Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-10-2016, 14:30   #331 (permalink)
Member: 1918840
Thanks Meter: 10
here is log
16:11:15 : 1. DO NOT USE THE PHONE"S BATTERY
16:11:15 : 2. Connect the Soldered TP Connections to ATF Box
16:11:15 : 3. Disconnect the USB Cable and Wait until the
16:11:15 : the ATF Software will tell you to Connect the USB.
16:11:15 :
16:11:15 :
16:11:15 : Interface Reset OK!
16:11:15 : eMMC Access Type: SECTOR MODE
16:11:15 : eMMC Supported Voltage Range:
16:11:15 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
16:11:15 :
16:11:15 : CID : 1101003430303037330088E340F0A219
16:11:15 : CSD : D07E00320F5903FFFFFFFFE78A4000D1
16:11:15 :
16:11:15 : eMMC Boot Information
16:11:15 : Revision 1.7 (for MMC v5.0, v5.01)
16:11:15 : BOOT PARTITION : BOOT PARTITION 1
16:11:15 : PARTITION ACCESS : R/W USER PARTITION
16:11:15 : PERM_BOOT_CFG_PROT : DISABLED
16:11:15 : PWR_BOOT_CFG_PROT : DISABLED
16:11:15 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
16:11:15 : RESET BUS WIDTH : ENABLED
16:11:15 : eMMC FirmW UPDATE : DISABLED
16:11:15 : EMMC CACHE SIZE : 0 KB
16:11:15 : SUPER PAGE SIZE : 4096 KB
16:11:15 : HC ERASE GROUP SIZE: 4096 KB
16:11:15 : USER AREA SIZE : 15758000128 BYTES
16:11:15 : BOOT PARTITION SIZE: 4096 KB
16:11:15 : RPMB PARTITION SIZE: 4096 KB
16:11:15 :
16:11:15 :
16:11:15 : eMMC Device Information
16:11:15 : Manufacturer ID: TOSHIBA
16:11:15 : Device Type : Embedded BGA
16:11:15 : Application ID : 00
16:11:15 : Product Name : 400073
16:11:15 : Product Rev : 0.0
16:11:15 : Product SN : 88E340F0
16:11:15 : Manufactured : January 1999
16:11:15 :
16:11:15 : Card Specific Data
16:11:15 : CSD_STRUCTURE : Extended
16:11:15 : SPEC_VERS : Version 4.1/4.2/4.3
16:11:15 : TAAC : 8000 ns
16:11:15 : TRAN_SPEED : 4000000 KHz
16:11:15 : READ_BL_LEN : 512 Bytes
16:11:15 : C_SIZE : HIGH CAPACITY
16:11:15 : WP_GRP_ENABLE : YES
16:11:15 : WRITE_BL_LEN : 512 Bytes
16:11:15 : CONTENT_PROT_APP : NO
16:11:15 : PERM_WRITE_PROTECT: NO
16:11:15 : TMP_WRITE_PROTECT : NO
16:11:15 :
16:11:15 : Extended CSD Saved:
16:11:15 : 1101003430303037330088E340F0A219.ext_csd
16:11:15 : Backup Directory:
16:11:15 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
16:11:15 :
16:11:15 :
16:11:15 :
16:11:15 :
16:11:15 : Start Writing Flash Images...
16:11:15 :
16:11:15 :
16:11:15 :
16:11:15 : Flash Image: sboot.bin
16:11:16 : Start Writing 0x00002000 Blocks at 0x00000000
16:11:16 : Partition Selected: BOOT 1
16:11:23 :
16:11:23 : Total Elapsed Time 00:00:07
16:11:23 : Write Success!
16:11:23 :
16:11:23 :
16:11:23 : Flash Image: param.bin
16:11:24 : Start Writing 0x00004000 Blocks at 0x0001A800
16:11:24 : Partition Selected: USER AREA
16:11:43 :
16:11:43 : Total Elapsed Time 00:00:19
16:11:43 : Write Success!
16:11:43 :
16:11:43 :
16:11:43 : Flash Image: cm.bin
16:11:44 : Start Writing 0x00002000 Blocks at 0x00000000
16:11:44 : Partition Selected: BOOT 2
16:12:05 :
16:12:05 : Total Elapsed Time 00:00:21
16:12:05 : Write Success!
16:12:05 :
16:12:05 :
16:12:05 : Total Images Written: 3
16:12:05 : Process Done!
Old 07-12-2016, 12:06   #332 (permalink)
Member: 1218019
Thanks Meter: 6
boot successfully restored. body go to download mode. but i cant flashing body. in odin an error pit not found. i try 4-files firmware. i try pit. but repartion filed. for boot i used J700HXXU2APE3_J700HOXY2APE3_CAU. which pit file to use?
Old 07-13-2016, 09:28   #333 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 812
resistor for vcc + cmd is broken, may i know the value of this resistor?
Old 07-13-2016, 10:50   #334 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 13,639
did anybody tried to write boot from version 6.0.1??
Old 07-13-2016, 11:43   #335 (permalink)
Member: 1418143
Thanks Meter: 324
yeah I did it, but phone still dead .
Old 07-13-2016, 11:50   #336 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,707
CMD resistor Value is 10K.
VCC isn't Resistor but CAPACITOR, just ceck value from other same phone.
FOR ALL: Not use Last Build 6.0.1, Samsung has disabled some Function and is useless use this FW.
allumts
The Following 3 Users Say Thank You to allumts For This Useful Post:
Old 07-13-2016, 11:56   #337 (permalink)
Member: 1418143
Thanks Meter: 324
allumts
thank br .
Old 07-13-2016, 13:50   #338 (permalink)
Member: 95960
Sonork: 100.1574721
allumts
what is the last version you test ??
Old 07-13-2016, 14:29   #339 (permalink)
allumts's Avatar
Member: 1564612
Depend of what model is you phone and if is QUALCOMM or Exinos....for QUALCOMM NOT use Last BUILD...only 5.1.1 of 2015 (october).
Important is what CPU mount.....
Old 07-14-2016, 12:09   #340 (permalink)
Member: 95960
Sonork: 100.1574721
i am taling about J700H
Old 07-14-2016, 14:42   #341 (permalink)
AgicAga's Avatar
Member: 866455
Sonork: 1669362
Thanks Meter: 246
Mega File Upload - J7E3G_EUR_OPEN.pit
Old 07-14-2016, 22:07   #342 (permalink)
Member: 1218019
Thanks Meter: 6
Originally Posted by AgicAga View Post
thanks, bro. I tried this file. I tried in odin, but with any firmware version error. repartion filed. I tried repation in emmc direct. software says everything is successful, but in odin error pit file not found. what am I doing wrong?
Old 07-18-2016, 00:20   #343 (permalink)
Member: 205475
Thanks Meter: 175
ok
this firmware tested and working good
J700HXXU2BPF2_J700HOXY2BPF2_SER 6.0.1
The Following User Says Thank You to anasshe For This Useful Post:
Old 07-19-2016, 20:43   #344 (permalink)
Member: 2548079
Hello sir I have atf box and jtag but I dont know how to use it please help
Old 07-20-2016, 18:40   #345 (permalink)
Member: 942321
samsung J700H ,i was repair boot succesfully but phone not power on.
i can not flash to repaire phone.
i have try 5 firmwares and android 6.0.1 ,same probleme .
who have solution for me thanks
phone is coming to UAE (LYS) language
Page generated in 0.39092 seconds with 8 queries
