Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-15-2016, 19:06   #361 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Or have used Wrong connection or this EMMC is broken, no P.Name and any Datas or Partitions.
Have resetted All....how want write only the 2 file from "Bootloader" Fw ?????...
Old 08-20-2016, 18:48   #362 (permalink)
Member: 1673356
Thanks Meter: 2
Excuse the question, what version of atf should I buy? (nitro, box or GoldBox) activation or what should I have? to repair boot J7 with atf
thanks
Old 08-24-2016, 22:41   #363 (permalink)
allumts's Avatar
Member: 1564612
thanks
Can purchase Atf Gold, (coming with All activaction inside) + SmartGsm 4 in 1 V3 adapter and haven't any issue for activaction or connection by EMMC Direct..
Old 08-29-2016, 13:34   #364 (permalink)
Member: 1418143
Thanks Meter: 353
seem the Problem is emmc brand , All Toshiba I did work without problem .
but my last time I failed was a skhynix emmc , i tried even 6.0
Old 09-01-2016, 18:18   #365 (permalink)
Member: 26041
Thanks Meter: 160
What the procedures to revive j700h, I tried on 2 phones with Toshiba emmc always stuck on sboot flashing, what wrong I did...?
Old 09-07-2016, 15:09   #366 (permalink)
Member: 2621792
Thanks Meter: 2
I have problem with J700H my atf box say when I scan eMMC
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
ERROR: EMMC WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
CMD1 Reply: 0x00000000
Is that my phone emmc is not good or what? please
Old 09-07-2016, 17:37   #367 (permalink)
allumts's Avatar
Member: 1564612
I'snt good you connection, EMMC Not detected, ceck carefully connection and try.
Old 09-08-2016, 06:01   #368 (permalink)
Member: 2621792
Thanks Meter: 2
I already check and resoldering it twice but same problem.
Old 09-08-2016, 09:42   #369 (permalink)
allumts's Avatar
Member: 1564612
Hello, this error is very clear: EMMC not detected.
Post CLEAR photo of connection you are using.
Old 09-09-2016, 09:48   #370 (permalink)
Member: 2621792
Thanks Meter: 2
Can I use SDC tool to repair samsung J700H/DS
Old 09-19-2016, 09:35   #371 (permalink)
Member: 2478245
Sonork: 100.1669922:JOTECH
Thanks Meter: 10
Sm-j700h emmc boot repair write error
PLEASE CAN SOMEONE HELP ME OUT AS TO WHAT COULD BE WRONG WITH MY TRYING TO REPAIR THE BOOT
OF SM-J700H WHICH FAILED TO BOOT AFTER FLASHING A BOOLOADER FILE(BL_J700HXXU1AOG3_CL679261_QB5534807_REV00_use r_low_ship.tar)
THE PHONE CONNECTED OK WITH ATF EMMC REPAIR TOOL BUT WOULD NOT WRITE THE REQUIRED FILES BEYOUNG 12% AND THE KEEP RETYING.
PLEASE WHAT COULD BE WRONG?
Old 09-19-2016, 20:33   #372 (permalink)
allumts's Avatar
Member: 1564612
No, only by EMMC Direct.
Old 09-19-2016, 20:45   #373 (permalink)
allumts's Avatar
Member: 1564612
What File have flashed in EMMC?...you have need only these 2 file: S.Boot.bin and Cm.bin any other.
When have writed these 2 file with Success in EMMC then reflash with Same FW used for Repair from Dead Boot.
*** REMEMBER ONE IMPORTANT THING ***
The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files.
allumts
Old 09-20-2016, 09:02   #374 (permalink)
Member: 2478245
Thanks Meter: 10
allumts
THANKS WHAT I DID WAS CHOOSING THE COMPLETE TAR FILE(J700HXXU2BPF9_J700HOJV2BPF4_J700HXXU2BPF2_HOM E_.tar) WHICH IS THE LATEST 6.0.1 ) COS THERE ARE NO SPLIT FILE FOR THE LATEST VERSION NAD AFTER AWHILE THE EMMC TOOL ITSELF WAS ABLE TO FIGURE OUT THE REQURED FILE WHICH IS THE sboot.bin and the Cm.bin. my problem was that when i click on write or start tab it starts to write the file and eventually stopped at 12%. i post the sceenshot alongside
Old 09-20-2016, 09:19   #375 (permalink)
allumts's Avatar
Member: 1564612
If use Stock rom must be in .Tar.Md5 not only in .Tar.
I not see any Log or screenshoot.
Page generated in 0.23199 seconds with 10 queries
