Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-27-2016, 16:39   #166 (permalink)
Crazy Poster
Member: 714092
Thanks Meter: 11
Ipossible file boot j700f 100% ok
Old 03-27-2016, 17:13   #167 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
resistor 2.8 cmd pull up from board how i can know value of it to put another one
Old 03-28-2016, 10:05   #168 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Value of CMD resistor is 10K later you connect in one side 2.8V external power.
Old 03-28-2016, 15:24   #169 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Question Sm-j700f dead boot repair erorr
when i try to repair sm-j700f dead boot repair showing pit error.
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034303030373300A35A25EFA22F
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : A35A25EF
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034303030373300A35A25EFA22F.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
when i try with pit again show another error
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Old 03-28-2016, 16:26   #170 (permalink)
Registered User
Member: 1029548
Sonork: 12345
Thanks Meter: 3
thank....
br.......
Old 03-28-2016, 23:29   #171 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 127
Originally Posted by Advance-Box View Post
STEP 1:
Download NEWEST Flash File which have your Language Pack Inside from s-a-m-m-o-b-i-l-e.com or other sites...
STEP 2:
Solder eMMC Connections to Phone PCB:
(Thanks to Chand Gee for Finding the Pinouts)
STEP 3:
Use ATF Software 12.66 or Higher... Select eMMC Tool Tab from ATF Plus.
Follow the Steps illustrated in the Screenshots Below:
STEP 4:
De-Solder/Remove eMMC Connections on the PCB and Flash Phone via ODIN using the same flash file which you used on Step 3.
STEP 5:
Done.
*** REMEMBER ONE IMPORTANT THING ***
The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files.
CAN this method work on G530H????
I HAVE 1 DEAD BOOT AFTER DOWNGRADE TO 4.4.4...
TRIED WITH DUMP FILES BUT STILL DEAD
Old 03-31-2016, 22:59   #172 (permalink)
Member: 2542589
Please help if you posted a video of the solution to the problem of the bot J700H and withdrawal method of the emmc
This is my account on Facebook
07706887711😢
أرسلت من GT-I9301I بإستخدام تاباتلك
Old 04-01-2016, 12:01   #173 (permalink)
Member: 1873398
Thanks Meter: 149
Sm-j700h/ds write boot success but no download mode
IM TRYING 2 DIFRENT FILES BUT PHONE STILL DAD J700HXXU2APC4_J700HOXY2APC4_J700HXXU2APC4_HOME.tar
J700HXXU1APA3_J700HOJV1AOK6_J700HXXU1APA2_HOME.tar
I HAVE DUMP ANY ONE TELL ME HOW TO WRITE DUMP OR OTHER SLUTION ?
Interface Reset OK!
CID : 110100343030303733007A8BD108B2ED
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
SUPER PAGE SIZE : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
Application ID : 00
Product Rev : 0.0
Product SN : 7A8BD108
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
110100343030303733007A8BD108B2ED.ext_csd
Backup Directory:
Flash Image: sboot.bin
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Total Elapsed Time 00:00:07
Write Success!
Flash Image: cm.bin
Write Success!
Total Images Written: 2
Process Done!
Old 04-02-2016, 09:52   #174 (permalink)
Member: 1908819
Sonork: 100.1626428
any body has a proper tutorial j700f boot repair help plzzzzz
Old 04-02-2016, 16:17   #175 (permalink)
Member: 621121
Thanks Meter: 366
After write last one phone still sleeping
BL_J700HXXU2APC4_CL1007644_QB8985004_REV00_user_low_ship.tar
1. Make Sure CLK Test Point is already Soldered
2. Make Sure CMD Test Point is already Soldered
Interface Reset OK!
CID : 110100343030303733008BD2B786A221
Application ID : 00
Product Rev    : 0.0
Product SN     : 8BD2B786
Card Specific Data
TAAC              : 8000 ns
WP_GRP_ENABLE     : YES
Extended CSD Saved:
110100343030303733008BD2B786A221.ext_csd
Backup Directory:
Total Elapsed Time 00.00.06
Write Success!
