03-19-2016, 21:35 | #137 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1972804 Status: Offline Thanks Meter: 26 | Please help Please sorry for disturbing is the 4 in 1 atf adapter same with all in 1 ultimate adapter because i only have the all in 1 ultimate adapter and i want to work on a j700f. and i need a video tutorial on how to connect with a j700f. Please help your boy. |
The Following User Says Thank You to kelexy10 For This Useful Post: |
03-19-2016, 22:06 | #138 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Just answered in other post. Br | |
03-21-2016, 16:03 | #142 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | still dead ,.... BL_J700FXXU2APC4_CL1002452_QB8911862_REV00_user_lo w_ship.tar J7E3G_EUR_OPEN what to next.... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT Start Writing 0x00000008 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:23 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 3 Process Done! |
03-21-2016, 20:34 | #144 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | and @alamgir80 There no separate BOOTLOADER for J700H and/or J700H/DS - it's SAME, exactly. Tested. WBR, DebeliaMark, BG P.S. - the Simple way to revive SM-J700H or SM-J700H/DS is to flash BOOT1 ( ROM2 ) eMMC partition with sboot.bin and BOOT2 ( ROM3 ) eMMC partition with cm.bin - both are 4Mb in size, and to flash ( not mandatory ) - param.bin in USER AREA ( ROM1 ) eMMC partition from 0x0001A800 to 0x0001F7FF - thats all - the phone must go to Download Mode. P.S.2 - Bootloader MUST be from SAME or newnest FW release compare to initial one in phone ( before to die !!! ) . The simple way is to use the LATEST One. |
The Following User Says Thank You to debeliamark For This Useful Post: |
03-21-2016, 20:43 | #145 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | |
03-21-2016, 20:54 | #146 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Forgot to give just a bootloader link to BL_J700HXXU2APB7 ... sorry. |
03-21-2016, 23:21 | #148 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | thanx i repair many j700h dead by downgrade all of them success but tow of them not still dead i notice j700h with frp protect and dead by downgrade not done like this one: Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733004D49B8AAA2C9 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 4D49B8AA Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733004D49B8AAA2C9.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:08 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:08 Write Success! Total Images Written: 2 Process Done! J700HXXU2APB7_J700HOJV2APB7_J700HXXU2APB7_HOME.tar .md5 J700HXXU1APA3_J700HOJV1AOK6_J700HXXU1APA2_HOME.tar .md5 and still dead |
03-22-2016, 04:40 | #149 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Quote:
need another solution | |
