05-28-2016, 13:05 | #273 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: india
Member: 2111064 Status: Offline Thanks Meter: 21 | @support i have a few questions about J700H dead boot repair? 1. iam using the big old ATF metal box with modified pcb! so the adaptor 4in1 ver2 from smartgsm connects in the extension port of the big box right? 2. if the CPU chip is changed (mine is HYNIX) compared to the illustraed ELPIDA the testpoints remain the same? pls see the link below for the EMMC i think its almost the same as the firstpost! https://drive.google.com/file/d/0B4E...ew?usp=sharing 3. if iam using ATF adaptor Ver 2 from smartgsm do i need any modification to the adaptor pcb? 2. i already have a switch on the for exynos so i dont need to toggle it for connecting this model right? all this is coz after the testpoint connections, the ATF box cant find the emmc chip always not found! Quote:
WBR Atstech | |
05-28-2016, 13:27 | #274 (permalink) | ||||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, Quote:
READ this thread and find all info you search, not wait all in you handles, same thing for Adapter V2 read Sticky thread. Where's Photo with you connection in EMMC pinout? If not know these Basic things, not touch this phone, sent to other good Shoop with good technician first you damage all phone. | ||||
05-29-2016, 14:44 | #275 (permalink) |
No Life Poster Join Date: Apr 2013 Location: The Galaxy Age: 34
Member: 1923587 Status: Offline Sonork: 100.1658149 Thanks Meter: 543 | hello i am facing this ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010034303030373300ADE3ACECB2AB CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : ADE3ACEC Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010034303030373300ADE3ACECB2AB.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! i thear sumting i am mising or what pls help me.....!! |
05-30-2016, 11:37 | #277 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Quote:
================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010034303030373300CCBB4969A215 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : CCBB4969 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010034303030373300CCBB4969A215.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:22 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:08 Write Success! Total Images Written: 3 Process Done! writing sucess but still fone is dead tried with this both J700FXXU1AOL2_J700FODD1AOL1_J700FXXU1AOL3_HOME.tar .md5 BL_J700FXXU2APC4_CL1002452_QB8911862_REV00_user_lo w_ship.tar.md5 | |
05-30-2016, 11:40 | #278 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Where i've writed of flash also "User Area"?. Why are Lazy and NOT read the Easy step in first post, you have also TOSHIBA EMMC more more easy of repair. Here for Lazy peoples: http://forum.gsmhosting.com/vbb/11625721-post1.html Br Last edited by allumts; 05-30-2016 at 11:45. |
05-31-2016, 20:09 | #279 (permalink) | |
Member: 2111064 Status: Offline Thanks Meter: 21 | Quote:
can we skip the 4in 1 adaptor and connect it direcrtly thru rj45 cable to the extension port of the box like lumia to repair dead boot? pls inform! wbr | |
05-31-2016, 20:45 | #280 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
FORGOT EXTENSION PORT, it's ok only for JTAG and one type of Nokia, for all that's EMMC Direct repair must need the RJ45 Port. NOTE: Must need of solder 2 pull up resistor of 100ohms in 2 wires output from this cable 8 pin. Br allumts | |
06-03-2016, 11:29 | #281 (permalink) | |
tks for your help! i think my 4 in 1 adaptor is faulty! i tried with other box and i was able to write boot, but unfortunately i think i have spoilt the emmc chip as it detects as some SEC SPS510 device! which after extensively searching i think is an emmc problem! anyway just weanted to let u know! wbr | |
06-03-2016, 11:37 | #282 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Can reset to Factory and repair you EMMC w/o replace this, just find FW Update for you EMMC type: http://forum.gsmhosting.com/vbb/f609...m-n-o-1936304/ Or can read How do with this example Step by Step for I9300/N7100 EMMC: http://forum.gsmhosting.com/vbb/f609...tures-1945278/ Br |
