Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-04-2016, 10:56   #181 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,994
Originally Posted by kishore ch View Post
hello atf box support emmc cable 4 in 1 ?? 5 in 1 ?? which is the best emmc Cable all supported plz
After 2 years too this question????
But not to see a LOT of Thread and post where's 5 in 1 is FAKE CABLE and must need of modific all for work with Atf?
Use 4 in 1 V3 from SmartGsm, can find also in "GsmServer", since seem that Website of SmartGsm is Off-Line.
Old 04-04-2016, 16:13   #182 (permalink)
Member: 621121
Thanks Meter: 340
please add verify after write option in next update
Old 04-04-2016, 18:43   #183 (permalink)
allumts's Avatar
Member: 1564612
No need of Add nothing.
Can ceck by yourself BOOT 1 opened with Notepad if is Blank or how this example, not to loock model of phone, loock Notepad File for Ceck BOOT1, here: Repair TOTALLY DEAD i9300/N7100 Without Removing eMMC - WITH PICTURES
allumts
Old 04-06-2016, 10:51   #184 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
please help me to solve this problem
ERROR: EMMC WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
CMD1 Reply: 0x00000000
Old 04-06-2016, 14:41   #185 (permalink)
Member: 224075
Thanks Meter: 50
please help
i have ATF adapter 4in1 V3
i didnt know where to resold v2.8 from phone board to adapter
my adapter have this points
GND
VBAT
3V3
1V8
CMD
CLC
DATA0
CLK2
RESET
2V8
Old 04-06-2016, 14:58   #186 (permalink)
allumts's Avatar
Member: 1564612
Solder 2 Wires thogheter in 3V3 then one connect in VCC and other in VCCQ in EMMC pinout.
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 04-08-2016, 09:13   #187 (permalink)
kbgsm2014's Avatar
Member: 2140248
Thanks Meter: 165
Dear Sir Plz Help me Yesterday I Have Flash J700H/DS After Flash Set Dead i m Confused...
WhenI Try To scan emmc always get This Error Plz Tell me What Thing Wrong
13:07:51 : ======================================================
13:07:51 :        eMMC Test Point Connection Module
13:07:51 :
13:07:51 : 1. DO NOT USE THE PHONE"S BATTERY
13:07:51 : 2. Connect the Soldered TP Connections to ATF Box
13:07:51 : 3. Disconnect the USB Cable and Wait until the
13:07:51 :    the ATF Software will tell you to Connect the USB.
13:07:51 :
13:08:58 : ERROR: EMMC WAS NOT Detected! (CMD1)
13:08:58 : Check your Test Point Soldering!
13:08:58 : CMD1 Reply: 0x5E5E5E5E
Old 04-08-2016, 17:03   #188 (permalink)
Member: 1269161
Thanks Meter: 83
hi
i solder all ok and test with scan emmc is ok
but with flash file downloaded with sn of phone i have this error:
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034203030373300A45EBAA6A231 (CRC7 Fail 0xFB)
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION     : NOT BOOT ENABLED
PARTITION ACCESS   : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT  : DISABLED
BOOT MODE          : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH    : ENABLED
eMMC FirmW UPDATE  : DISABLED
EMMC CACHE SIZE    : 0 KB
SUPER PAGE SIZE    : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE     : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type    : Embedded BGA
Application ID : 00
Product Name   : 4 0073
Product Rev    : 0.0
Product SN     : A45EBAA6
Manufactured   : January 1999
Card Specific Data
CSD_STRUCTURE     : Extended
SPEC_VERS         : Version 4.1/4.2/4.3
TAAC              : 8000 ns
TRAN_SPEED        : 4000000 KHz
READ_BL_LEN       : 512 Bytes
C_SIZE            : HIGH CAPACITY
WP_GRP_ENABLE     : YES
WRITE_BL_LEN      : 512 Bytes
CONTENT_PROT_APP  : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034203030373300A45EBAA6A231.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
Old 04-09-2016, 23:31   #189 (permalink)
Member: 205475
Thanks Meter: 176
Originally Posted by .:B-A-G:. View Post
hi
Interface Reset OK!
Application ID : 00
Product Rev    : 0.0
Card Specific Data
TAAC              : 8000 ns
WP_GRP_ENABLE     : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
MBR is Corrupted...
just use pit file and u will success
Old 04-10-2016, 20:58   #190 (permalink)
Member: 2033821
Thanks Meter: 2
hi..my phone skhynix cpu j700f dd...write last frimware j700f india samfrimware write complate with atf not work...plz help me
Old 04-11-2016, 06:47   #191 (permalink)
Member: 257603
Sonork: 100.1605284
Thanks Meter: 138
j700f/dd not able to write boot file
Interface Reset OK!
CID : 11010034303030373300929D940FA283
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
SUPER PAGE SIZE : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : 929D940F
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
11010034303030373300929D940FA283.ext_csd
Backup Directory:
Start Writing Flash Images...
Old 04-13-2016, 10:08   #192 (permalink)
Member: 2559153
hi
i need driver SECS5PC210 B/D
please help me
Old 04-13-2016, 10:19   #193 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 197
yes brother i have same problem after jitage it
hi
please help me
thats ur driver link
SEC S5PC110 TEST B/D Drivers
The Following User Says Thank You to ghr For This Useful Post:
Old 04-13-2016, 10:22   #194 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 197
see my post
3X EasyJtag Software ver. 2.0.7.6
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0B00A018B9D80701, ,FW Ver.: 01.52
CMD Pullup Level:1258 mV
CMD Active Level:2186 mV
HiPower™ mode is ON!
EMMC CID : 110100343030303733002996114DB2FC
EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 11/2015 Rev.0x0
EMMC NAME: 400073 , S/N: 697700685
EMMC NAME (HEX): 34303030373300
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: 400073_ 697700685_20160402_1521.extcsd
Done.
Processing file...C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin
Processing file...C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin
extCSD Are not selected , skip writing extCSD
Z3X EasyJtag Software ver. 2.0.7.6
Skip loading eMMC Addon Firmware
Input file : C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin
Writing 0000400000 bytes to 00000000 ...ROM1 (USER ROM)
Full Verify Enabled!
Done. Write Speed: 449 kB/s
Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 379 kB/s
Input file : C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin
Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 380 kB/s
every thing is done but only sec-spc210 test b/d driver needed soualtion badly
Old 04-14-2016, 08:58   #195 (permalink)
Member: 2183673
Sonork: 100.1667189
Thanks Meter: 24
Very good upadates ATF team.... Feel the power with ATF.
Page generated in 0.39207 seconds with 8 queries
