02-23-2016, 15:23 | #76 (permalink) |
Freak Poster Join Date: Apr 2012 Location: Iran
Member: 1748375 Status: Offline Sonork: 100.1617845 Thanks Meter: 17 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733008BB5272EA2A3 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 8BB5272E Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733008BB5272EA2A3.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:09 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 2 Process Done! Unread messages [4:54:06 PM] |
The Following User Says Thank You to Jimbojump For This Useful Post: |
02-23-2016, 16:03 | #77 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2089529 Status: Offline Thanks Meter: 2 | like me bro my phone still dead what about flash dump ?this dump from diamond J700h-DS - Download - 4shared - Gsm Diamond post your result password = diamond |
02-23-2016, 16:23 | #78 (permalink) | |
Freak Poster Join Date: Nov 2013
Member: 2064519 Status: Offline Thanks Meter: 83 | Quote:
do write all files. ext_csd boot1 boot2 user area boot 1 and boot 2 is 32mb user area is 512mb | |
The Following User Says Thank You to Diamond Gsm For This Useful Post: |
02-24-2016, 20:22 | #81 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TuNiSiA
Member: 462224 Status: Offline Sonork: 100.1586374 Thanks Meter: 103 | hi, i'm stuck here, can't write boot Code: 19:33:37 : eMMC Test Point Connection Module 19:33:37 : ====================================================== 19:33:37 : ====================================================== 19:33:37 : 19:33:37 : 1. DO NOT USE THE PHONE"S BATTERY 19:33:37 : 2. Connect the Soldered TP Connections to ATF Box 19:33:37 : 3. Disconnect the USB Cable and Wait until the 19:33:37 : the ATF Software will tell you to Connect the USB. 19:33:37 : 19:33:37 : 19:33:37 : Interface Reset OK! 19:33:37 : eMMC Access Type: SECTOR MODE 19:33:37 : eMMC Supported Voltage Range: 19:33:37 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 19:33:37 : 19:33:37 : CID : 11010034303030373300AC754955A235 19:33:37 : CSD : D07E00320F5903FFFFFFFFE78A4000D1 19:33:37 : 19:33:37 : eMMC Boot Information 19:33:37 : Revision 1.7 (for MMC v5.0, v5.01) 19:33:37 : BOOT PARTITION : NOT BOOT ENABLED 19:33:37 : PARTITION ACCESS : R/W USER PARTITION 19:33:37 : PERM_BOOT_CFG_PROT : DISABLED 19:33:37 : PWR_BOOT_CFG_PROT : DISABLED 19:33:37 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 19:33:37 : RESET BUS WIDTH : ENABLED 19:33:37 : eMMC FirmW UPDATE : DISABLED 19:33:37 : EMMC CACHE SIZE : 0 KB 19:33:37 : SUPER PAGE SIZE : 4096 KB 19:33:37 : HC ERASE GROUP SIZE: 4096 KB 19:33:37 : USER AREA SIZE : 15758000128 BYTES 19:33:37 : BOOT PARTITION SIZE: 4096 KB 19:33:37 : RPMB PARTITION SIZE: 4096 KB 19:33:37 : 19:33:37 : 19:33:37 : eMMC Device Information 19:33:37 : Manufacturer ID: TOSHIBA 19:33:37 : Device Type : Embedded BGA 19:33:37 : Application ID : 00 19:33:37 : Product Name : 400073 19:33:37 : Product Rev : 0.0 19:33:37 : Product SN : AC754955 19:33:37 : Manufactured : January 1999 19:33:37 : 19:33:37 : Card Specific Data 19:33:37 : CSD_STRUCTURE : Extended 19:33:37 : SPEC_VERS : Version 4.1/4.2/4.3 19:33:37 : TAAC : 8000 ns 19:33:37 : TRAN_SPEED : 4000000 KHz 19:33:37 : READ_BL_LEN : 512 Bytes 19:33:37 : C_SIZE : HIGH CAPACITY 19:33:37 : WP_GRP_ENABLE : YES 19:33:37 : WRITE_BL_LEN : 512 Bytes 19:33:37 : CONTENT_PROT_APP : NO 19:33:37 : PERM_WRITE_PROTECT: NO 19:33:37 : TMP_WRITE_PROTECT : NO 19:33:37 : 19:33:37 : Extended CSD Saved: 19:33:37 : 11010034303030373300AC754955A235.ext_csd 19:33:37 : Backup Directory: 19:33:37 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 19:33:37 : 19:33:37 : 19:33:37 : MBR is Corrupted... 19:33:37 : 19:33:37 : 19:33:37 : Start Writing Flash Images... 19:33:37 : 19:33:37 : Flash Image: MBR + PGPT 19:34:01 : Start Writing 0x00000032 Blocks at 0x00000000 19:34:01 : Partition Selected: USER AREA 19:36:42 : Operation Cancelled... 19:36:42 : EMMC Connect Error 19:36:42 : Operation Cancelled... 19:36:42 : Total Elapsed Time 00:03:04 19:36:42 : ERROR: Write FAILED! |
02-25-2016, 11:07 | #82 (permalink) | |
what file did you write? | |
02-26-2016, 10:17 | #84 (permalink) |
Registered User Join Date: Jul 2006 Location: indore m.p. india 452007 Age: 37
Member: 320752 Status: Offline Thanks Meter: 30 | same hear i am write full with emmc but handset is dead j700f i am try 4 time 4 x firmware and all time emmc write only boot 1 not boot 2 what is wrong with me |
02-26-2016, 11:57 | #86 (permalink) | |
Junior Member Join Date: May 2009
Member: 1040322 Status: Offline Sonork: milad Thanks Meter: 2 | Quote:
I flash boot and cm j700f with this firmware J700FXXU1APA7_J700FOJV1APA5_J700FXXU1APA1_HOME.tar but problem exist help | |
02-26-2016, 12:57 | #87 (permalink) |
Member: 1748375 Status: Offline Sonork: 100.1617845 Thanks Meter: 17 | Atf team not answer. I think maybe atf team not guide completly for repair this phone. Becuase every thing is ok and sboot and cm write succsesfull. Sent from my SM-N920C using Tapatalk |
02-26-2016, 13:17 | #88 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Why not read the easy Procedure write here: http://forum.gsmhosting.com/vbb/f609...shing-2052359/ Sticky thread no there's for "loveliness" but for to be used, so not are lazy and read first some basical things about manage EMMC direct with Atf. Br allumts |
02-26-2016, 13:46 | #89 (permalink) |
Member: 1748375 Status: Offline Sonork: 100.1617845 Thanks Meter: 17 | I read completly and done completly again and again and again and tested 2 j700f and 1 j700H and write sboot and cm succesfull. But phones still dead. In power supply voltage phone when power it .03 and then 0 3 phones in my hands same after write Sboot and CM. Sent from my SM-N920C using Tapatalk |
