11-04-2015, 14:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | SDC Write Error - [SOLVED] =============================================== =============================================== SDC Direct Access Connection Module ================================================== ============================================ ERROR: Failed to Initialize SDC Module Total Elapsed Time 00:00:02 ERROR: WRITE FAILED! ====== ====== I used 2 different SD original cards (8GB and 16GB) The Lightning Dongle has a Orange light gowing ON. Im using v12.50 (updated from v12.34 Full Package) How do I solve this ? |
11-04-2015, 15:20 | #2 (permalink) |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | I tried to do more research and i went to the CONNECTION MANAGER tab to try to read card info: Here is what I got when i click Read Card Info - ERROR: Failed to Initialize SDC Module 0x5E ERROR: Failed to Initialize SDC Module |
11-05-2015, 14:33 | #3 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: türkey AKSARAY
Member: 897899 Status: Offline Thanks Meter: 36 | Quote:
11-05-2015, 22:32 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Maybe your adapter is faulty? Do you have another adapter to check with or another ATF box? This could not be EXE problem as this feature working for other users. What's your ATF box firmware version? Did you update box firmware? I would also suggest to download and install full installer of ATF 12.50 version as you just updated EXE only and also repair box EEPROM from at product support tab. |
