Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-16-2016, 22:21   #286 (permalink)
Member: 2570643
for me
for me repire don
but no screen and download mod
help
plzzzzz
Old 06-20-2016, 18:59   #287 (permalink)
Member: 1770616
Thanks Meter: 62
ATF team need help, the same mistake that others give them giving me battle ...
First I tried with all these rom to see if the problem is the rom but with all the same.
Second pit have proven several including those who are here is the thread.
I re-soldered third pinount several times and still like someone who has solved the problem
Data of the team:
J700H / DS
Adapter 4 in one.
Old 06-21-2016, 21:52   #288 (permalink)
Member: 1218019
Thanks Meter: 6
j700h/ds write done, but still dead
22:19:39 : Samsung TAR+MD5 File Detected!
22:19:39 : Checking Flash File MD5 HASH...
22:19:40 : FILE MD5 HASH : 75EB0727CE288D581EF0530BCCAD76EB
22:20:32 : CALC MD5 HASH: 75EB0727CE288D581EF0530BCCAD76EB
22:20:32 : Checking Flash Images inside TAR...
22:31:23 : WARNING: Write Operation Cancelled
22:31:24 : ================================================== ====
22:31:24 : eMMC Test Point Connection Module
22:31:24 :
22:31:24 : 1. DO NOT USE THE PHONE"S BATTERY
22:31:24 : 2. Connect the Soldered TP Connections to ATF Box
22:31:24 : 3. Disconnect the USB Cable and Wait until the
22:31:24 : the ATF Software will tell you to Connect the USB.
22:31:24 :
22:31:24 :
22:31:24 : Interface Reset OK!
22:31:24 : eMMC Access Type: SECTOR MODE
22:31:24 : eMMC Supported Voltage Range:
22:31:24 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
22:31:24 :
22:31:24 : CID : 110100343030303733009A59D122B2B9
22:31:24 : CSD : D07E00320F5903FFFFFFFFE78A4000D1
22:31:24 :
22:31:24 : eMMC Boot Information
22:31:24 : Revision 1.7 (for MMC v5.0, v5.01)
22:31:24 : BOOT PARTITION : BOOT PARTITION 1
22:31:24 : PARTITION ACCESS : R/W USER PARTITION
22:31:24 : PERM_BOOT_CFG_PROT : DISABLED
22:31:24 : PWR_BOOT_CFG_PROT : DISABLED
22:31:24 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
22:31:24 : RESET BUS WIDTH : ENABLED
22:31:24 : eMMC FirmW UPDATE : DISABLED
22:31:24 : EMMC CACHE SIZE : 0 KB
22:31:24 : SUPER PAGE SIZE : 4096 KB
22:31:24 : HC ERASE GROUP SIZE: 4096 KB
22:31:24 : USER AREA SIZE : 15758000128 BYTES
22:31:24 : BOOT PARTITION SIZE: 4096 KB
22:31:24 : RPMB PARTITION SIZE: 4096 KB
22:31:24 :
22:31:24 :
22:31:24 : eMMC Device Information
22:31:24 : Manufacturer ID: TOSHIBA
22:31:24 : Device Type : Embedded BGA
22:31:24 : Application ID : 00
22:31:24 : Product Name : 400073
22:31:24 : Product Rev : 0.0
22:31:24 : Product SN : 9A59D122
22:31:24 : Manufactured : January 1999
22:31:24 :
22:31:24 : Card Specific Data
22:31:24 : CSD_STRUCTURE : Extended
22:31:24 : SPEC_VERS : Version 4.1/4.2/4.3
22:31:24 : TAAC : 8000 ns
22:31:24 : TRAN_SPEED : 4000000 KHz
22:31:24 : READ_BL_LEN : 512 Bytes
22:31:24 : C_SIZE : HIGH CAPACITY
22:31:24 : WP_GRP_ENABLE : YES
22:31:24 : WRITE_BL_LEN : 512 Bytes
22:31:24 : CONTENT_PROT_APP : NO
22:31:24 : PERM_WRITE_PROTECT: NO
22:31:24 : TMP_WRITE_PROTECT : NO
22:31:24 :
22:31:24 : Extended CSD Saved:
22:31:24 : 110100343030303733009A59D122B2B9.ext_csd
22:31:24 : Backup Directory:
22:31:24 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
22:31:24 :
22:31:24 :
22:31:24 :
22:31:24 :
22:31:24 : Start Writing Flash Images...
