Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-21-2016, 18:35   #376 (permalink)
Member: 2478245
Sonork: 100.1669922:JOTECH
Thumbs down Sm-j700h emmc boot repair write error
Please Allumt, my problem was that i was not allow to post an attachment, i really wanted to post the screen shot of the operation. i quite understood that i needed tar.Mds file which was what i really used but the problem was that when i clicked on start to write the phone, it connected quite ok but when it start writing and gets to 12%, it stooped and keep retrying. i have 2 pieces of these type of phones( SM-J700H) which goes dead when trying to do the FRP reset via flashing. please what could cause the inability of the software in writing to the phone EMMC
Old 09-22-2016, 17:10   #377 (permalink)
lamran's Avatar
Member: 352958
Sonork: 100.1585201
Thanks Meter: 119
hi guy
have j700h/ds
but getting this error
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034303030373300E15741AAA219
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : E15741AA
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034303030373300E15741AAA219.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
Old 09-25-2016, 08:33   #378 (permalink)
ddilshod93's Avatar
Member: 2082192
Thanks Meter: 949
Originally Posted by lamran View Post
hi guy
have j700h/ds
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Hi bro
please see logs
MBR is Corrupted...
your right select Pit files.
Old 09-25-2016, 13:38   #379 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,650
And loock also here:
Here no need only 2 files of Boot but Full Dump in.Bin
Loock Good EMMC:
16:11:15 : SUPER PAGE SIZE : 4096 KB
16:11:15 : HC ERASE GROUP SIZE: 4096 KB
16:11:15 : USER AREA SIZE : 15758000128 BYTES
16:11:15 : BOOT PARTITION SIZE: 4096 KB
16:11:15 : RPMB PARTITION SIZE: 4096 KB
allumts
Old 09-26-2016, 11:08   #380 (permalink)
Member: 2339459
Thanks Meter: 24
SM-J700H boot repair problem ??
Interface Reset OK!
CID : 1101003430303037330070963449C26B
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
Application ID : 00
Product Rev : 0.0
Product SN : 70963449
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
1101003430303037330070963449C26B.ext_csd
Backup Directory:
Start Writing Flash Images...
Flash Image: sboot.bin
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Total Elapsed Time 00:00:04
Write Success!
Flash Image: cm.bin
Partition Selected: BOOT 2
Write Success!
Total Images Written: 2
Process Done!
after repair boot dead stil phone dead plzz help
Old 09-27-2016, 16:51   #381 (permalink)
Member: 2623405
very nice update atfTEAM
Old 10-15-2016, 17:04   #382 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 107
Red face Allumts sir please guide me some
i have atf big chrome and i can make rj45 cable and can sold ...i have seen pinout atf big chrome box rj45 port but i am confused about v2.8....all other things are ok but tell me about this pls rj45 port which pin will be connected to j700h pcb v2.8 point.i am a little bit confused
Old 10-29-2016, 10:14   #383 (permalink)
Member: 1239990
Thanks Meter: 2
please help me . my j700h dead after flash .. now i want pinout of j700h SKhunix cpu inside . help me advance team .. thank you in advance
Old 11-01-2016, 18:32   #384 (permalink)
urshihab's Avatar
Member: 617912
Thanks Meter: 41
Emmc writing done but mobile same condition not working
Interface Reset OK!
CID : 110100343030303733005D635011C27B
Application ID : 00
Product Rev : 0.0
Product SN : 5D635011
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
110100343030303733005D635011C27B.ext_csd
Backup Directory:
Total Elapsed Time 00:00:08
Write Success!
Flash Image: cm.bin
Total Elapsed Time 00:00:07
Write Success!
Flash Image: boot.img
Start Writing 0x00010000 Blocks at 0x0001E800
Partition Selected: USER AREA
Total Elapsed Time 00:00:52
Write Success!
Flash Image: recovery.img
Start Writing 0x00013000 Blocks at 0x0002E800
Total Elapsed Time 00:01:03
Write Success!
Warning: EXT3/4 Image Detected
Skipping system.img...
Flash Image: modem.bin
Start Writing 0x0002C000 Blocks at 0x00047800
Total Elapsed Time 00:02:23
Write Success!
Skipping cache.img...
Skipping hidden.img...
Total Images Written: 5
Process Done!
Old 11-02-2016, 13:54   #385 (permalink)
allumts's Avatar
Member: 1564612
Hello, where you have read of Flash FULL Stock FW?
Only 2 Boot partition need of flash, not also Modem, Hidden.img, cache itc...
Old 11-02-2016, 18:49   #386 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 37
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
Write Success!
Flash Image: cm.bin
Write Success!
Process Done!
check the file u are using.i have done two today .if you can contact me i will give u the file for j700h
Old 11-04-2016, 18:11   #387 (permalink)
Member: 2644984
i repair a lot of j7 with atf box . thats perfect box for emmc
Old 11-10-2016, 07:01   #388 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,222
what type of switching taken by the phone which is JTAG or dead boot ?
I receive phone when press power key stuck at 13 amp
The Following User Says Thank You to HUM For This Useful Post:
Old 02-25-2017, 08:18   #389 (permalink)
Member: 2681131
Thanks Meter: 2
thanks to chand g for boot repeir j700f pinout .
Old 04-23-2017, 19:27   #390 (permalink)
Member: 2220270
Thanks Meter: 8
Originally Posted by bronce View Post
TESTED VERY MUCH!!! THANKS ATF TEAM !!!
OHWRYT...
J-TAG/TANIM MODE ( pwedi pa pala kamay at mata ko sa taniman hihi )
DONE
BOOTLOADER ALIVE
i need tp picture of j700h/ds please
Page generated in 0.41828 seconds with 8 queries
