02-26-2016, 14:41 | #91 (permalink) | |
Junior Member Join Date: May 2009
Member: 1040322 Status: Offline Sonork: milad Thanks Meter: 2 | Quote:
but the other one j700f\dd and j700h write boot and cm with different firmware but still not ok . how can I do for this two phone ??? | |
02-27-2016, 22:23 | #92 (permalink) |
Freak Poster Join Date: Apr 2012 Location: Iran
Member: 1748375 Status: Offline Sonork: 100.1617845 Thanks Meter: 17 | i dont understand last firmware for j700F dd is J700FXXU1AOL2_J700FODD1AOL1_INS ? Or same with J700F ds last firmware J700FXXU1APA7_J700FOJV1APA5_BTC ??? this mean I repair J700F dd with Last firmware dd Indian firmware Or same Ds Normal J700F,??? I want you Answer me . Thanks. |
03-01-2016, 12:07 | #96 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: turkey Age: 35
Member: 495542 Status: Offline Sonork: 100.1650191 Thanks Meter: 45 | Quote:
this FAKE product ??????????????? | |
03-01-2016, 22:57 | #97 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yes, get in the TRUSH!!!! For use this FAKE adapter you must need of modific all otherwise you cannot work with Atf. P.D. search in section one of many post with photo and how modific all this fake adapter Br allumts |
03-03-2016, 12:42 | #102 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yoy must need of connect in Golden point no where you have signed. Ceck you connection in you adapter and show full info of what type of Atf are using, if Direct RJ45 cable, (Only BIG Atf), show photo of you connection done first of say that's wrong, is Full tested and working 100% |
03-05-2016, 11:09 | #103 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733008BDF2E87A2A3 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 8BDF2E87 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733008BDF2E87A2A3.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... ERROR: PIT Partition NOT FOUND! Please Provide a PIT File via Selecting "Re-Partition" |
