Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-27-2016, 06:04   #211 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 689
J700H dead after flash,
i have tried 3 different firmwares via atf emmc jtag, write success but still dead.
this is chip of J700H, does it support or which firmware need this cpu?
Old 04-27-2016, 08:23   #212 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
read my previous posts in this thread you will get answer
Sent from my SM-N910C using Tapatalk
Old 04-27-2016, 08:34   #213 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 689
bro, my english is very weak, i can't understand your previous posts, which is correct answer ?
Old 04-27-2016, 08:37   #214 (permalink)
Member: 1629153
hataw talaga ang atf boss.
Old 04-27-2016, 08:43   #215 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
So i can't write in urdu contact me in private
Old 04-27-2016, 09:03   #216 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 183
PakFones can u accpted my request on skype
Old 04-27-2016, 09:17   #217 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 689
is there any other DATA POINT in J700H ?
i lost DATA POINT.
Old 04-27-2016, 09:17   #218 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 689
PakFones bro, Plz accept my request on skype
Old 04-27-2016, 09:55   #219 (permalink)
medie's Avatar
Member: 181277
Thanks Meter: 82
what about this error
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034303030373300178C146972A9
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : 178C1469
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034303030373300178C146972A9.ext_csd
Backup Directory:
F:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: sboot.bin
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Operation Cancelled...
EMMC Connect Error
Total Elapsed Time 00:09:36
ERROR: Write FAILED!
Process Cancelled...
Old 04-27-2016, 10:52   #220 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
EMMC Connect Error
You pressed cancel before complete operation if it take much time to write or detecting emmc again and again this may problem in software configuration.
Old 04-28-2016, 14:37   #221 (permalink)
medie's Avatar
Member: 181277
Thanks Meter: 82
it stopped here what could be th prob
Interface Reset OK!
CID : 110100343030303733001E79AE84A2A9
Application ID : 00
Product Rev : 0.0
Product SN : 1E79AE84
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
110100343030303733001E79AE84A2A9.ext_csd
Backup Directory:
Old 04-30-2016, 12:04   #222 (permalink)
Member: 1586115
Thanks Meter: 14
how to samsung a300fu jtag pinout
Old 04-30-2016, 14:39   #223 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
i have not seen any success report about a300fu but i have not any phone for test.
Old 04-30-2016, 16:43   #224 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,708
Search by yourself Pinout with this easy guide: ===>>> ATF eMMC Test Point Finder Tutorial <<<===
Then just Write Bootloader direct in EMMC how for J700F/H/K/MP/8/ and you have phone alive other time.
It's Qualcomm Based, so useless try with Sdc File becouse NOT WORKING, also shorting CMD point "TP" it's ok for Exinos Based phones.
NOTE: Samethingh for A500FU and all these series
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 04-30-2016, 18:01   #225 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 360
i have ip-part 4 in 1 v2 cable but cant connect the set also i try to 100 ohms ris to 3.3 to cmd and data o but still cant connect
can u tell me atf team this cable working or i buy new cable??
Page generated in 0.34775 seconds with 8 queries
