Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-17-2016, 06:26   #31 (permalink)
Member: 1022207
J700F Boot Repair done
1000% success..... thanks 1st
Old 02-17-2016, 08:08   #32 (permalink)
Member: 1939490
Sonork: 100.1638723
Thanks Meter: 17
GND - GND
CMD - CMD
DATA- DATAO
CLK - CLK
V 2.8 Near CMD - ?
v 2.8 Capasitor - ?
J700F
ON ATF 4 IN 1 ADAPTOR V2
Old 02-17-2016, 09:45   #33 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,726
Originally Posted by mustafa alasfar View Post
I tested. but still not working i dowonlod last flash for j700h and flashed with emmc tool like image but not work any one have any idea for my plzzzz
أرسلت من HTC Desire 816 dual sim بإستخدام تاباتلك
But what flash like Immage? what are searching of say?, "EMMC TOOL IMMAGE CREATOR is one thing Totally difrent from "EMMC DIRECT TP", search of understand good first of post these Big mistake
The Following User Says Thank You to allumts For This Useful Post:
Old 02-17-2016, 09:48   #34 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,726
Originally Posted by ahsan.mt View Post
GND - GND
CMD - CMD
DATA- DATAO
CLK - CLK
V 2.8 Near CMD - ?
v 2.8 Capasitor - ?
J700F
Yes 100% V.2.8 VCC and VCCQ V2.8 goes solder togheter in adapter 4 in 1.
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 02-17-2016, 09:53   #35 (permalink)
Member: 2089529
Thanks Meter: 2
Sorry for my english bro i want to say i applied the steps as the post but still not working
Old 02-17-2016, 10:04   #36 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,726
Post Log and Screen, but also most important what type of EMMC and CPU have in this phone and What Bootloader File have used, if last version or what, Any Stock FW must use.
allumts
Old 02-17-2016, 12:44   #37 (permalink)
Member: 2033821
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
ERROR: EMMC WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
CMD1 Reply: 0x00000000
Old 02-17-2016, 14:01   #38 (permalink)
Member: 1939490
Sonork: 100.1638723
Thanks Meter: 17
Where Can i solder v2.8 near cmd ? - to 2.8 or 3.3 on atf adaptor
V2.8 on capasitor side ,
where connect cable on ATF Big Box Flashbus or Extention?
Old 02-17-2016, 15:36   #39 (permalink)
Member: 2089529
Thanks Meter: 2
allumts
Emmc toshiba + exynos cpu and i use j700hxxu1apa3 this is the last flash
Old 02-17-2016, 15:36   #40 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,726
Yes.
to 2.8 thogheter.
YES.
Flashbus
For other question of this type READ carefully Easy digram and steps in first post!!!
Old 02-17-2016, 15:39   #41 (permalink)
Member: 1939490
Sonork: 100.1638723
Thanks Meter: 17
Done , Success.
https://www.youtube.com/watch?v=Mck1Eto4iKc
Old 02-18-2016, 19:35   #42 (permalink)
Member: 499918
Thanks Meter: 2
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 110100343030303733003D32B2C9B2ED
CSD : D07E00320F5903FFFFFFFFE78A4000D1
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : 3D32B2C9
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
110100343030303733003D32B2C9B2ED.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
Old 02-19-2016, 07:06   #43 (permalink)
toninhosantos's Avatar
Member: 1320000
Sonork: 100.1667898
Thanks Meter: 207
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Try this pit file EXYNOS_7_OCTA_7580 - Download - 4shared
Old 02-19-2016, 07:24   #44 (permalink)
Member: 241705
Thanks Meter: 4,294,967,295
getting this eror again and again test point are ok as in pic
Old 02-20-2016, 05:40   #45 (permalink)
Member: 844312
Sonork: 100.1640471
Thanks Meter: 210
data pin out others pin site help please very hard work so iron soldaring pin out help plsese
solder pin easy pin out emmc repaire
Page generated in 0.45438 seconds with 8 queries
