03-07-2016, 14:25 | #107 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | and what about my j700h post ,,,no one rply for me ....... |
03-07-2016, 17:08 | #108 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Why not read and open you eyes? have answer in post #104 New Bootloader had posted for you and no has thanked and ask here becouse are very Tired for read right? Incredible all in handle want Br |
03-08-2016, 00:45 | #109 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2542589 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Hi Possible full explanation of opening the phone to a soft and Thanks |
03-08-2016, 08:03 | #110 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | dear boss..tnx for usefull post..and atf team.i have problem to boot repair j700f i got 4 mobile i repair only one but all other boot repair done.but still not power on or in download mode there is any new mathod i try with pit also but still same.one of them i try full flash its take around 30mints its also came in download mode but when try to flash its alwasy fail.but all other 100% boot file done but not in download mode..plz help.. |
03-08-2016, 09:43 | #111 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Use Sticky Thread and Forum for to have Basic Knowledge, in other case more good not touch nothing and send to a Complete shop of Telephonia. It's Atf section, no "Tech School", sorry but it's the reality. BR | |
03-08-2016, 09:47 | #112 (permalink) | |
Read carefully Guide and search where you are Wrong. Br allumts | |
03-08-2016, 17:32 | #114 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | Hi to all i need help try other box phone connect ok and write bl file ok but phone not show download mode then try with ATF but error my ATF emmc adapter ok other phone connecting good ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (CRC7 Fail 0x77) ERROR: EMMC_SET_RELATIVE_ADDRESS FAILED (CMD3) Check your Test Point Soldering! |
03-08-2016, 21:35 | #115 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | How can write that you connection is OK?....not import here of other box lol...atf work in his mode and this is one Big Connection Error: Quote:
allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
03-09-2016, 08:02 | #117 (permalink) |
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | ok tnx i will try...but can you tell me how to read full backup..i have one working device i want to take full backup and then i will try to write it to dead device.but i dont know start block.....and end block..and size if you help i can try....tnx. |
03-09-2016, 11:08 | #118 (permalink) | |
Member: 1886712 Status: Offline Thanks Meter: 53 | Quote:
write file done but phone not come download mode still dead i need help ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330029C4C8D3A257 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 29C4C8D3 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330029C4C8D3A257.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 2 Process Done! then write other file BL file but phone still dead ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330029C4C8D3A257 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 29C4C8D3 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330029C4C8D3A257.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:18 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 3 Process Done! | |
03-09-2016, 12:09 | #119 (permalink) | |
================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330029C4C8D3A257 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 29C4C8D3 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330029C4C8D3A257.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Normal Factory Erase ================================================== ==== For eMMC Revision 1.2 (for MMC v4.2) and LOWER --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB For eMMC Revision 1.3 (for MMC v4.3) and HIGHER --> This will ONLY ERASE USER AREA ================================================== ==== This eMMC is: Revision 1.x (For MMC v4.x) Factory Erasing Supported FLASH AREA... Normal Factory Erase Done! ================================================== ==== WARNING - WARNING - WARNING - WARNING - WARNING ================================================== ==== 1. WRITE BOOT1 Image if Needed 2. WRITE BOOT2 Image if Needed 3. WRITE USER AREA Image if Needed ================================================== ==== Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Start Writing 0x00000001 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:00 Write Success! Start Writing 0x00100000 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:13:58 Write Success! | |
03-09-2016, 13:49 | #120 (permalink) |
Member: 1886712 Status: Offline Thanks Meter: 53 | ok thanks for all my problem solve i write this file BL_J700HXXU1APA3_CL877784_QB8010669_REV00_user_low _ship.tar ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003430303037330029C4C8D3A257 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 29C4C8D3 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003430303037330029C4C8D3A257.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT Start Writing 0x00000008 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 3 Process Done! Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Unlocking device ... ok ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Load BOOT "E:\Z3X\FLASH FILE\J700H\SM-J700H_1_20160113183027_pwxuf0iq4t_fac\BL_J700HXXU1 APA3_CL877784_QB8010669_REV00_user_low_ship.tar.md 5" ok Load PDA "E:\Z3X\FLASH FILE\J700H\SM-J700H_1_20160113183027_pwxuf0iq4t_fac\AP_J700HXXU1 APA3_CL877784_QB8010669_REV00_user_low_ship.tar.md 5" ok Load Phone "E:\Z3X\FLASH FILE\J700H\SM-J700H_1_20160113183027_pwxuf0iq4t_fac\CP_J700HXXU1 AOL1_CL877784_QB7821759_REV00_user_low_ship.tar.md 5" ok Load CSC "E:\Z3X\FLASH FILE\J700H\SM-J700H_1_20160113183027_pwxuf0iq4t_fac\CSC_OXY_J700 HOXY1AOL1_CL877784_QB7821759_REV00_user_low_ship.t ar.md5" ok Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD load pit from files ... Connect to device ... Device pit saved to E:\BST\backup\samsung\pit\SM-J700H\SM-J700H_2016-03-09_17.45.25.pit re-partition ... Write file sboot.bin ... Write file param.bin ... Write file cm.bin ... Write file boot.img ... Write file recovery.img ... Write file system.img ... Write file modem.bin ... Write file cache.img ... Write file hidden.img ... Flash completed Time used : 1 min 25 s |
The Following User Says Thank You to aliusmanbava For This Useful Post: |