22:31:24 :
22:31:24 :
22:31:24 :
22:31:24 : Flash Image: sboot.bin
22:31:25 : Start Writing 0x00002000 Blocks at 0x00000000
22:31:25 : Partition Selected: BOOT 1
22:31:33 :
22:31:33 : Total Elapsed Time 00:00:08
22:31:33 : Write Success!
22:31:33 :
22:31:33 :
22:31:34 : Flash Image: cm.bin
22:31:35 : Start Writing 0x00002000 Blocks at 0x00000000
22:31:35 : Partition Selected: BOOT 2
22:31:42 :
22:31:42 : Total Elapsed Time 00:00:08
22:31:43 : Write Success!
22:31:43 :
22:31:43 :
22:31:43 : Total Images Written: 2
22:31:43 : Process Done!
have solution for this dead body?
The Following User Says Thank You to nezlos For This Useful Post:
Old 06-22-2016, 23:53   #289 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,823
Try with Last Fw released from "Sammobile"....same procedure and if go in D.Mode, (can forfe also), flash Full stock fw used for Dead Boot repair.
allumts
Old 06-22-2016, 23:59   #290 (permalink)
Member: 1218019
Thanks Meter: 6
allumts
SER_J700HXXU2BPF2_20160606125827 i try this fw. all done. but this body still dead. no d. mode, no logo.
Old 06-23-2016, 00:13   #291 (permalink)
allumts's Avatar
Member: 1564612
Change country code fw
The Following User Says Thank You to allumts For This Useful Post:
Old 06-23-2016, 00:44   #292 (permalink)
dilbarkhan's Avatar
Member: 1814786
Sonork: 100.1619255
Thanks Meter: 29
But how About A5000 Can that be Done with it ?????
Sent from my iPhone using Tapatalk
Old 06-23-2016, 09:39   #293 (permalink)
Member: 1218019
Thanks Meter: 6
i change 3. but still dead. not universal boot in this phone(j700h/ds)?
Old 06-25-2016, 22:20   #294 (permalink)
Member: 205475
Thanks Meter: 175
can i use marshmallow firmware to revive it ?
thanx
Old 06-26-2016, 11:08   #295 (permalink)
allumts's Avatar
Member: 1564612
thanx
And why cannot?....yes can use!!!
Old 06-26-2016, 12:48   #296 (permalink)
Member: 205475
Thanks Meter: 175
ok
cause i use it and phone not boot stll dead.
mobile dead by downgrade
Old 06-27-2016, 13:35   #297 (permalink)
kamiran's Avatar
Member: 223973
Thanks Meter: 150
have any one found real solution yet ?? i have got one j700h/ds dead by downgrade .... tried with many latest firmware but no luck phone wont turn on.....
[email protected]
Old 06-27-2016, 16:18   #298 (permalink)
Crazy Poster
Member: 1863808
Thanks Meter: 3
i have atf adapter and i want to know what colour is 2.8 v i have 7colours brown and yellow and orange and red and blue and green how i can connect to borad
wait u help please
Old 06-27-2016, 18:29   #299 (permalink)
allumts's Avatar
Member: 1564612
wait u help please
Hello,
No need of loock ANY colours, loock for CMD, DATA0, CLK ITC...
And the 2 wires from VCC and VCCQ from Pcb goes cottencted TOGHETER in 2.8V in adapter, Total are 6 Wires....
Read Carefully SCREENSHOOT if FIRT PAGE.
Old 06-27-2016, 23:44   #300 (permalink)
Member: 1218019
Thanks Meter: 6
bro allumts. have universal solution for j700h ds? people try many sw and no result what we're doing wrong? It may have paid secrets?
Page generated in 0.39454 seconds with 8 queries
