47:33 : eMMC Access Type: SECTOR MODE
21:47:33 : eMMC Supported Voltage Range:
21:47:33 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
21:47:33 :
21:47:33 : CID : 11010034303030373300C4EB3D26A2C3
21:47:33 : CSD : D07E00320F5903FFFFFFFFE78A4000D1
21:47:33 :
21:47:33 : eMMC Boot Information
21:47:33 : Revision 1.7 (for MMC v5.0, v5.01)
21:47:33 : BOOT PARTITION     : BOOT PARTITION 1
21:47:33 : PARTITION ACCESS   : R/W USER PARTITION
21:47:33 : PERM_BOOT_CFG_PROT : DISABLED
21:47:33 : PWR_BOOT_CFG_PROT  : DISABLED
21:47:33 : BOOT MODE          : x4 SINGLE DATA RATE + LOW SPEED
21:47:33 : RESET BUS WIDTH    : ENABLED
21:47:33 : eMMC FirmW UPDATE  : DISABLED
21:47:33 : EMMC CACHE SIZE    : 0 KB
21:47:33 : SUPER PAGE SIZE    : 4096 KB
21:47:33 : HC ERASE GROUP SIZE: 4096 KB
21:47:33 : USER AREA SIZE     : 15758000128 BYTES
21:47:33 : BOOT PARTITION SIZE: 4096 KB
21:47:33 : RPMB PARTITION SIZE: 4096 KB
21:47:33 :
21:47:33 :
21:47:33 : eMMC Device Information
21:47:33 : Manufacturer ID: TOSHIBA
21:47:33 : Device Type    : Embedded BGA
21:47:33 : Application ID : 00
21:47:33 : Product Name   : 400073
21:47:33 : Product Rev    : 0.0
21:47:33 : Product SN     : C4EB3D26
21:47:33 : Manufactured   : January 1999
21:47:33 :
21:47:33 : Card Specific Data
21:47:33 : CSD_STRUCTURE     : Extended
21:47:33 : SPEC_VERS         : Version 4.1/4.2/4.3
21:47:33 : TAAC              : 8000 ns
21:47:33 : TRAN_SPEED        : 4000000 KHz
21:47:33 : READ_BL_LEN       : 512 Bytes
21:47:33 : C_SIZE            : HIGH CAPACITY
21:47:33 : WP_GRP_ENABLE     : YES
21:47:33 : WRITE_BL_LEN      : 512 Bytes
21:47:33 : CONTENT_PROT_APP  : NO
21:47:33 : PERM_WRITE_PROTECT: NO
21:47:33 : TMP_WRITE_PROTECT : NO
21:47:33 :
21:47:33 : Extended CSD Saved:
21:47:33 : 11010034303030373300C4EB3D26A2C3.ext_csd
21:47:33 : Backup Directory:
21:47:33 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 : Start Writing Flash Images...
21:47:33 :
21:47:33 :
21:47:33 :
21:47:33 : Flash Image: sboot.bin
21:47:34 : Start Writing 0x00002000 Blocks at 0x00000000
21:47:34 : Partition Selected: BOOT 1
21:47:44 :
21:47:44 : Total Elapsed Time 00:00:10
21:47:44 : Write Success!
21:47:44 :
21:47:44 :
21:47:44 : Flash Image: cm.bin
21:47:44 : Start Writing 0x00002000 Blocks at 0x00000000
21:47:44 : Partition Selected: BOOT 2
21:47:54 :
21:47:54 : Total Elapsed Time 00:00:10
21:47:54 : Write Success!
21:47:54 :
21:47:54 :
21:47:54 : Total Images Written: 2
21:47:54 : Process Done!
The Following 11 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 02-15-2016, 10:52   #15 (permalink)
Member: 205475
Thanks Meter: 176
cmd+2.8 removed from board any one can help or i can to connect to it without R?
thanx
The Following 2 Users Say Thank You to anasshe For This Useful Post:
Page generated in 0.39191 seconds with 8 queries
