06-28-2016, 10:16 | #301 (permalink) | |
Insane Poster Join Date: Jan 2013
Member: 1863808 Status: Offline Thanks Meter: 6 | Quote:
but i am new what is vcc and vccq and where is 2.8 adapter can u give me screenshot can explain to me i have atf jtag 5*1 wait for u reply | |
06-28-2016, 10:40 | #302 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, whats this: Quote:
1) If have Big Atf use RJ45 Cable taking out right Wires and Pull Up resistor 100homs 2) Purchase Good Adapter 4 in 1 of SmartGsm Br | |
The Following User Says Thank You to allumts For This Useful Post: |
06-28-2016, 11:29 | #303 (permalink) | |
1st i have big atf gold 2nd i uploaded pic of atf jtag i just bought yesterday tell me exactly what i do and i am fast learner tell me is this atf jtag is good or in trush or what to do? and thx again | |
06-28-2016, 11:39 | #304 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: could'nt found yet
Member: 223973 Status: Offline Thanks Meter: 155 | Quote:
Br | |
06-28-2016, 11:47 | #305 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Name of this ISN'T "Atf Jtag", but "Adapter 4 in 1", starting Clearing somethings!!! Not For last, This "Adapter 4 in 1" is one Very BAD Copy of the ORIGINAL "4 in 1" adapter of "SmartGsm", so get this in the TRUSH becouse Never can use for Detect EMMC by Atf Sw. Clear now? Have Cheated you, next time Read Stycky Thread and Loock carefully whats is Right or NOT. Br allumts | |
06-28-2016, 11:49 | #306 (permalink) | |
You Not Misguide Other Users, if you Not are able or do any mistake isn't Fault of the procedure. This Procedure is been tested Many times from many Users with SUCCESS, can be you have need only of see where are wrong..... Br | |
06-28-2016, 12:46 | #307 (permalink) |
Member: 223973 Status: Offline Thanks Meter: 155 | the procedure mentioned is not an equation that only Albert Einstein can solve .... EMMC can be connect can write sboot.bin and cm.bin with the latest firmware from sammobile or other sources but phone still wont turn on....i just want other users to wait until ATF Team resolve the Glitch with toshiba emmc and release a new update.... Br |
The Following User Says Thank You to kamiran For This Useful Post: |
06-28-2016, 13:20 | #308 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Any Einstain....only that user now are starting to flash Last BUILD in they phone and when Downgrade you cannot know what Fw had first of downgrade...so now must need of use RIGHT (more High), version of Bootloader that was there first. *** REMEMBER ONE IMPORTANT THING *** The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files. Br |
06-28-2016, 17:23 | #309 (permalink) | |
J700HXXU1APA3 dead by flashing firmware J700HXXU1AOG3_OXY1AOFG used firmware to repair Dead boot J700HXXU2APE3_J700HOXY2APE3 J700HXXU1APA3_J700HOJV1AOK6 J700HXXU2BPF2_J700HOXY2BPF2 let me know if the firmwares used to repair are older... Phone is Still Dead no download mode Br | |
06-29-2016, 11:57 | #311 (permalink) | |
07-01-2016, 17:31 | #315 (permalink) |
Product Supporter Join Date: Oct 2009 Location: Mumbai. Great India
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | Hello, i have SM-j700F phone dead by flashing trying to downgrade by customer, phone come to my hands in dead condition when i try to write sboot and cm file with atf emmc tool software says to select PIT file then i select PIT file and write sboot and cm file and its done this time phone go to download mode but when i try to flash phone with odin give me error there is no pit partition . i need help to solve this problem |