Flash Image: cm.bin
Partition Selected: BOOT 2
Total Elapsed Time 00.00.04
Write Success!
Process Done!
Old 04-02-2016, 16:36   #176 (permalink)
Member: 1873398
Thanks Meter: 149
Phone success full repair no budy guide me any way thnx team
Phone success full repair sm-j700h no budy guide me any way thnx team
Originally Posted by shahidshan40 View Post
sm-j700h/ds write boot success but no download mode
im trying 2 difrent files but phone still dad j700hxxu2apc4_j700hoxy2apc4_j700hxxu2apc4_home.tar
j700hxxu1apa3_j700hojv1aok6_j700hxxu1apa2_home.tar
i have dump any one tell me how to write dump or other slution ?
emmc test point connection module
1. Do not use the phone"s battery
2. Connect the soldered tp connections to atf box
3. Disconnect the usb cable and wait until the
the atf software will tell you to connect the usb.
Interface reset ok!
Emmc access type: Sector mode
emmc supported voltage range:
3.5-3.6v, 3.4-3.5v, 3.3-3.4v, 3.2-3.3v, 3.1-3.2v
3.0-3.1v, 2.9-3.0v, 2.8-2.9v, 2.7-2.8v, 1.9-2.0v
cid : 110100343030303733007a8bd108b2ed
csd : D07e00320f5903ffffffffe78a4000d1
emmc boot information
revision 1.7 (for mmc v5.0, v5.01)
boot partition : Boot partition 1
partition access : R/w user partition
perm_boot_cfg_prot : Disabled
pwr_boot_cfg_prot : Disabled
boot mode : X4 single data rate + low speed
reset bus width : Enabled
emmc firmw update : Disabled
emmc cache size : 0 kb
super page size : 4096 kb
hc erase group size: 4096 kb
user area size : 15758000128 bytes
boot partition size: 4096 kb
rpmb partition size: 4096 kb
emmc device information
manufacturer id: Toshiba
device type : Embedded bga
application id : 00
product name : 400073
product rev : 0.0
product sn : 7a8bd108
manufactured : January 1999
card specific data
csd_structure : Extended
spec_vers : Version 4.1/4.2/4.3
taac : 8000 ns
tran_speed : 4000000 khz
read_bl_len : 512 bytes
c_size : High capacity
wp_grp_enable : Yes
write_bl_len : 512 bytes
content_prot_app : No
perm_write_protect: No
tmp_write_protect : No
extended csd saved:
110100343030303733007a8bd108b2ed.ext_csd
backup directory:
C:\advancebox turbo flasher\emmc\ext_csd\
start writing flash images...
Flash image: Sboot.bin
start writing 0x00002000 blocks at 0x00000000
partition selected: Boot 1
total elapsed time 00:00:07
write success!
Flash image: Cm.bin
write success!
Total images written: 2
process done!
Old 04-02-2016, 20:41   #177 (permalink)
toninhosantos's Avatar
Member: 1320000
Sonork: 100.1667898
Thanks Meter: 272
Maybe if you write only sboot.bin in boot1 and only cm.bin in boot 2 work.
Old 04-03-2016, 11:12   #178 (permalink)
Member: 1873398
Thanks Meter: 149
boot_1_0x00000000000_0x00000001FFF
boot_2_0x00000000000_0x00000001FFF
user_area_0x00000000000_0x0001FFFFE00
1101003430303037330080D99B8CA2BD.ext_csd
Old 04-03-2016, 11:40   #179 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
TESTED VERY MUCH!!! THANKS ATF TEAM !!!
OHWRYT...
J-TAG/TANIM MODE ( pwedi pa pala kamay at mata ko sa taniman hihi )
DONE
BOOTLOADER ALIVE
The Following User Says Thank You to bronce For This Useful Post:
Old 04-04-2016, 08:18   #180 (permalink)
kishore ch's Avatar
Member: 642004
Thanks Meter: 100
hello atf box support emmc cable 4 in 1 ?? 5 in 1 ?? which is the best emmc Cable all supported plz
Page generated in 0.29976 seconds with 10 queries
