Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-04-2016, 12:27   #241 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
Thanks for reporting the file link can be found below Remove space from link.
w w w . s a m m o b i l e.com/firmwares/download/70263/J700FXXU2APD6_J700FOJV2APD1_TUR/
The Following User Says Thank You to >>PakFones<< For This Useful Post:
Old 05-05-2016, 17:11   #242 (permalink)
zulfqarali's Avatar
Member: 1273573
Sonork: 100.1623251 QQ.2905713135
Thanks Meter: 3,733
Originally Posted by allumts View Post
@zulfqarali,
Where's the second resistor?
sir i cant underrstant about 2nd resistor
In Adapter are 2 Resistor of 100 Ohms
sir i cannt understand also these 2 resister of 100 ohms in adapter please help me step by step
From V.3.3 to Data0 and CMD, you connection is WRONG.
sir on my board resistance between data and v2.8 is misssing then iput 100ohms resistance between cmd and v2.8 then i write file of diffrent versions writing is succes but set is still dead if im wrong then plzzzz kindly help me
Why you write all these partition lol? Only Cm.bin and Sboot.bin as Boot1 and Boot2 are enough.
Why not read carefully prvious page?...Modific all and report here you Success.
allumts
sir please tell me about this it is right or wrong ??
(When i Press Power Button Continously Then File Write Properly And When i Release Power Button Then file writing Process is Stoped)
i tried also v2.8 & v3.3 set conecting is ok
v2,8 write file done this ver file-J700HXXU1AOK5_J700HOJV1AOK6_J700HXXU1AOK8_HOME.tar
& use this ver file..
SM-J700Hver 5.1.1--1_20160115111040_vrbiyt9hvt_fac
SM-J700H_ 1_20160115111040_vrbiyt9hvt_fac
J700HXXU1AOG9_J700HOJV1AOGA
J700HXXU1AOFG_OXY1AOFG
J700HXXU1AOJ5_J700HOJV1AOI1_J700HXXU1AOJ5_HOME.tar
BL_J700HXXU1APA3
Plz Sir Corrcet Ver & Guide Me Step By Step
Br.
JAMIL MOBILE
The Following User Says Thank You to zulfqarali For This Useful Post:
Old 05-07-2016, 23:09   #243 (permalink)
Member: 777714
sam problem with me any solution
Old 05-07-2016, 23:33   #244 (permalink)
Member: 777714
when i try to repair sm-j700f dead boot repair showing pit error.
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034303030373300A35A25EFA22F
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : A35A25EF
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034303030373300A35A25EFA22F.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
when i try with pit again show another error
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Old 05-07-2016, 23:34   #245 (permalink)
Member: 777714
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Report Post
any solution plzplzplz
Old 05-08-2016, 00:07   #246 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,706
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Report Post
Try with this PIT: EXYNOS_7_OCTA_7580
allumts
Old 05-08-2016, 10:52   #247 (permalink)
muhammad.arif09's Avatar
Member: 1951379
Sonork: 100.1647567
Thanks Meter: 137
where is emmc master
mr
chand_gee theise days any one now he is offline sincs 2 month
i need to talk
Old 05-08-2016, 23:21   #248 (permalink)
Member: 777714
sam proplem
help plz plz plz
Old 05-09-2016, 17:10   #249 (permalink)
Member: 777714
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Report Post
Old 05-09-2016, 19:49   #250 (permalink)
Member: 777714
when i try to repair sm-j700h dead boot repair showing pit error.
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Report Post
Old 05-09-2016, 22:58   #251 (permalink)
Member: 1743808
Thanks Meter: 6
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
Report Post
hi
used latest firmware in live.samsung-updates.com and set speed on 2.5mh
Old 05-09-2016, 23:04   #252 (permalink)
Member: 1743808
Thanks Meter: 6
hi
i direct my j700h and repair with sboot and cm only with this firmware "SER-J700HXXU2APC5-20160406233018_2" my phone powerd on and came downloading screen i flash it with same firmware it came on samsung logo and dead again and never powerd on and i can not direct again (in first time after power my phone amper was 25/100 and second time is 25/100)
please hellp me
thx
Old 05-10-2016, 23:55   #253 (permalink)
Member: 777714
sam proplem
plas help
plz plz plz
Old 05-11-2016, 17:44   #254 (permalink)
Member: 22466
Thanks Meter: 193
Originally Posted by alamgir80 View Post
can i use this pinout ?
or must need ATF JTAG PLUS ATF 4 IN 1 ADAPTOR
I have only atf big box. don't have adapter.
can u help me wit connections
Old 05-11-2016, 19:24   #255 (permalink)
allumts's Avatar
Member: 1564612
And not see that this connection is for Atf Big from RJ45 cable?
More clear of this @X-Shadow cannot post, and you ask for connection...
Page generated in 0.62567 seconds with 8 queries
