12-03-2014, 08:15 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @zintung2911 Click "SCAN SDC" and post logs If SD card cannot be detected, then possible your SD card socket has problem. You can just clean the ATF PCB and check the resistors below the SD Card slot if they are shorted. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-14-2014, 08:44 | #4 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2100924 Status: Offline Thanks Meter: 19 | Thanks to the mod, I've found the cause. My Samsung Pro memory card is not supported by ATF box .... I have to change to another type of memory card 10 and succeeded in clashes. Cause: Error due to memory card .......... |
