07-28-2013, 15:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | SECURITY_TEST : FAILED 6700s Basic Phone Information ================================================ MCU Version: V ICPR82_11w16.3 19-05-11 RM-576 (c) Nokia IMEI Plain : 353390045479134 IMEI Spare : A353390045479130 IMEI SV : 33533900454791344F Phone Model: Nokia 6700s Category : Classic Phone Phone Type : RM-576 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Product Code : 0589333 Long Production SN : 0 MCU SW Version : V ICPR82_11w16.3 19-05-11 RM-576 (c) Nokia HW Version : 1001 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR82_11w16 AHNE Version : 11 APE SW Core Version : 071.004 Variant Version : 071.004071.004.11.01071.004.C00.01 APE Test Version : 0.049 RETU Version : 35 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Bluetooth ID : 206:07:4B:79:43 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED ================================================== ==== Selected VPL File: RM576_0589278_071.004_001.vpl ================================================== ==== Variant Details : RM-576 CTR RAW ALUM RUSSIAN LATIN CIS/GE Software Version : 071.004 Product Type : RM-576 Product Code : 0589278 Variant Version : 001 not found this pm file rm-576 in sx4 folder how ro repair this fault? please explain |
07-29-2013, 06:23 | #3 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | same after sx4 pm auth then wrote PM 1 and 309 ================================================ Super Dongle RPL Stand Alone Edition ================================================ Generating Super Dongle RPL... Sending Superdongle RPL... OK: Super Dongle RPL Accepted Successfully done. ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-576.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 2 Byte(s): 10 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 6 Byte(s): 10 - Ok Field : 1 Sub : 7 Byte(s): 214 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 10 - Ok Field : 1 Sub : 16 Byte(s): 208 - Ok Field : 1 Sub : 18 Byte(s): 208 - Ok Field : 1 Sub : 20 Byte(s): 208 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 26 Byte(s): 110 - Ok Field : 1 Sub : 28 Byte(s): 10 - Ok Field : 1 Sub : 29 Byte(s): 10 - Ok Field : 1 Sub : 31 Byte(s): 208 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 376 - Ok Field : 1 Sub : 35 Byte(s): 16 - Ok Field : 1 Sub : 37 Byte(s): 4 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 16 - Ok Field : 1 Sub : 41 Byte(s): 182 - Ok Field : 1 Sub : 42 Byte(s): 4 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 182 - Ok Field : 1 Sub : 45 Byte(s): 182 - Ok Field : 2 Sub : 0 Byte(s): 2080 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... ================================================ Basic Phone Information ================================================ MCU Version: V ICPR82_11w16.3 19-05-11 RM-576 (c) Nokia IMEI Plain : 353390045479134 IMEI Spare : A353390045479130 IMEI SV : 33533900454791344F Phone Model: Nokia 6700s Category : Classic Phone Phone Type : RM-576 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Product Code : 0589333 Long Production SN : 0 MCU SW Version : V ICPR82_11w16.3 19-05-11 RM-576 (c) Nokia HW Version : 1001 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR82_11w16 AHNE Version : 11 APE SW Core Version : 071.004 Variant Version : 071.004071.004.11.01071.004.C00.01 APE Test Version : 0.049 RETU Version : 35 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Bluetooth ID : 206:07:4B:79:43 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED any more solution please |
